« on: January 11, 2013, 01:24:31 pm » |
hello all i need help adding a debounce to this part of my code digital_state0[count] = digitalRead(mux_buttonPin[0]); //set mux0 input val for each digitalstate value digital_state1[count] = digitalRead(mux_buttonPin[1]); //set mux1 input val for each digitalstate value digital_state2[count] = digitalRead(mux_buttonPin[2]); //set mux2 input val for each digitalstate value digital_state3[count] = digitalRead(mux_buttonPin[3]); //set mux3 input val for each digitalstate value here is the full code of the program int mux_buttonPin[4] = {5,6,7,8};
int buttonState0 = LOW; int lastButtonState0 = LOW;
int buttonState1 = LOW; int lastButtonState1 = LOW;
int buttonState2 = LOW; int lastButtonState2 = LOW;
int buttonState3 = LOW; int lastButtonState3 = LOW;
int digital_state0 [7] = { LOW};//set aside input values for mux
int digital_state1 [7] = { LOW};//set aside input values for mux
int digital_state2 [7] = { LOW};//set aside input values for mux
int digital_state3 [7] = { LOW};//set aside input values for mux
int r0 = 0; //value select pin at the 4051 (s0) int r1 = 0; //value select pin at the 4051 (s1) int r2 = 0; //value select pin at the 4051 (s2)
int row = 0; // storeing the bin code int count = 0; // just a count int bin [] = { 000, 1, 10, 11, 100, 101, 110, 111};//bin = binär, some times it is so easy
void setup(){ for (int i=0; i<=7; i++) {
pinMode(digital_state0[i], INPUT); //mux0 inputs pinMode(digital_state1[i], INPUT); //mux1 inputs pinMode(digital_state2[i], INPUT); //mux2 inputs pinMode(digital_state3[i], INPUT); //mux3 inputs }
pinMode(2, OUTPUT); // s0 pinMode(3, OUTPUT); // s1 pinMode(4, OUTPUT); // s2 pinMode(mux_buttonPin[0], INPUT); // mux0 read pin //digital pinMode(mux_buttonPin[1], INPUT); // mux1 read pin //digital pinMode(mux_buttonPin[2], INPUT); // mux2 read pin //digital pinMode(mux_buttonPin[3], INPUT); // mux3 read pin //digital
Serial.begin(9600); } void loop () {
for (count=0; count<=7; count++) { row = bin[count]; r0 = row & 0x01; r1 = (row>>1) & 0x01; r2 = (row>>2) & 0x01; digitalWrite(2, r0); digitalWrite(3, r1); digitalWrite(4, r2); //Serial.println(bin[count]); //print current bin digital_state0[count] = digitalRead(mux_buttonPin[0]); //set mux0 input val for each digitalstate value digital_state1[count] = digitalRead(mux_buttonPin[1]); //set mux1 input val for each digitalstate value digital_state2[count] = digitalRead(mux_buttonPin[2]); //set mux2 input val for each digitalstate value digital_state3[count] = digitalRead(mux_buttonPin[3]); //set mux3 input val for each digitalstate value //Serial.println(digital_state0[count]); // print digital_state0 for debug //Serial.println(digital_state1[count]); // print digital_state1 for debug //Serial.println(digital_state2[count]); // print digital_state2 for debug //Serial.println(digital_state3[count]); // print digital_state3 for debug
buttonState0 = digital_state0[count]; buttonState1 = digital_state1[count]; buttonState2 = digital_state2[count]; buttonState3 = digital_state3[count]; //MUX0 if (buttonState0 != lastButtonState0) { // if the state has changed, increment the counter if (buttonState0 == HIGH) { // if the current state is HIGH then the button // wend from off to on: Serial.print("MUX0 button "); Serial.print(count); Serial.println(" pressed"); } else { // if the current state is LOW then the button // wend from on to off: Serial.print("MUX0 button "); Serial.print(count); Serial.println(" released"); } } // save the current state as the last state, //for next time through the loop lastButtonState0 = buttonState0; //MUX1 if (buttonState1 != lastButtonState1) { // if the state has changed, increment the counter if (buttonState1 == HIGH) { // if the current state is HIGH then the button // wend from off to on: Serial.print("MUX1 button "); Serial.print(count); Serial.println(" pressed"); } else { // if the current state is LOW then the button // wend from on to off: Serial.print("MUX1 button "); Serial.print(count); Serial.println(" released"); } } // save the current state as the last state, //for next time through the loop lastButtonState1 = buttonState1; //MUX2 if (buttonState2 != lastButtonState2) { // if the state has changed, increment the counter if (buttonState2 == HIGH) { // if the current state is HIGH then the button // wend from off to on: Serial.print("MUX2 button "); Serial.print(count); Serial.println(" pressed"); } else { // if the current state is LOW then the button // wend from on to off: Serial.print("MUX2 button "); Serial.print(count); Serial.println(" released"); } } // save the current state as the last state, //for next time through the loop lastButtonState2 = buttonState2;
//MUX3 if (buttonState3 != lastButtonState3) { // if the state has changed, increment the counter if (buttonState3 == HIGH) { // if the current state is HIGH then the button // wend from off to on: Serial.print("MUX3 button "); Serial.print(count); Serial.println(" pressed"); } else { // if the current state is LOW then the button // wend from on to off: Serial.print("MUX3 button "); Serial.print(count); Serial.println(" released"); } } // save the current state as the last state, //for next time through the loop lastButtonState3 = buttonState3; } delay (10); //delay 10 for read between values
here is the scimatics http://i48.tinypic.com/qsthms.jpgthank you in advance its driving me crazy i dont know were or how to implement the debounce
Queens, New York
"Of all the things I've ever lost, I miss my mind the most" -Ozzy Osbourne
« Reply #1 on: January 11, 2013, 01:29:44 pm » |
Do a search in the project guidance forum. Debounce multiple buttons/switches
UNO, MEGA, NANO, 4x4 keypad, micro servos, RF transceivers, bluetooth, ultrasonic sensor, 20x4 I2C LCD, 3.2 TFT touch screen, L298N Dual motor driver, Voice Recognition 15W
"If your doing nothing, it does not mean your lazy, it just means your open for anything that suits you" - Unknown
« Reply #2 on: January 11, 2013, 01:47:12 pm » |
i found this code will it work? const long debounceDelay = 20; //The button debounce time
// Button = pin number to read int checkButton(int Button) { int buttonState = digitalRead(Button); // Read button if (buttonState == HIGH) { // If button pressed then wait a bit to allow for debounce long Time = millis(); while ((millis() - Time) < debounceDelay) { } buttonState = digitalRead(Button); // Read button again return buttonState; // Return button state } else { return LOW; } }
Queens, New York
« Reply #3 on: January 11, 2013, 01:48:42 pm » |
It will for one button, but there is another code that does it for multiple buttons. http://arduino.cc/forum/index.php/topic,139805.0.html
« Reply #4 on: January 11, 2013, 02:07:29 pm » |
i was thinking i could just implement it in a loop for 4 times returning diffrent values like this but ill keep looking
Queens, New York
« Reply #5 on: January 11, 2013, 02:20:14 pm » |
The link I gave you, is from my understanding, is what you're looking for.
« Reply #6 on: January 11, 2013, 02:23:48 pm » |
sorry i didnt see the link before im trying to extract the debounceing part of his code is it more then just boolean debounce(int thisButton) { boolean current = digitalRead(swiPin[thisButton]); if (currentButtonVal[thisButton] != current) { delay(5); current = digitalRead(swiPin[thisButton]); } currentButtonVal[thisButton] = current; // store new state for your pin return current; }
« Reply #7 on: January 11, 2013, 02:28:58 pm » |
is this enough for it to function the debounce? int swiPin [] = { 5,6,7,8}; boolean currentButtonVal[3];
void setup(){ for(int x = 0; x<3; x++){ currentButtonVal[x] = true; } Serial.begin(9600); }
void loop(){
Serial.println(debounce(0)); Serial.println(debounce(1)); Serial.println(debounce(2)); Serial.println(debounce(3));
Queens, New York
« Reply #8 on: January 11, 2013, 02:34:13 pm » |
No, look at Nick Gammon's code on page 3, its a lot, but it works. And it has a test you can do too.
If you want, you can also take the debounce code in your Arduino examples, and convert it to use arrays and the use of a FOR loop.
« Last Edit: January 11, 2013, 02:43:07 pm by HazardsMind »
« Reply #9 on: January 11, 2013, 02:53:59 pm » |
origionally i tryed using the debouncing libary but i dont know if that would work heres the code with at #include <Debounce.h> int mux_buttonPin[4] = {5,6,7,8}; Debounce debouncer0 = Debounce( 20 , mux_buttonPin[0] ); Debounce debouncer1 = Debounce( 20 , mux_buttonPin[1] ); Debounce debouncer2 = Debounce( 20 , mux_buttonPin[2] ); Debounce debouncer3 = Debounce( 20 , mux_buttonPin[3] );
int row = 0; // storeing the bin code int count = 0; // just a count int bin [] = { 000, 1, 10, 11, 100, 101, 110, 111};//bin = binär, some times it is so easy void setup(){ for (int i=0; i<=7; i++) {
for (count=0; count<=7; count++) { row = bin[count]; r0 = row & 0x01; r1 = (row>>1) & 0x01; r2 = (row>>2) & 0x01; digitalWrite(2, r0); digitalWrite(3, r1); digitalWrite(4, r2); //Serial.println(bin[count]); //print current bin debouncer0.update(); // Update the debouncer debouncer1.update(); // Update the debouncer debouncer2.update(); // Update the debouncer debouncer3.update(); // Update the debouncer digital_state0[count] = digitalRead(debouncer0.read()); //set mux0 input val for each digitalstate value digital_state1[count] = digitalRead(debouncer1.read()); //set mux1 input val for each digitalstate value digital_state2[count] = digitalRead(debouncer2.read()); //set mux2 input val for each digitalstate value digital_state3[count] = digitalRead(debouncer3.read()); //set mux3 input val for each digitalstate value //Serial.println(digital_state0[count]); // print digital_state0 for debug //Serial.println(digital_state1[count]); // print digital_state1 for debug //Serial.println(digital_state2[count]); // print digital_state2 for debug //Serial.println(digital_state3[count]); // print digital_state3 for debug
Queens, New York
« Reply #10 on: January 11, 2013, 03:26:03 pm » |
Edit: Your code can be greatly simplified with the correct use of arrays, but try this. All I did was modify the example code. /* Debounce This example code is in the public domain. http://www.arduino.cc/en/Tutorial/Debounce */
// constants won't change. They're used here to // set pin numbers: const int buttonPin[] = {2,3,4,5}; const int ledPins[] = {8,9,10,11}; // the number of the LED pin
int MAX_PINS = 4; int i = 0; int counter=0; int reading[4];
//byte ledState = HIGH;
int buttonState[4]; // the current reading from the input pin int lastButtonState[] = {LOW,LOW,LOW,LOW}; // the previous reading from the input pin long lastDebounceTime[] = {0,0,0,0}; // the last time the output pin was toggled
long debounceDelay = 50; // the debounce time; increase if the output flickers
void setup() { for(i = 0; i <= MAX_PINS; i++){ pinMode(buttonPin[i], INPUT); pinMode(ledPins[i], OUTPUT); } }
void loop() { // read the state of the switch into a local variable: for(counter = 0; counter <= MAX_PINS; i++) { reading[counter] = digitalRead(buttonPin[counter]); if (reading[counter] != lastButtonState[counter]) { lastDebounceTime[counter] = millis(); }
if ((millis() - lastDebounceTime[counter]) > debounceDelay) { buttonState[counter] = reading[counter]; }
digitalWrite(ledPins[counter], buttonState[counter]); lastButtonState[counter] = reading[counter]; } }
« Last Edit: January 11, 2013, 03:46:32 pm by HazardsMind »
« Reply #11 on: January 11, 2013, 04:32:15 pm » |
the counter value never goes any higher then 0 in that example?
« Reply #12 on: January 11, 2013, 04:59:33 pm » |
alright im almost there heres what i have // constants won't change. They're used here to // set pin numbers: const int mux_buttonPin[] = {5,6,7,8};
int MAX_PINS = sizeof(mux_buttonPin)/2-1; int counter=0; int reading[sizeof(mux_buttonPin)-1]; int buttonState[sizeof(mux_buttonPin-1)]; // the current reading from the input pin int lastButtonState[] = {LOW,LOW,LOW,LOW}; // the previous reading from the input pin long lastDebounceTime[] = {0,0,0,0}; // the last time the output pin was toggled long debounceDelay = 50; // the debounce time; increase if the output flickers
void setup(){ for(int i = 0; i <= MAX_PINS; i++){ pinMode(mux_buttonPin[i], INPUT);// mux read pin } for (int i=0; i<=7; i++) {
for (count=0; count<=7; count++) { row = bin[count]; r0 = row & 0x01; r1 = (row>>1) & 0x01; r2 = (row>>2) & 0x01; digitalWrite(2, r0); digitalWrite(3, r1); digitalWrite(4, r2); //Serial.println(bin[count]); //print current bin digital_state0[count] = digitalRead(mux_buttonPin[0]); //set mux0 input val for each digitalstate value digital_state1[count] = digitalRead(mux_buttonPin[1]); //set mux1 input val for each digitalstate value digital_state2[count] = digitalRead(mux_buttonPin[2]); //set mux2 input val for each digitalstate value digital_state3[count] = digitalRead(mux_buttonPin[3]); //set mux3 input val for each digitalstate value // read the state of the switch into a local variable: for(int counter = 0; counter <= MAX_PINS; counter++) { reading[counter] = digitalRead(mux_buttonPin[counter]); if (reading[counter] != lastButtonState[counter]) { lastDebounceTime[counter] = millis(); }
if ((millis() - lastDebounceTime[counter]) > debounceDelay) { buttonState[counter] = reading[counter]; } // Serial.println(counter); Serial.println(buttonState[counter]); lastButtonState[counter] = reading[counter]; } //Serial.println(digital_state0[count]); // print digital_state0 for debug //Serial.println(digital_state1[count]); // print digital_state1 for debug //Serial.println(digital_state2[count]); // print digital_state2 for debug //Serial.println(digital_state3[count]); // print digital_state3 for debug
heres the part that confused me digital_state0[count] = digitalRead(mux_buttonPin[0]); //set mux0 input val for each digitalstate value digital_state1[count] = digitalRead(mux_buttonPin[1]); //set mux1 input val for each digitalstate value digital_state2[count] = digitalRead(mux_buttonPin[2]); //set mux2 input val for each digitalstate value digital_state3[count] = digitalRead(mux_buttonPin[3]); //set mux3 input val for each digitalstate value // read the state of the switch into a local variable: for(int counter = 0; counter <= MAX_PINS; counter++) { reading[counter] = digitalRead(mux_buttonPin[counter]); if (reading[counter] != lastButtonState[counter]) { lastDebounceTime[counter] = millis(); }
Queens, New York
« Reply #13 on: January 11, 2013, 06:42:20 pm » |
I made an error in my code, it was this "for(counter = 0; counter <= MAX_PINS; i++)" But change it to "for(counter = 0; counter <= MAX_PINS; counter++)" It works with multiple buttons, I just tried it and it works perfectly. EDIT. Also, digital_state0[count] = digitalRead(mux_buttonPin[0]); //set mux0 input val for each digitalstate value digital_state1[count] = digitalRead(mux_buttonPin[1]); //set mux1 input val for each digitalstate value digital_state2[count] = digitalRead(mux_buttonPin[2]); //set mux2 input val for each digitalstate value digital_state3[count] = digitalRead(mux_buttonPin[3]); //set mux3 input val for each digitalstate value Isn't any different from "reading[counter] = digitalRead(mux_buttonPin[counter]);"
« Last Edit: January 11, 2013, 07:04:08 pm by HazardsMind »
