Topic: HD44780 Doesn't Reinit After Power Off/On (Read 5486 times) previous topic - next topic
liudr
Great! Let me know if you have any questions on my libraries or hardware.
Serial LCD keypad panel,phi_prompt user interface library,SDI-12 USB Adapter
gerschu
By the way, i had a similar issue with no reset after power off, using photoduino board with the uno.
I cut the bridge at reset-en on board, voila : solved
palitu
Hey, i posted this on adafruit just now, but though i would share the love for anyone searching:
Hey,
I have quite a bit about this issue, and haven't really found an explanation or proper solution.
I am using a freeduino leonardo,and read somewhere that the LCD needs ~15ms prior to it being initialised. To fix it, i simply put a delay in the setup() function.
haven't had an issue yet.
Code: [Select]
    delay(20);
    lcd.begin(16, 4);
floresta
You have resurrected an ancient thread for this non-news.
Quote
I wonder if that is why the LCD initialization in the library starts out with a 50000 uS (50 mS) delay?  You haven't 'fixed' anything with that added delay unless you have an extremely out-of-spec display.
You should be more concerned with the improper cursor positioning on lines 3 and 4 of the 16x4 displays.
Don
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
