Loading...
Pages: [1]   Go Down
Author Topic: how to read the angle value of a continuous rotation servo  (Read 231 times)
Offline Offline
Newbie
View Profile
Hi guys, I would like to know if the function read of the servo library gives the current angle value even if it is applied to a continuous rotation servo. Using the function write we are setting the speed, so does the command read return the last speed or the current angle?
Logged
Dubuque, Iowa, USA
Offline Offline
Edison Member
View Profile
The signal you sent to the servo is representative of its speed and not its angle. There's no way to determine the angle of a continuous rotation servo unless you add some type of additional, absolute encoder.
Logged
Offline Offline
Newbie
View Profile
OK, thank you!
Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Not only can you not obtain the position value of a continuous rotation servo, even when using a standard unmodified servo the value returned from a servo read command is just whatever the last servo write value you used and if the servo is still moving to reach that servo write command posotion, then the servo read command will not reflect it's actual position until enough time has passed for the servo to reach the last position command written to it. It's a case that software can often run much faster then the hardware one is trying to control.
Lefty
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
If one wanted to DIY their own continous rotation servo, there is some possibility of having position feedback. The pots in servos I've modified don't have mechanical stops on the pots themselves. If one can work with small circuit mods. one might be able to electrically disconnect the internal pot, substitute a small resistor voltage divider for the internal pot, then externally read the origional internal pot.
Logged
Why I like my 2005 rio yellow Honda S2000 with the top down, and more!
GOOGLE ADVANCED FORUM SEARCH BELOW!
Go to:  http://www.google.com/advanced_search?hl=en
put in key search words,
use site or domain:  http://arduino.cc/forum
or in a google search box put key words site:http://arduino.cc/forum
Offline Offline
Brattain Member
View Profile
That is possible. Remove the wiper wire and wire it to the center of two 10k ohm series resistors wired to Vcc and ground to make the servo electronics happy and use the pot's wiper terminal as a feedback signal to an arduino analog input pin. Keep in mind that the pot will have a 'bad spot' that will read flaky most likely, were it wraps around from min to max on the pot.
Lefty
Logged
Pages: [1]   Go Up
Print
Jump to:
