Pages: [1] 2   Go Down
Author Topic: Changes to external ip  (Read 823 times)
Hello all
As you probably here all the time im quite new to all this and could really use some help in my project
I need my programing to:
1) get external IP
2) Wait for a while
3) Get new external IP
4) Compare the old and new to see if their are any changes
im really going nowhere any input would be appriciated
Thanks
Seattle, WA USA
Seattle, WA USA
1) get external IP
Of what?
2) Wait for a while
That's easy.
Of?
And if they are?
Sorry, the external ip of the Ethernet board or rather the router/ the inetrnet connection it is using
Oh, if the external ip is different then it will hopefully send a get request to another server, i have actualy managed this bit and in my backwards thinking to start at the end and work my way back.
Thanks
Seattle, WA USA
Seattle, WA USA
I don't know if it's even possible to get the address of the outward facing IP of router that the Arduino is connected to. I asked that this topic be moved here to Networking, because it is more appropriate here. Perhaps someone else will be able to answer your question.
Put this php script to a server on Internet with know ip:
<?php
print ('<'.$_SERVER['REMOTE_ADDR'].'>');
And use something like this script to read the ip from there: http://bildr.org/2011/06/arduino-ethernet-client/
Now you just need to compare the new and old ip values.
Is this what you are looking for?
« Last Edit: January 10, 2013, 07:17:27 pm by llukkari » Logged
Yeah Thank you that helps a lot, I dont suppoze you would know how i could then compare the old from the new?
Thanks again
Smithfield, Rhode Island
The easiest way, although probably not the most efficient, is to use the String class. What version of the Arduino environment are you using?
Seattle, WA USA
Seattle, WA USA
How have you written the code to get the two values?
Well thats really the part i dont get, i can not get the external ip (thanks) so so far ive got:
//ARDUINO 1.0+ ONLY
//ARDUINO 1.0+ ONLY
#include <Ethernet.h>
#include <SPI.h>
//CONFIGURE
byte server[] = { 192,168,0,31 }; //ip Address of the server you will connect to
//The location to go to on the server
//make sure to keep HTTP/1.0 at the end, this is telling it what type of file it is
String location = "/externalip.php/ HTTP/1.0";
// if need to change the MAC address (Very Rare)
EthernetClient client;
char inString[32]; // string for incoming serial data
int stringPos = 0; // string index counter
boolean startRead = false; // is reading?
void setup(){
  Ethernet.begin(mac);
void loop(){
  String pageValue = connectAndRead(); //connect to the server and read the output
  Serial.println(pageValue); //print out the findings.
  delay(5000); //wait 5 seconds before connecting again
String connectAndRead(){
  Serial.println("connecting...");
  //port 80 is typical of a www page
  if (client.connect(server, 80)) {
    Serial.println("connected");
    client.print("GET ");
    client.println(location);
    client.println();
    //Connected - Read the page
    return readPage(); //go and read the output
  }else{
    return "connection failed";
String readPage(){
  //read the page, and capture & return everything between '<' and '>'
  stringPos = 0;
  memset( &inString, 0, 32 ); //clear inString memory
  while(true){
    if (client.available()) {
      char c = client.read();
      if (c == '<' ) { //'<' is our begining character
        startRead = true; //Ready to start reading the part
      }else if(startRead){
        if(c != '>'){ //'>' is our ending character
          inString[stringPos] = c;
          stringPos ++;
        }else{
          //got what we need here! We can disconnect now
          startRead = false;
          client.stop();
          client.flush();
          Serial.println("disconnecting.");
          return inString;
I setup a webserver localy on that ip for now which is printing the internal ip but shows alls working, so as of now i get a simple ip address.
So i think what i need to do is then save that numer as a string?
Then wait (thats the easy bit  smiley )
Then change the name of the now old ip sting to "old"
Check again and call it "new"
Check old against new
If old is the same as new then...
If not start again
But i have no idea how to get the read data and save it as a string?
Thanks again for your time
Seattle, WA USA
Seattle, WA USA
Where did you get that crappy code?
There is no reason to be using the String class. There is, in particular, almost a crime in wrapping a global char array as a String just because you can't figure out what the correct return type for readPage() should be (hint: it's void).
Anyway, that code does something, and generates some serial output. The psychic we hired starts the 12th of never. If you need help before then, you'll tell us what that code actually does, and show the serial output.
Online Online
You might start with some code like below.
//zoomkat 9-22-12
//simple client test
//for use with IDE 1.0.1
//with DNS, DHCP, and Host
//open serial monitor and send an e to test
//for use with W5100 based ethernet shields
#include <SPI.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
char serverName[] = "checkip.dyndns.com"; // zoomkat's test web page server
void setup(){
  if (Ethernet.begin(mac) == 0) {
    Serial.println("Failed to configure Ethernet using DHCP");
    // no point in carrying on, so do nothing forevermore:
    while(true);
  Serial.println("Better client test 9/22/12"); // so I can keep track of what is loaded
  Serial.println("Send an e in serial monitor to test"); // what to do to test
void loop(){
  // check for serial input
  if (Serial.available() > 0) //if something in serial buffer
    byte inChar; // sets inChar as a byte
    inChar = Serial.read(); //gets byte from buffer
    if(inChar == 'e') // checks to see byte is an e
      sendGET(); // call sendGET function below when byte is an e
void sendGET() //client function to send/receive GET request data.
  if (client.connect(serverName, 80)) {  //starts client connection, checks for connection
    client.println("GET / HTTP/1.0"); //download text
    client.println("Host: checkip.dyndns.com");
    client.println(); //end of get request
  else {
    Serial.println("connection failed"); //error message if no client connect
    Serial.println();
  while(client.connected() && !client.available()) delay(1); //waits for data
  while (client.connected() || client.available()) { //connected or data available
    char c = client.read(); //gets byte from ethernet buffer
    Serial.print(c); //prints byte to serial monitor
  Serial.println();
  Serial.println("==================");
  Serial.println();
  client.stop(); //stop client
put in key search words,
Excellent code Changes to external ip
How do I send the ip found for a PHP page or email?
Or how do I access a page as http://username:password@members.dyndns.org/nic/update?hostname=yourhostname&myip=ipaddress
London, UK
You can use UPNP to get your external IP from your router.
This library can do it pretty easily.
https://github.com/deverick/Arduino-Upnp-PortMapping
Ok But I like to get my external ip (wan) to be able to access the Internet via arduino. In that case then I can not know the external IP.
Pages: [1] 2   Go Up
