Hello, I am trying to get my MEGA with LCD to blink the screen. Below is the code, it is not working...It gets two errors when I check it, it will not let me copy and paste them for some reason.
Thanks for any help. Steve
Modified by Lauren
version 0.3
Any suggestions are welcome.
E-mail:
Lauran.pan@gmail.comEditor : Lauren from DFRobot
Date : 06.01.2012
* Have the back light under control.
* Update the library and sketch to compatible with IDE V1.0 and earlier
#ifndef LCD4884_h
#define LCD4884_h
#if defined(ARDUINO) && ARDUINO >= 100
#include "Arduino.h"
#else
#include "WProgram.h"
#endif
#define SPI_SCK 2
#define SPI_MOSI 3
#define LCD_DC 4
#define SPI_CS 5
#define LCD_RST 6
#define LCD_BL 7
//display mode -- normal / highlight
#define MENU_NORMAL 0
#define MENU_HIGHLIGHT 1
#define OFF 0
#define ON 1
class LCD4884
public:
LCD4884();
void LCD_init(void);
void backlight(unsigned char dat);
void LCD_write_byte(unsigned char dat, unsigned char dat_type);
void LCD_draw_bmp_pixel(unsigned char X,unsigned char Y,unsigned char *map,unsigned char Pix_x,unsigned char Pix_y);
void LCD_write_string(unsigned char X,unsigned char Y,char *s, char mode);
void LCD_write_chinese(unsigned char X, unsigned char Y,unsigned char *c,unsigned char ch_with,unsigned char num,unsigned char line,unsigned char row);
void LCD_write_string_big ( unsigned char X,unsigned char Y, char *string, char mode );
void LCD_write_char_big (unsigned char X,unsigned char Y, unsigned char ch, char mode);
void LCD_write_char(unsigned char c, char mode);
void LCD_set_XY(unsigned char X, unsigned char Y);
void LCD_clear(void);
extern LCD4884 lcd;
#endif //
