Author Topic: need help adding debounce to my code  (Read 229 times)
hello all i need  help adding a debounce to this part of my code
        digital_state0[count] = digitalRead(mux_buttonPin[0]); //set mux0 input val for each digitalstate value
        digital_state1[count] = digitalRead(mux_buttonPin[1]); //set mux1 input val for each digitalstate value
        digital_state2[count] = digitalRead(mux_buttonPin[2]); //set mux2 input val for each digitalstate value
        digital_state3[count] = digitalRead(mux_buttonPin[3]); //set mux3 input val for each digitalstate value
here is the full code of the program
int mux_buttonPin[4] = {5,6,7,8};
int buttonState0 = LOW;
int lastButtonState0 = LOW;
int buttonState1 = LOW;
int lastButtonState1 = LOW;
int buttonState2 = LOW;
int lastButtonState2 = LOW;
int buttonState3 = LOW;
int lastButtonState3 = LOW;
int  digital_state0 [7]  = {
  LOW};//set aside input values for mux
int  digital_state1 [7]  = {
int  digital_state2 [7]  = {
int  digital_state3 [7]  = {
int r0 = 0;      //value select pin at the 4051 (s0)
int r1 = 0;      //value select pin at the 4051 (s1)
int r2 = 0;      //value select pin at the 4051 (s2)
int row = 0;     // storeing the bin code
int count = 0;    // just a count
int  bin [] = {
  000, 1, 10, 11, 100, 101, 110, 111};//bin = binär, some times it is so easy
void setup(){
  for (int i=0; i<=7; i++) {
    pinMode(digital_state0[i], INPUT); //mux0 inputs
    pinMode(digital_state1[i], INPUT); //mux1 inputs
    pinMode(digital_state2[i], INPUT); //mux2 inputs
    pinMode(digital_state3[i], INPUT); //mux3 inputs
  pinMode(2, OUTPUT);    // s0
  pinMode(3, OUTPUT);    // s1
  pinMode(4, OUTPUT);    // s2
  pinMode(mux_buttonPin[0], INPUT);     // mux0 read pin //digital
pinMode(mux_buttonPin[1], INPUT);     // mux1 read pin //digital
pinMode(mux_buttonPin[2], INPUT);     // mux2 read pin //digital
pinMode(mux_buttonPin[3], INPUT);     // mux3 read pin //digital
void loop () {
  for (count=0; count<=7; count++) {
    row = bin[count];
    r0 = row & 0x01;
    r1 = (row>>1) & 0x01;
    r2 = (row>>2) & 0x01;
    digitalWrite(2, r0);
    digitalWrite(3, r1);
    digitalWrite(4, r2);
    //Serial.println(bin[count]); //print current bin
    //Serial.println(digital_state0[count]); // print digital_state0 for debug
  //Serial.println(digital_state1[count]); // print digital_state1 for debug
  //Serial.println(digital_state2[count]); // print digital_state2 for debug
  //Serial.println(digital_state3[count]); // print digital_state3 for debug
    buttonState0 = digital_state0[count];
    buttonState1 = digital_state1[count];
    buttonState2 = digital_state2[count];
    buttonState3 = digital_state3[count];
    //MUX0
    if (buttonState0 != lastButtonState0) {
      // if the state has changed, increment the counter
      if (buttonState0 == HIGH) {
        // if the current state is HIGH then the button
        // wend from off to on:
        Serial.print("MUX0 button ");
        Serial.print(count);
        Serial.println(" pressed");
      else {
        // if the current state is LOW then the button
        // wend from on to off:
        Serial.println(" released");
    // save the current state as the last state,
    //for next time through the loop
    lastButtonState0 = buttonState0;
     //MUX1
    if (buttonState1 != lastButtonState1) {
      if (buttonState1 == HIGH) {
        Serial.print("MUX1 button ");
      else {
    lastButtonState1 = buttonState1;
 //MUX2
    if (buttonState2 != lastButtonState2) {
      if (buttonState2 == HIGH) {
        Serial.print("MUX2 button ");
      else {
    lastButtonState2 = buttonState2;
//MUX3
    if (buttonState3 != lastButtonState3) {
      if (buttonState3 == HIGH) {
        Serial.print("MUX3 button ");
      else {
    lastButtonState3 = buttonState3;
  delay (10);  //delay 10 for read between values
here is the scimatics
http://i48.tinypic.com/qsthms.jpg
thank you in advance its driving me crazy i dont know were or how to implement the debounce
Queens, New York
Online Online
"Of all the things I've ever lost, I miss my mind the most" -Ozzy Osbourne
Do a search in the project guidance forum. Debounce multiple buttons/switches
UNO, MEGA, NANO, 4x4 keypad, micro servos, RF transceivers, bluetooth, ultrasonic sensor, 20x4 I2C LCD, 3.2 TFT touch screen, L298N Dual motor driver, Voice Recognition 15W, Gameduino
Arduino Tutorials, coming soon.
"If your doing nothing, it does not mean your lazy, it just means your open for anything that suits you" - Unknown
i found this code will it work?
const long debounceDelay = 20; //The button debounce time
// Button = pin number to read
int checkButton(int Button) {
  int buttonState = digitalRead(Button);    // Read button
  if (buttonState == HIGH) {                // If button pressed then wait a bit to allow for debounce
    long Time = millis();
    while ((millis() - Time) < debounceDelay) {
    buttonState = digitalRead(Button);      // Read button again
    return buttonState;                     // Return button state
  else {
    return LOW;
Queens, New York
Online Online
It will for one button, but there is another code that does it for multiple buttons.
http://arduino.cc/forum/index.php/topic,139805.0.html
i was thinking i could just implement it in a loop for 4 times returning diffrent values like this but ill keep looking
Queens, New York
Online Online
The link I gave you, is from my understanding, is what you're looking for.
sorry i didnt see the link before im trying to extract the debounceing part of his code is it more then just
boolean debounce(int thisButton) {
  boolean current = digitalRead(swiPin[thisButton]);
  if (currentButtonVal[thisButton] != current) {
    delay(5);
  currentButtonVal[thisButton] = current;  // store new state for your pin
  return current;
is this enough for it to function the debounce?
int swiPin [] = {
  5,6,7,8};
boolean currentButtonVal[3];
void setup(){
  for(int x = 0; x<3; x++){
    currentButtonVal[x] = true;
    delay(5);
  return current;
void loop(){
  Serial.println(debounce(0));
  Serial.println(debounce(1));
  Serial.println(debounce(2));
  Serial.println(debounce(3));
Queens, New York
Online Online
No, look at Nick Gammon's code on page 3, its a lot, but it works. And it has a test you can do too.
If you want, you can also take the debounce code in your Arduino examples, and convert it to use arrays and the use of a FOR loop.
« Last Edit: January 11, 2013, 02:43:07 pm by HazardsMind » Logged
origionally i tryed using the debouncing libary but i dont know if that would work heres the code with at
#include <Debounce.h>
Debounce debouncer0 = Debounce( 20 , mux_buttonPin[0] );
Debounce debouncer1 = Debounce( 20 , mux_buttonPin[1] );
Debounce debouncer2 = Debounce( 20 , mux_buttonPin[2] );
Debounce debouncer3 = Debounce( 20 , mux_buttonPin[3] );
int  bin [] = {
void setup(){
void loop () {
    row = bin[count];
    r0 = row & 0x01;
    debouncer0.update(); // Update the debouncer
    debouncer1.update(); // Update the debouncer
    debouncer2.update(); // Update the debouncer
    debouncer3.update(); // Update the debouncer
        digital_state0[count] = digitalRead(debouncer0.read()); //set mux0 input val for each digitalstate value
        digital_state1[count] = digitalRead(debouncer1.read()); //set mux1 input val for each digitalstate value
        digital_state2[count] = digitalRead(debouncer2.read()); //set mux2 input val for each digitalstate value
        digital_state3[count] = digitalRead(debouncer3.read()); //set mux3 input val for each digitalstate value
    //MUX0
      else {
     //MUX1
      else {
 //MUX2
      else {
//MUX3
      else {
Queens, New York
Online Online
Edit: Your code can be greatly simplified with the correct use of arrays, but try this. All I did was modify the example code.
 Debounce
 This example code is in the public domain.
 http://www.arduino.cc/en/Tutorial/Debounce
// constants won't change. They're used here to
// set pin numbers:
const int buttonPin[] = {2,3,4,5};
const int ledPins[] =  {8,9,10,11};      // the number of the LED pin
int MAX_PINS = 4;
int i = 0;
int counter=0;
int reading[4];
//byte ledState = HIGH;
int buttonState[4];             // the current reading from the input pin
int lastButtonState[] = {LOW,LOW,LOW,LOW};   // the previous reading from the input pin
long lastDebounceTime[] = {0,0,0,0};  // the last time the output pin was toggled
long debounceDelay = 50;    // the debounce time; increase if the output flickers
  for(i = 0; i <= MAX_PINS; i++){
    pinMode(buttonPin[i], INPUT);
    pinMode(ledPins[i], OUTPUT);
  // read the state of the switch into a local variable:
  for(counter = 0; counter <= MAX_PINS; i++)
    reading[counter] = digitalRead(buttonPin[counter]);
    if (reading[counter] != lastButtonState[counter]) {
    lastDebounceTime[counter] = millis();
    if ((millis() - lastDebounceTime[counter]) > debounceDelay) {
      buttonState[counter] = reading[counter];
    digitalWrite(ledPins[counter], buttonState[counter]);
    lastButtonState[counter] = reading[counter];
« Last Edit: January 11, 2013, 03:46:32 pm by HazardsMind » Logged
the counter value never goes any higher then 0 in that example?
alright im almost there heres what i have
// set pin numbers:
const int mux_buttonPin[] = {5,6,7,8};
int MAX_PINS = sizeof(mux_buttonPin)/2-1;
int counter=0;
int reading[sizeof(mux_buttonPin)-1];
int buttonState[sizeof(mux_buttonPin-1)];             // the current reading from the input pin
int  bin [] = {
void setup(){
   for(int i = 0; i <= MAX_PINS; i++){
    pinMode(mux_buttonPin[i], INPUT);// mux read pin
void loop () {
    row = bin[count];
    r0 = row & 0x01;
  for(int counter = 0; counter <= MAX_PINS; counter++)
    reading[counter] = digitalRead(mux_buttonPin[counter]);
// Serial.println(counter);
    Serial.println(buttonState[counter]);
    //MUX0
      else {
     //MUX1
      else {
 //MUX2
      else {
//MUX3
      else {
heres the part that confused me
Queens, New York
Online Online
I made an error in my code, it was this "for(counter = 0; counter <= MAX_PINS; i++)" But change it to "for(counter = 0; counter <= MAX_PINS; counter++)"
It works with multiple buttons, I just tried it and it works perfectly.
EDIT.
Also,
Isn't any different from "reading[counter] = digitalRead(mux_buttonPin[counter]);"
« Last Edit: January 11, 2013, 07:04:08 pm by HazardsMind » Logged
