Pages: [1] 2   Go Down
Author Topic: HarwareSerial.h  (Read 1180 times)
Somebody mail me the library file HardwareSerial.h (including HardwareSerial.h,HardwareSerial.cpp & keyword.txt).
bhairumaaman@gmail.com
Netherlands
it is in the c:\program files\arduino\... folder -> search the filesystem from that folder
Rob Tillaart
You do some programming to solve a problem, and some to solve it in a particular language. (CC2)
Why ?
@ tuxduino: I need to collect the serial data from the UART directly to a variable, through a software serial port. To do that, i found that the library HardwareSerial.h contains a function UART.Read(), which very well serves this purpose. But unfortunately i don't have this header file.
@ robtillaar: couldn't find it over there.
What operating system are you using ?
Did you download ad uncompress the Arduino zip file ?
HardwareSerial is part of Arduino core libraries.
Where did you read about UART.read() ?
Also, if you're thinking about using a software serial implementation, why are you looking for a _hardware_ serial library ?
Netherlands
on my PC this is one of the arduino paths
C:\Program Files (x86)\arduino-0022\hardware\arduino\cores\arduino
and the red part is different depending on IDE version
Are you familiar with the Serial class? It abstracts the hardware uarts,
if (Serial.available() > 0) x = Serial.read();
Rob Tillaart
 @robtillaart & @tuxduino: I am using ubuntu 11. I downloaded and installed arduino 0022 using the 'software centre' of ubuntu. Installation takes place automatically once the download is done.
The problem i faced was that i couldn't include the header file HardwareSerial.h in my program and hence i couldn't invoke the function UART.Read() (which i came across in a forum long time ago).
My requirement, in short, is to collect a serial data into a variable. By using "if (Serial.available() > 0) x = Serial.read()", we can collect data into variable x, only if we type the required string within the "Serial Monitor" of arduino. What i am trying is, to transmit a data, for example, "Serial.myPrint("arduino");", which will be transmitted via the 'tx' pin 3(which is set as my software 'tx' pin; pin 2 is the software 'rx') and collect the same into a variable, via the 'rx' pin of arduino. I have shorted the 'tx' pin of arduino with the software 'rx' pin 2 and 'rx' pin of arduino with the software 'tx' pin 3.
As i mentioned, if we use "x=UART.Read()", i can read and collect a data being received by the 'rx' pin of arduino.
Netherlands
Definitely NOT true.
Serial.print() writes to the hardware tx pin, Serial.Read() reads from the hardware rx pin.
You don't need to use UART.Read() but you can.
The serial monitor of the IDE can connect to the COM port (/dev/tty...) the Arduino has. This port is connected to the pins 0 and 1 too.
Any serial application can connect to the COM port (/dev/tty...) and read data from the Arduino. That is not restricted to the IDE.
x = Serial.Read() does just that.
The Arduino is single tasking and software serial is quite time critical so having it interrupted by the hardware serial my corrupt timing especially at higher baud rates.
What baud rate are you using?
Does that mean you have it working now?
Rob Tillaart
UART.Read()-I have only seen it. Still i can't use it.
I am using 9600 baud rate both for software and hardware serial.
Assume this scenario. In my program i am using a keypad. There are 12 keys. Once a key is pressed, a serial data corresponding to that key is transmitted. Say, for example, if first key is pressed data "Key1" is transmitted. (using Serial.Print("Key1")smiley-wink I need this data to be collected in a variable, after its transmission,through a port pin of arduino. This is the flow: A key is pressed--> Data corresponding to that key is transmitted--> Collect this data to a variable, through a port pin of arduino.
This is what i am trying to accomplish. I am using software serial to make port pin of arduino collect serial data.
Seattle, WA USA
Seattle, WA USA
Then why is HardwareSerial.h/.cpp relevant? You need to post code for both the sender and the receiver, so we can see what you are doing.
The reason why i wanted to use HardwareSerial.h was to use UART.Read().
I am using the same arduino board as the sender and receiver.
Sender is the hardware 'tx' pin.
Receiver is any of the port pin of arduino.
program:
#include<NewSoftSerial.h> // for software serial pins
NewSoftSerial mySerial(2,3); // sets port pin 2 as software 'rx' and pin 3 as software 'tx'
char c;
Serial.begin(9600); //sets baud rate for hardware UART
mySerial.begin(9600); //sets baud rate for oftware UART
Serial.Print("Key1"); //data sent via hardware 'tx' pin
if(mySerial.available()>0)
   c=mySerial.Read(); //data read via software 'rx' pin
I shorted the harware 'tx' and software 'rx' pins; also the harware 'rx' and software 'tx' pins. But this code did not work. I even tried the other way around. That is, transmit via software 'tx' and receive via harware 'rx'. But that too did not work. The code for this arrangement is here:
Serial.myPrint("Key1"); //data sent via software 'tx' pin
if(Serial.available()>0)
   c=Serial.Read(); //data read via hardware 'rx' pin
Netherlands
Can you compile this code ???
Rob Tillaart
Netherlands
One question about your code (removed your comments)
char c;
  Serial.Print("Key1"); //(1) <<<<<<<<<<<<<<
  if (mySerial.available() > 0)
    c=mySerial.Read(); // (2) <<<<<<<<<<<<<<<<
So you (1) print 4 characters over hardware serial and (2) read only one in software serial and you do nothing with it.
What do you expect to happen?
Serial.[color=red]myPrint[/color]("Key1"); //does not exist!!!     mySerial.print("key1") might compile
   c=Serial.Read();
for the rest same problem as before.
At least if you send 4 chars you need to read 4 chars.
Rob Tillaart
Serial.myprint() was a mistake. Actual syntax is mySerial.print().
I could compile my code.
What i expect is to receive those 4 characters "key1" through the software 'rx' pin, to a variable c, once it has been transmitted over the hardware 'tx'.
Seattle, WA USA
Seattle, WA USA
Then, post your ACTUAL code.
Pages: [1] 2   Go Up
