Loading...
Pages: 1 [2]   Go Down
Author Topic: HarwareSerial.h  (Read 1156 times)
Offline Offline
Newbie
View Profile
#include<NewSoftSerial.h>
NewSoftSerial mySerial(2,3);
char c;
  mySerial.begin(9600);
  Serial.Print("Key1");
  if (mySerial.available() > 0)
    c=mySerial.Read();
This is the code i compiled. But couldn't receive data "key1" to the variable c.
Could you check the output in your hardware, once shorting the pins i mentioned?
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
How do you know? What is connected to the software serial pins - 2 and 3?
Logged
Offline Offline
Newbie
View Profile
char c;
    c=mySerial.Read();
Serial.print(c);
I could observe garbage values only. I tried with a single character, as well. That is, Serial.print('A'), instead of Serial.print("key1"). Still, i couldn't get the desired result.
Logged
Offline Offline
Newbie
View Profile
Software pin 'tx' (pin 3) is shorted to hardware 'rx' and Software pin 'rx' (pin 2) is shorted to hardware 'tx'
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
The proper ratio of answers to questions is 1 to 1. Try again.
Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
Quote
What i expect is to receive those 4 characters "key1" through the software 'rx' pin, to a variable c, once it has been transmitted over the hardware 'tx'.
and what did you get?
and how did you check that?
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Offline Offline
Newbie
View Profile
I printed the variable to verify. But i could obtain garbage values only.
Serial.print(c); Check this code below:
char c;
  Serial.Print('A');
    c=mySerial.Read();
Serial.print(c);
Here in the serial monitor i got output as shown below:
A <a rectangular symbol> A <a rectangular symbol> ........
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Why are you printing the value of c whether you received any data, or not? Move that print() statement inside the if() block.
And, answer the questions. WHAT IS CONNECTED TO PINS 2 AND 3?
Logged
Offline Offline
Newbie
View Profile
pin 3 (software 'tx') connected to hardware 'rx'
pin 2 (software 'rx') connected to hardware 'tx'
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
