Topic: HarwareSerial.h (Read 6270 times) previous topic - next topic
bhairu
#include<NewSoftSerial.h>
NewSoftSerial mySerial(2,3);
char c;
  mySerial.begin(9600);
  Serial.Print("Key1");
  if (mySerial.available() > 0)
    c=mySerial.Read();
This is the code i compiled. But couldn't receive data "key1" to the variable c.
Could you check the output in your hardware, once shorting the pins i mentioned?
PaulS
How do you know? What is connected to the software serial pins - 2 and 3?
bhairu
char c;
    c=mySerial.Read();
Serial.print(c);
I could observe garbage values only. I tried with a single character, as well. That is, Serial.print('A'), instead of Serial.print("key1"). Still, i couldn't get the desired result.
bhairu
Software pin 'tx' (pin 3) is shorted to hardware 'rx' and Software pin 'rx' (pin 2) is shorted to hardware 'tx'
PaulS
The proper ratio of answers to questions is 1 to 1. Try again.
robtillaart
What i expect is to receive those 4 characters "key1" through the software 'rx' pin, to a variable c, once it has been transmitted over the hardware 'tx'.
and what did you get?
and how did you check that?
Rob Tillaart
bhairu
I printed the variable to verify. But i could obtain garbage values only.
Serial.print(c); Check this code below:
char c;
  Serial.Print('A');
    c=mySerial.Read();
Serial.print(c);
Here in the serial monitor i got output as shown below:
A <a rectangular symbol> A <a rectangular symbol> ........
PaulS
Why are you printing the value of c whether you received any data, or not? Move that print() statement inside the if() block.
And, answer the questions. WHAT IS CONNECTED TO PINS 2 AND 3?
bhairu
pin 3 (software 'tx') connected to hardware 'rx'
pin 2 (software 'rx') connected to hardware 'tx'
