Loading...
Pages: [1] 2   Go Down
Author Topic: Complier window saying "expected primary-expression before ')' token"  (Read 645 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
I receive via my etherent board data, I am trying to send that data back out to a local server.
But although I can print it out, I cannot send it, I think its because pointers are involved,
If it helps I am using Arduino MQTT, although I don't think it matters as to my problem.
Please see API info at the end of this.
I get  an error in the Arduino complier window saying "expected primary-expression before ')' token"
Hopefully you can help as I have tried for hours and still have no clue what is wrong?
regards
Gary
Code:
void callback(char* topic, byte* payload, unsigned int length)                                // Data that has been received from server.
        payload[length] = '\0';        // Add a 'null' to the payload.
        strPayload = String((char*)payload);                                                              // strPayload now holds the contents of the memory pointed to by payload
void Send_data_back_to_MQTT(void)
client.publish("sensor/001/mqtt_server_in", strPayload); // Fail =  "expected primary-expression before ')' token"
Serial.print(strPayload); // Prints OK
In the API of MQTT these are the options of how to return data:
boolean publish (topic, payload)
Publishes a string message to the specified topic.
The payload must be a null-terminated string. The message is published at QoS 0 with the retain flag set to false.
Parameters
    topic – the topic to publish to (char*)
    payload – the message to publish (char*)
Returns
    false – publish failed.
    true – publish succeeded.
boolean publish (topic, payload, length)
Publishes a message to the specified topic.
Parameters
    payload – the message to publish (byte array)
    length – the length of the message (byte)
Returns
Logged
Temple, Texas
Offline Offline
Sr. Member
View Profile
We may need to see your entire sketch...
Why aren't you just using payload-- what's the additional purpose/benefit of strPayload?
John
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
You seem to have { to start the function and ) to end the function - they need to match
Code:
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
0
Offline Offline
Newbie
Arduino rocks
View Profile
I have included some more of the code but the whole code is in 8 tabs in the IDE, so cannot paste all of it here.
The reason I want to send that data out in a seperate routine to the original code.
Is that the original code works correctly but is only fired when it receives data from the MQTT server and this could be seconds hours or days before an update happens.
I need to update a webpage every 1 minute as to the latest setting.
Hope that helps.
Regards
Gary
Code:
void callback(char* topic, byte* payload, unsigned int length)                              // Check the Data that has been received from MQTT server.
        Serial.println("");
        Serial.print("Payload = ");
         strPayload = String((char*)payload);                                                 // strPayload now holds the contents of the memory pointed to by payload.
        // Use  strPayload  for comparison below
       if   (strPayload == "Set to 5.0")
              Serial.print(" .... Set Temp To 05.0");
              target_temperature = 05;
     client.publish("sensor/001/mqtt_server_in", payload, length);                          // **** ORIGINAL THIS WORKS Send to MQTT server ****
      client.publish("sensor/001/mqtt_server_in", strPayload);      // On attempt to compile in IDE ,get complier window saying "expected primary-expression before ')' token"
Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
I'd go with the non-matching braces hypothesis.
Looks pretty clear to me.
Certainly the best bet in the absence of code.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
0
Offline Offline
Newbie
Arduino rocks
View Profile
Sorry the braces were just a typo when adding it on here, in the real code its correct.
Regards
Gary
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
How does cut and paste add a typo?
Logged
UK
Offline Offline
Tesla Member
View Profile
So post the real code that causes the error.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
See my reply #3
If theres not anything obvious there I will add more tomorrow , its just the code is about 200 lines and spread over 8 tab pages.
Thanks
Regards
Gary
Logged
Temple, Texas
Offline Offline
Sr. Member
View Profile
Regards
Gary
Be that as it may, a paren instead of curly brace will cause exactly the error message you posted.  Though in a different place
Good Luck,
John
Logged
UK
Offline Offline
Tesla Member
View Profile
See my reply #3
The code in reply #3 obviously will not compile, because it is incomplete.
Please stop trying to be cute about which bits of code you post, and show the entire file that causes the compilation error, in its entirety, exactly as it was when you tried to compile it. Please post the complete output from the compiler too.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Thanks for your patience, I have thought about how best to demonstrate what I am trying to achieve
and its actually best to show you the original file I downloaded fron the net.
It requires a lib and I have attached this. Also in the second piece of code shows you what I have added.
The purpose of my changes are to update a MQTT server with latest data every 15 seconds
As the original would only update on a received message. which may be seconds or hours away.
Obviously there is a definite fault and its different to the title of this thread.
But it is caused by what I am trying to achieve, it uses pointers and I have
never worked with them. And i do not know how to declare them satifactorly for this to compile.
The errors given are as follows:
Test_MQTT_V1_0.cpp: In function 'void update()':
Test_MQTT_V1_0:35: error: 'payload' was not declared in this scope
Test_MQTT_V1_0:35: error: 'length' was not declared in this scope
Code:
Original code:
 Publishing in the callback
  - connects to an MQTT server
  - subscribes to the topic "inTopic"
  - when a message is received, republishes it to "outTopic"
  This example shows how to publish messages within the
  callback function. The callback function header needs to
  be declared before the PubSubClient constructor and the
  actual callback defined afterwards.
  This ensures the client reference in the callback function
  is valid.
#include <SPI.h>
#include <Ethernet.h>
#include <PubSubClient.h>
// Update these with values suitable for your network.
byte mac[]    = {  0xDE, 0xED, 0xBA, 0xFE, 0xFE, 0xED };
byte server[] = { 172, 16, 0, 2 };
byte ip[]     = { 172, 16, 0, 100 };
// Callback function header
void callback(char* topic, byte* payload, unsigned int length);
EthernetClient ethClient;
PubSubClient client(server, 1883, callback, ethClient);
void callback(char* topic, byte* payload, unsigned int length) {
  client.publish("outTopic", payload, length);
  Ethernet.begin(mac, ip);
  if (client.connect("arduinoClient")) {
    client.publish("outTopic","hello world");
    client.subscribe("inTopic");
  client.loop();
Code:
My addition to original code:
#include <SPI.h>
// Callback function = only received at random intervals could be seconds hours or days.
void update()
  client.loop();
  delay (15000);
  update();       // Update after 15 seconds
Logged
UK
Offline Offline
Tesla Member
View Profile
The error is in this function:
Code:
void update()
It looks as if it is based on this function:
Code:
In the original, the payload and length are being passed in by the PubSubClient, presumably obtained from an incoming message.
Now that you're publishing messages spontaneously you will need to decide what payload you're going to send. I'm not sure what 'latest data' means. You could either remember the last incoming payload (by saving it in a global variable) and keep sending that, or get the payload from some other source. But you need to provide the payload somehow. Here is my guess at how you'd use a hard-coded constant payload containing an ASCII string:
Code:
// incomplete, uncompiled, untested
void update()
  byte *payload = "my payload";
  int length = strlen(payload);
  client.publish("outTopic", payload , length);
« Last Edit: January 12, 2013, 07:55:40 am by PeterH » Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Hi PeterH,
Thanks for tyhe reply, tried your code and now it comes up with:
Test_MQTT_V1_0:36: error: invalid conversion from 'const char*' to 'byte*'
Test_MQTT_V1_0:37: error: invalid conversion from 'byte*' to 'const char*'
Test_MQTT_V1_0:37: error: initializing argument 1 of 'size_t strlen(const char*)'
Quote
Yes the latest data is sent from a server when it has new data.
I think although I may be wrong, 'payload' remains in memory until it receives a new update.
Thanks so far
regards
Gary
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
We need to see HOW you integrated that snippet in YOUR code yo determine what YOU did wrong. Most likely, all that is needed is some casting.
Logged
Pages: [1] 2   Go Up
Print
Jump to:
