Topic: Does 7.2VDC RC battery pack kill 6VDC servos? (Read 2419 times) previous topic - next topic
jeffmorris
I have been using 7.2VDC battery pack usually used for RC vehicles. A few days ago, some EZ-Robot S08NF STD servos died. Now, some Power HD 1501 MG servos died. I'm afraid to use Futaba S3003 servos with the 7.2 VDC battery pack. Any suggestions?
zoomkat
Any suggestions?
Follow the min and max voltage recomendations for the servos.
keeper63@cox.net
Most standard servos are rated for 4.8 to 6.0 VDC (generally for the electronics inside). There are models of servos out there designed for higher voltages, but as zoomkat noted, you need to check the datasheets for your servos before applying power. When in doubt, try 5 VDC first.
jeffmorris
How do I create a circuit that reduces 7.2VDC to 6.0VDC?
Funky Diver
Get a BEC for off the shelf voltage conversion, they're pennies
retrolefty
The 7.2 volt battery pack sounds like a Li-Po pack? If so it's output voltage will be proportional to it's state of charge reaching 8.4vdc at full charge and down to 6vdc where you should stop drawing current or risk overdischarging the pack which can cause permanent damage to the battery. But that aside running most servos at higher then 6.0 is a good way to start and build up a collection of ex-servos.
Lefty
JimboZA
Easiest way is probably to get a 7806 6v regulator.... if that's unavailable then the 7805 5v is very very common and will be ok with your servos if they are the 4.8 to 6v ones. Read about them here.
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
E40racer
Search ebay or hobbyking for UBEC's. These devices will step down the voltage to 5 or 6V and are used in RC cars/planes to power the servos. Your local RC store will probably have some in stock... Most "RC" servo's are made for a max voltage of 6V.
www.bajdi.com
