Loading...
Pages: [1]   Go Down
Author Topic: USB serial Port not found  (Read 612 times)
Offline Offline
Newbie
View Profile
About an hour I was able to upload onto my arduino Uno but now the USB serial Port won't come up for me to be able to select it and I can't upload anything.
I'm using a Mac, an Arduino Uno.  I've tried some of the suggestions that I found on the web but nothing seems to make a difference.
Help would be greatly appreciated smiley
Logged
Tacoma, Washington, USA
Offline Offline
Newbie
View Profile
If you have the Serial Monitor ON (Displayed), close it, then disconnet the UNO from USB, reconnect the UNO and check if COM port is now available.
Bob
Logged
Offline Offline
Newbie
View Profile
I didn't have Serial Monitor open.
I'm trying with another arduino duemilenove now and the port is coming up but I keep getting this msg:
"avrdude: stk500_recv(): programmer is not responding"
I've used arduino for a couple of years now and I've never had any of these problems...I'm at a complete loss as to what to do.
Logged
Offline Offline
Newbie
View Profile
Your driver probably isn't installed properly. This is how I solved the problem.
Go to your Control panel > hardware and sounds > device manager > Ports
- then you should see "Unknown device". Double click on it
- Click on the "Driver" tab
- Click on "update Driver"
- Click on "Browse my computer for driver software"
- click "browse" and select the "drivers" subfolder in your Arduino folder.
- Click "next" and hopefully, your computer will install the driver for you successfully
Goodluck  smiley
Logged
Offline Offline
Newbie
View Profile
Do you have 1.0.3 or the beta arduino IDE?
Logged
Austin, TX
Offline Offline
Faraday Member
CMiYC
View Profile
WWW
Okay but they are on a Mac, so none of this applies.
When switching to the Duemilanove, did you remember to change the board type in the IDE?
Logged
www.cmiyc.com - A guide to being an Enginerd
Pages: [1]   Go Up
Print
Jump to:
