Topic: Giant score board (Read 959 times) previous topic - next topic
Mlandgraaf
Hi Guys,
A few monthes ago i posted about a giant score board that i'm making. So i finished the schematics and was hoping you could check it out, so that i wont be dissapointed when it doenst work!
It's made so you can connect a 10 wire ribbon cable to a series of led strips (330ma 12v each) making a giant 7-segment display.
Looking forward to your criticism!
Thanks
Mike
larryd
At 1st glance it looks good.
I think I would have used 4 X ULN2803 hex drivers rather than the FETS. This would get rid of 64 discrete components.
http://www.datasheetcatalog.org/datasheets/90/366828_DS.pdf
There are a myriad of ways of doing things though!
No technical PMs.
The last thing you did is where you should start looking.
larryd
:smiley-red: Your current requirements would negate an ULN2803.
No technical PMs.
Mlandgraaf
So if i send this to someone who makes PCB's it will work properly? The data connections are good?
tack
You can't just send a schematic, unless someone else is also going to design the PCB for you.
To send a PCB to be made then you need to design it, convert to the appropriate format for the tab house (usually Gerber files) and send them.
CrossRoads
The .pdf seems to try & open a link
http://arduino.cc/forum/index.php?action=dlattach;topic=142154.0;attach=33416
that is not any good.
Mlandgraaf
Can you tell me why i need a pull down resisitor? and what value should it be? I've let someone make a pcb, and it looks perfect!
Also, what capacitor needs to be on the vcc of the shift register?
Thanks
MIke
CrossRoads
0.1uF on the VCC pins.
Pulldown resistor - 10K is fine. Keeps the MOSFETs while the sketch comes out of bootloader and takes control of the IO pins bring them low prior to any data writing, i.e.
pinMode(pinX);
digitalWrite(pinX, LOW);
