Loading...
Pages: [1]   Go Down
Author Topic: how to use LabVIEW for receive data from serial monitor ?  (Read 756 times)
Offline Offline
Newbie
View Profile
Can i use 2 Xbees(one with arduino to LabVIEW and one with LM35) and 1 Arduino for temperature monitoring in LabVIEW ? , How to use LabVIEW(LIFA or VISA) for receive data from serial monitor arduino ?
I'm newbie for LabVIEW Arduino and Xbee and I'm so confused.
I've used
Arduino UNO
Xbee S2 & Xbee S2PRO
Xbee Shield from dfrobot
LM35
LabVIEW
Logged
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Quote
You can't. LabVIEW can receive data from the same serial port that the Serial Monitor does, but not at the same time. Only one application can connect to a serial port at a time.
Quote
Then, a simpler project, or breaking this one down into smaller pieces, is in order.
Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
Quote
There are serial port replicators applications but IIRC these are not really cheap.
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Offline Offline
Newbie
View Profile
Thanks , All
i want to receive  data in difference time , how i can config this
Logged
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Quote
Start with learning when to use capital letters, like an adult. Then, explain what this means.
Logged
Offline Offline
Newbie
View Profile
How Xbee Need to use X-CTU before communication with LabVIEW ?
Logged
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Quote
The XBee doesn't communicate with LabVIEW. It puts data on the serial port and gets data from the serial port. Whether the other end of that serial port is connected to the Serial Monitor application or LabVIEW is irrelevant.
Why are you using Mesh Network modules to do Point to Point communications? How have you configured the XBees? Do you KNOW that they communicate?
Finally, answer the questions that are asked before asking more.
Logged
Pages: [1]   Go Up
Print
Jump to:
