Topic: Strange Problem while controlling motors with MOSFET (Read 2914 times) previous topic - next topic
nishant_91
So, I was trying to drive a motor using PWM based on the circuit in the Getting started with Arduino book (Image attached). However my circuit (the second image) does not behave as expected.
As soon as the power is turned on, the motor is on irrespective of the Arduino. In fact it works even if I disconnect the the arduino from the gate pin! I have replaced the mosfet, diode, resistor etc, in case there was a hardware problem but there is still no difference. Please hep me to find the mistake!
nishant_91
The thin red and blue wires are going to the brushed DC motor (Not able to fit in the picture, sorry!)
larryd
Your 100R resistor is shorted out, review how to use a protoboard.
I don't see a ground going to the Arduino.
No technical PMs.
The last thing you did is where you should start looking.
nishant_91
Thanks for pointing that out, silly of me,
But shouldn't it work even though the resistor is shorted? Since the motor should only be on wen there is a high voltage applied to the gate?
larryd
Please confirm you have a ground connection going to the Arduino.
Would you also confirm what number is written on the FET.
Also, we like to see a Gate to Ground resistor (10K should be good here).
No technical PMs.
nishant_91
I do not have a ground connection to the Arduino, is it necessary? I am new to electronics, could you tell me why?
The MOSFET is IRF520, I know it wont be fully activated by the Arduino since it is not a logic level MOSFET but it is enough for my purposes since me motor draws only 70mA
Lastly thanks for the help!
retrolefty
Yes it is necessary, because the gate voltage for the mosfet is coming from the arduino and it won't be a circuit without a ground return for the gate drive signal back to the arduino. You can't light a lamp by just having one wire from the battery positive to the lamp without also having a wire from the other side of the lamp back to battery ground. The mosfet source terminal is the return path back to whatever is driving the gate terminal.
nishant_91
Thanks for the explanation! I was not sure of the working principle of the MOSFET, I shall try it out with a ground!
