Topic: A cautionary tale with cheap ebay Voltage Regulators. (Read 7802 times) previous topic - next topic
cjdelphi
I can show a stable voltage on video to the device you're powering, but decrease the resistance the voltage increases.
That's probably quite different than saying that the voltage increases when you short them.
the voltage sure does rise when you short them, i'm uploading a video of me just brushing 2 crockadile clips together, i then make it switch between voltage in and voltage out (it alternates). then as i short the clips
you'll see the voltage jump, the voltage reader is correct, confirmed it by the multimeter, but when it gets hot powering a device with a large current the voltage does also increase, but it has to be a large current, eg an arduino alone wont be effected too little current.... but if you start connecting bigger items, motors and things? I dunno, i only discovered it by accident when shorting it once time and blowing a small 5mm LED never thought much of it until this board which displays the voltage on automatically arrived..
So i was playing with it and noticed that the 5? pin regulator on this was behaving the same as the even cheaper boards with an even less wattage rated IC switcher... but still this board can supply more watts big whoop, not interested, what I am interested in is why the voltage increases when shorted briefly or after long periods of heat the voltage goes up, device goes um poof.
cjdelphi
dhenry
Sounds like you have defined "short" uniquely.
cjdelphi
http://en.wikipedia.org/wiki/Short_circuit
"A short circuit is an abnormal connection between two nodes of an electric circuit intended to be at different voltages. This results in an excessive electric current/overcurrent"
- wiki
touching the clips results in max amp discharge causing the wires to give off heat. is this not a "short" ? I'm serious.....
dhenry
You probably want to focus on the part where it talks about very low / no resistance.
You cannot have a voltage drop over a wire with no resistance.
cjdelphi
Docedison
#21
Jan 11, 2013, 05:15 pm Last Edit: Jan 12, 2013, 01:39 am by Docedison Reason: 1
The Title... or more correectly how to abuse a component without really trying.
The regulator is rated at 2A output current... for short periods of time because there is no effective heat sink.
Read ALL the data sheet INCLUDING the thermal considerations. The voltage drift is most likely due to components on the board getting hot. The OP once mentioned that the module was too hot to touch and it is my opinion that IF as I believe this is the case, then the module needs to have a heat sink soldered to the bottom of the switcher. A 12 mm X 25 mm strip of copper about .6 mm thick with a hole 1/4 from one end a 90 deg at the half point, (middle) soldered to the switcher and mounted to a good heat radiator.
IMO the component is being abused and it is very simple to use it properly.
I appear here to be a hard nose but that is my training, I had to learn the hard way to be Certain that anything I did was 100% Perfect. I am non trying to be the expert, more to share my thoughts only, If I appear otherwise it is unintentional and I apologize.
{Edit, RKJ}
Bob
--> WA7EMS <--
retrolefty
A wire with no resistance? Can you spare me a little of yours as my supply of super-conductors has run low?
Lefty
SirNickity
Well, it is a switching regulator, so...  if you apply a large load to the output, then remove that load, it is likely to overshoot.  With an undersized output filtering stage, it's entirely possible that its regulation suffers when faces with current transients.  Now, if the voltage increases steadily with a consistent heavy load on the output (say, a 5 ohm resistor) then it's probably a component behaving out of tolerance.  Maybe a saturated inductor?  Or comparator oscillation?  I don't know.
It would be interesting to put a scope on the feedback voltage divider to see what the comparator input looks like under overload conditions.
Whether this is "abnormal abuse" or something that should be handled properly by the IC's protection circuitry is debatable.  I would like to know that if something in the load circuit failed, the PSU would do everything it its power to behave according to the three-tiered model:  Protect the user, protect the load, and protect itself -- in that order.  As a realist, I don't necessarily expect that in a regulator bought for spare change from a no-name overseas merchant via eBay.
westfw
It would also be interesting to wire up the same circuit with known-real chip and parts and see if it behaves similarly...
westfw
Hmm.  Noticing that actually SHORTING the output of a typical buck switching regulator is sort-of like operating the inductor like a boost regulator...
Also noticing that the input and output caps in the photos on eBay are smaller than the "typical circuit" in the datasheet.  (Even if "220" really means 220uF, and not 22uF, which is another possibility.)
Docedison
#26
Jan 12, 2013, 12:49 am Last Edit: Jan 12, 2013, 05:02 am by Docedison Reason: 1
Indeed it would and I for one would be very happy to do so.
The very few 3 or 4 of the 'Chinese' boards have all worked fine.
I am conservative in nature and have no desire to deal with excess heat so I try to remember that 10 to 20% of the load current will be lost as heat and plan accordingly.
The concept of counterfeit IC's crops up from time to time and for some, I can believe that the money for IC's that are "Pure Unobtanium" is too good to pass up and China is a Long way away.
There is as well the send me the defective ones and I'll test them and let you know what my 'engineers say". This has enough holes in it for it to work occasionally. However to begin to think about faking chips of that nature is unbelievable particularly in the quantities that are sold every day.
It is possible that only one house in Shenzhen has all the phonies.. but I've seen, bought, used  and have several 'variants' with and without meters, current adjustment, in both buck and boost mode Too..
I have designed and built switching regulators with both National Semi and Linear Tech's devices and by my experience that heatsink is going to get very warm with a 6 or 7 volt I/O differential and a 1A load.
It will take a few minutes and so might fool someone initially because of the thermal mass of the device, but the bottom line is as always if it is too hot to touch, comfortably, IT IS TOO HOT... Put a heat sink on it.
The rest of the errors reported could just as easily be measurement errors.
I am Not Trying to imply that the measurements are anything but what they claim or to be as I have no intention of starting any kind of discourse over a minor difference of opinion.
Possibly the wiring to the regulators might be long enough to require extra bypassing.
There are many possible causes and again due to the high volume of sales coupled with the low numbers of complaints reported here in the Forum I am for one somewhat inclined to be skeptical of "Cheap Chinese Knock Off's or counterfeit IC's as the reasons for performance issues, especially of that nature.
Bob
--> WA7EMS <--
Docedison
#27
Jan 12, 2013, 01:04 am Last Edit: Jan 12, 2013, 01:30 am by Docedison Reason: 1
No I don't think it means 22 uF, that marking is used for ceramic caps... to the best of my knowledge and experience.. Or at least in the past 50 years.. give or take a day. That they are marked 220 uF means little though, those are Electrolytics on that PCB and the SMT components place them at being less than ..? 20 years old.. Surplus at any rate.
Seriously the parts if more than a year old are suspect, highly suspect... I put my scope on both input and output and use a 10 uF tant and check for significant ripple reduction on both input and output noise with any of those switchers.. It's called Due Dilligence.
If I see any the caps are old and dried out, I replace them. For the cost of the board...
Well below what I could purchase them in less than 25 quantities blank and bare of anything but the etching and screening..
Thank You, I will try to understand my 'resource' and make the best of it.
Much more interesting for me to find out *Exactly* why and what to do to fix/avoid the issue and report that... Now... that's really useful.
Bob
--> WA7EMS <--
cjdelphi
Ah now that explains it...  cheers
jmknapp
#29
Jul 22, 2013, 12:09 pm Last Edit: Jul 22, 2013, 12:12 pm by jmknapp Reason: 1
I bought a lot of 10 of the ebay LM2596 boards for about $15 shipped.
http://www.ebay.com/itm/10pcs-LM2596S-power-module-DC-DC-Buck-Converter-Step-Down-Module-/400358408922
After some testing, I suspect that the LM2596S chip on these boards is counterfeit. The LM2596 spec sheet says that the switching frequency is 150 KHz, but these measure more like 50 KHz. The output ripple is supposed to be under 30 mV, but I see 200 mV with a 5V/300ma load. Also, if I set it for 5V at no load, I measure 4.75V at 1.6A load, more droop than expected.
Last year I bought a very similar-looking device from ebay for $6, only slight differences in the layout, matching this item:
http://www.ebay.com/itm/DC-DC-Buck-Converter-Module-LM2596-Breadboard-Power-Module-1-23V-35V/321158804705
That device shows a 150 KHz switching frequency as expected and much lower output ripple.
