Topic: need help adding debounce to my code (Read 3116 times) previous topic - next topic
michael040990
hello all i need  help adding a debounce to this part of my code
        digital_state0[count] = digitalRead(mux_buttonPin[0]); //set mux0 input val for each digitalstate value
        digital_state1[count] = digitalRead(mux_buttonPin[1]); //set mux1 input val for each digitalstate value
        digital_state2[count] = digitalRead(mux_buttonPin[2]); //set mux2 input val for each digitalstate value
        digital_state3[count] = digitalRead(mux_buttonPin[3]); //set mux3 input val for each digitalstate value
here is the full code of the program
int mux_buttonPin[4] = {5,6,7,8};
int buttonState0 = LOW;
int lastButtonState0 = LOW;
int buttonState1 = LOW;
int lastButtonState1 = LOW;
int buttonState2 = LOW;
int lastButtonState2 = LOW;
int buttonState3 = LOW;
int lastButtonState3 = LOW;
int  digital_state0 [7]  = {
  LOW};//set aside input values for mux
int  digital_state1 [7]  = {
int  digital_state2 [7]  = {
int  digital_state3 [7]  = {
int r0 = 0;      //value select pin at the 4051 (s0)
int r1 = 0;      //value select pin at the 4051 (s1)
int r2 = 0;      //value select pin at the 4051 (s2)
int row = 0;     // storeing the bin code
int count = 0;    // just a count
int  bin [] = {
  000, 1, 10, 11, 100, 101, 110, 111};//bin = binär, some times it is so easy
void setup(){
  for (int i=0; i<=7; i++) {
    pinMode(digital_state0[i], INPUT); //mux0 inputs
    pinMode(digital_state1[i], INPUT); //mux1 inputs
    pinMode(digital_state2[i], INPUT); //mux2 inputs
    pinMode(digital_state3[i], INPUT); //mux3 inputs
  pinMode(2, OUTPUT);    // s0
  pinMode(3, OUTPUT);    // s1
  pinMode(4, OUTPUT);    // s2
  pinMode(mux_buttonPin[0], INPUT);     // mux0 read pin //digital
pinMode(mux_buttonPin[1], INPUT);     // mux1 read pin //digital
pinMode(mux_buttonPin[2], INPUT);     // mux2 read pin //digital
pinMode(mux_buttonPin[3], INPUT);     // mux3 read pin //digital
void loop () {
  for (count=0; count<=7; count++) {
    row = bin[count];
    r0 = row & 0x01;
    r1 = (row>>1) & 0x01;
    r2 = (row>>2) & 0x01;
    digitalWrite(2, r0);
    digitalWrite(3, r1);
    digitalWrite(4, r2);
    //Serial.println(bin[count]); //print current bin
    //Serial.println(digital_state0[count]); // print digital_state0 for debug
  //Serial.println(digital_state1[count]); // print digital_state1 for debug
  //Serial.println(digital_state2[count]); // print digital_state2 for debug
  //Serial.println(digital_state3[count]); // print digital_state3 for debug
    buttonState0 = digital_state0[count];
    buttonState1 = digital_state1[count];
    buttonState2 = digital_state2[count];
    buttonState3 = digital_state3[count];
    //MUX0
    if (buttonState0 != lastButtonState0) {
      // if the state has changed, increment the counter
      if (buttonState0 == HIGH) {
        // if the current state is HIGH then the button
        // wend from off to on:
        Serial.print("MUX0 button ");
        Serial.print(count);
        Serial.println(" pressed");
      else {
        // if the current state is LOW then the button
        // wend from on to off:
        Serial.println(" released");
    // save the current state as the last state,
    //for next time through the loop
    lastButtonState0 = buttonState0;
     //MUX1
    if (buttonState1 != lastButtonState1) {
      if (buttonState1 == HIGH) {
        Serial.print("MUX1 button ");
      else {
    lastButtonState1 = buttonState1;
//MUX2
    if (buttonState2 != lastButtonState2) {
      if (buttonState2 == HIGH) {
        Serial.print("MUX2 button ");
      else {
    lastButtonState2 = buttonState2;
//MUX3
    if (buttonState3 != lastButtonState3) {
      if (buttonState3 == HIGH) {
        Serial.print("MUX3 button ");
      else {
    lastButtonState3 = buttonState3;
  delay (10);  //delay 10 for read between values
here is the scimatics
http://i48.tinypic.com/qsthms.jpg
thank you in advance its driving me crazy i dont know were or how to implement the debounce
HazardsMind
Do a search in the project guidance forum. Debounce multiple buttons/switches
My GitHub:
https://github.com/AndrewMascolo?tab=repositories
michael040990
i found this code will it work?
const long debounceDelay = 20; //The button debounce time
// Button = pin number to read
int checkButton(int Button) {
  int buttonState = digitalRead(Button);    // Read button
  if (buttonState == HIGH) {                // If button pressed then wait a bit to allow for debounce
    long Time = millis();
    while ((millis() - Time) < debounceDelay) {
    buttonState = digitalRead(Button);      // Read button again
    return buttonState;                     // Return button state
  else {
    return LOW;
HazardsMind
It will for one button, but there is another code that does it for multiple buttons.
http://arduino.cc/forum/index.php/topic,139805.0.html
My GitHub:
michael040990
i was thinking i could just implement it in a loop for 4 times returning diffrent values like this but ill keep looking
HazardsMind
The link I gave you, is from my understanding, is what you're looking for.
My GitHub:
michael040990
sorry i didnt see the link before im trying to extract the debounceing part of his code is it more then just
boolean debounce(int thisButton) {
  boolean current = digitalRead(swiPin[thisButton]);
  if (currentButtonVal[thisButton] != current) {
    delay(5);
  currentButtonVal[thisButton] = current;  // store new state for your pin
  return current;
michael040990
is this enough for it to function the debounce?
int swiPin [] = {
  5,6,7,8};
boolean currentButtonVal[3];
void setup(){
  for(int x = 0; x<3; x++){
    currentButtonVal[x] = true;
    delay(5);
  return current;
void loop(){
  Serial.println(debounce(0));
  Serial.println(debounce(1));
  Serial.println(debounce(2));
  Serial.println(debounce(3));
HazardsMind
#8
Jan 11, 2013, 08:34 pm Last Edit: Jan 11, 2013, 08:43 pm by HazardsMind Reason: 1
No, look at Nick Gammon's code on page 3, its a lot, but it works. And it has a test you can do too.
If you want, you can also take the debounce code in your Arduino examples, and convert it to use arrays and the use of a FOR loop.
My GitHub:
michael040990
origionally i tryed using the debouncing libary but i dont know if that would work heres the code with at
#include <Debounce.h>
Debounce debouncer0 = Debounce( 20 , mux_buttonPin[0] );
Debounce debouncer1 = Debounce( 20 , mux_buttonPin[1] );
Debounce debouncer2 = Debounce( 20 , mux_buttonPin[2] );
Debounce debouncer3 = Debounce( 20 , mux_buttonPin[3] );
int  bin [] = {
void setup(){
void loop () {
    row = bin[count];
    r0 = row & 0x01;
    debouncer0.update(); // Update the debouncer
    debouncer1.update(); // Update the debouncer
    debouncer2.update(); // Update the debouncer
    debouncer3.update(); // Update the debouncer
        digital_state0[count] = digitalRead(debouncer0.read()); //set mux0 input val for each digitalstate value
        digital_state1[count] = digitalRead(debouncer1.read()); //set mux1 input val for each digitalstate value
        digital_state2[count] = digitalRead(debouncer2.read()); //set mux2 input val for each digitalstate value
        digital_state3[count] = digitalRead(debouncer3.read()); //set mux3 input val for each digitalstate value
    //MUX0
      else {
     //MUX1
      else {
//MUX2
      else {
//MUX3
      else {
HazardsMind
#10
Jan 11, 2013, 09:26 pm Last Edit: Jan 11, 2013, 09:46 pm by HazardsMind Reason: 1
Edit: Your code can be greatly simplified with the correct use of arrays, but try this. All I did was modify the example code.
Debounce
This example code is in the public domain.
http://www.arduino.cc/en/Tutorial/Debounce
// constants won't change. They're used here to
// set pin numbers:
const int buttonPin[] = {2,3,4,5};
const int ledPins[] =  {8,9,10,11};      // the number of the LED pin
int MAX_PINS = 4;
int i = 0;
int counter=0;
int reading[4];
//byte ledState = HIGH;
int buttonState[4];             // the current reading from the input pin
int lastButtonState[] = {LOW,LOW,LOW,LOW};   // the previous reading from the input pin
long lastDebounceTime[] = {0,0,0,0};  // the last time the output pin was toggled
long debounceDelay = 50;    // the debounce time; increase if the output flickers
  for(i = 0; i <= MAX_PINS; i++){
    pinMode(buttonPin[i], INPUT);
    pinMode(ledPins[i], OUTPUT);
  // read the state of the switch into a local variable:
  for(counter = 0; counter <= MAX_PINS; i++)
    reading[counter] = digitalRead(buttonPin[counter]);
    if (reading[counter] != lastButtonState[counter]) {
    lastDebounceTime[counter] = millis();
    if ((millis() - lastDebounceTime[counter]) > debounceDelay) {
      buttonState[counter] = reading[counter];
    digitalWrite(ledPins[counter], buttonState[counter]);
    lastButtonState[counter] = reading[counter];
My GitHub:
michael040990
the counter value never goes any higher then 0 in that example?
michael040990
alright im almost there heres what i have
// set pin numbers:
const int mux_buttonPin[] = {5,6,7,8};
int MAX_PINS = sizeof(mux_buttonPin)/2-1;
int counter=0;
int reading[sizeof(mux_buttonPin)-1];
int buttonState[sizeof(mux_buttonPin-1)];             // the current reading from the input pin
int  bin [] = {
void setup(){
   for(int i = 0; i <= MAX_PINS; i++){
    pinMode(mux_buttonPin[i], INPUT);// mux read pin
void loop () {
    row = bin[count];
    r0 = row & 0x01;
  for(int counter = 0; counter <= MAX_PINS; counter++)
    reading[counter] = digitalRead(mux_buttonPin[counter]);
// Serial.println(counter);
    Serial.println(buttonState[counter]);
    //MUX0
      else {
     //MUX1
      else {
//MUX2
      else {
//MUX3
      else {
heres the part that confused me
HazardsMind
#13
Jan 12, 2013, 12:42 am Last Edit: Jan 12, 2013, 01:04 am by HazardsMind Reason: 1
I made an error in my code, it was this "for(counter = 0; counter <= MAX_PINS; i++)" But change it to "for(counter = 0; counter <= MAX_PINS; counter++)"
It works with multiple buttons, I just tried it and it works perfectly.
EDIT.
Also,
Isn't any different from "reading[counter] = digitalRead(mux_buttonPin[counter]);"
My GitHub:
