Topic: guitar frequencies (Read 9506 times) previous topic - next topic
PaulS
obs: is that line 87 of the frequency library - ?
I like AWOL's analogy.
My car wouldn't start this morning. It's the white one. Can you tell me what is wrong?
You didn't show any code. You didn't post any error messages. You simply expected us to help you fix them.
Ducaqabe
sorry PaulS
you are  right, what I want to try is to re-use  the frequency counter library code/ the code on this public domain link:http://www.pjrc.com/teensy/td_libs_FreqCount.html#compare
because I think, it is relevant my project after modifying,. I compliled the code, there is always error like this one
thanks
the code is
// Frequency Counter Lib example
  Martin Nawrath KHM LAB3
  Kunsthochschule f¸r Medien Kˆln
  Academy of Media Arts
  http://www.khm.de
  http://interface.khm.de/index.php/labor/experimente/
#include <FreqCounter.h>
unsigned long frq;
int cnt;
int pinLed=13;
  pinMode(pinLed, OUTPUT);
  Serial.begin(115200);        // connect to the serial port
  Serial.println("Frequency Counter");
  // wait if any serial is going on
  FreqCounter::f_comp=10;   // Cal Value / Calibrate with professional Freq Counter
  FreqCounter::start(100);  // 100 ms Gate Time
  while (FreqCounter::f_ready == 0)
  frq=FreqCounter::f_freq;
  Serial.print(cnt++);
  Serial.print("  Freq: ");
  Serial.println(frq);
  delay(20);
  digitalWrite(pinLed,!digitalRead(pinLed));  // blink Led
header file
  FreqCounter.h - Library for a Frequency Counter c.
  Created by Martin Nawrath, KHM Lab3, Dec. 2008
  Released into the public domain.
#ifndef FreqCounter_h
#define FreqCounter_h
#include <avr/interrupt.h>
#if defined(ARDUINO) && ARDUINO >= 100
#include "Arduino.h"
#else
#include "WProgram.h"
#endif
namespace FreqCounter {
extern unsigned long f_freq;
extern volatile unsigned char f_ready;
extern volatile unsigned char f_mlt;
extern volatile unsigned int f_tics;
extern volatile unsigned int f_period;
extern volatile unsigned int f_comp;
void start(int ms);
#endif
PaulS
There is a difference between
and
#include "FreqCounter.h"
The difference is where the compiler looks for include files. If one doesn't work, because you have not installed the library as a library, try the other one.
Ducaqabe
Thanks  PoulS
now I changed header file from  #include <FreqCounter.h> to
I can see that was a part of the compile error, but still the compile problem not disappear,
new one is her: on the piture
how to install the library as library ?, sorry my novice questions?
thanks again
GoForSmoke
The issue with a pickup is that unless the rest of the strings are muted they will resonate too the absolute difference between any consecutive two notes is the 12th root  of 2 or 1.059463... (20 more places).
Bob
Sure, you won't get a perfectly clean sine wave. A pickup will also get effect from the guitar body sound box. Yet somehow an A sounds like an A, those resonances add a little tone is all.
You want just the string, do like Les Paul did and get a piece of train track.. or a hardwood 4x4. But then it's not an acoustic guitar.
Nick Gammon on multitasking Arduinos:
1) http://gammon.com.au/blink
2) http://gammon.com.au/serial
Ducaqabe
thanks
I installed the library "frequency Library" and it complied well,
thank you PoulS and other guys in thread :)
Ducaqabe
HI,
is there any help about this thread,http://arduino.cc/forum/index.php/topic,142209.msg1075998.html#msg1075998 , still I coun't figur out , calculating the frequency of guitar strings???? any hints ?
thanks
GoForSmoke
Are you trying to visualize the data or calculate the frequency?
You know that the string plucked will be the loudest part of the sound by far?
And that loudest sound is highest amplitude at the peaks?
So if you feed the signal through a resistor of high enough value to the grid of an NPN transistor, only the peaks will turn that on. Blip, blip, blip, count the blips per second and you have what?
Ducaqabe
Hi  GoForSmoke
I just want to visualize the string frequency(guitar string) on LCD.
PaulS
You've got some code you haven't showed us.
You've using some hardware to get the vibration information that you haven't told us about,
My car still won't start. The seats are leather. Does that help?
Ducaqabe
#25
Jan 19, 2013, 07:00 pm Last Edit: Jan 19, 2013, 07:05 pm by Ducaqabe Reason: 1
Hi PaulS
thanks for help, may be  "a strang car again" sorry, I am new for using farum.
the hardware I am using, I explained before here: http://arduino.cc/forum/index.php/topic,142209.msg1075998.html#msg1075998
I get some code from this  public domain: http://www.tonychai.com/guitar.html wrote by Tony Chai
I don,t need to to use servo or tuning peg, indstead I am using electromegnet and coils to vibrate the string, just visualizing frequency. my vibration hardware circuit I put here
here is the code
* Magic_Tune
* This program will receive an amplified analog signal, compare the pitch, and control the servo motor while displaying output LEDs
//Libraries required for servo control and usage of the Atmega's internal timer
#include
//Global variables to be used
int x;
int y;
int lastx;
int lasty;
long timer;
int idle_timer;
int threshold;
int cross_count;
int in_tune;
int average_val;
int pitch_diff;
int upper_bound;
int lower_bound;
int avg_cross;
int avg_counter;
int avg_upper;
int avg_lower;
float a, b;
int timer_divide;
int divide_by;
int string_select;
int select_pin_val;
int analogPin = 0; // analog to digital pin for signal input
int led_high = 13; // this LED will show user if a string's pitch is too high
int led_ok = 12; // this LED will show user if a string's pitch is correct
int led_low = 11; // this LED will show user if a string's pitch is too low
// these pins will light up to show which string the Atmega is comparing values for
int led_e4 = 10;
int led_b3 = 9;
int led_g3 = 8;
int led_d3 = 7;
int led_a2 = 6;
int led_e2 = 5;
int button_pin = 3; // input pin for user using a button to switch strings
int servoPin = 2; // control pin for servo motor
// Set up timer 1 to generate an interrupt every 1 microsecond
TCCR1A = 0x00;
TCCR1B = (_BV(WGM12) | _BV(CS12));
OCR1A = .071;
TIMSK1 = _BV(OCIE1A);
x = 0;
lastx = 0;
y = 0;
lasty = 0;
timer = 0;
cross_count = 0;
avg_cross = 0;
avg_counter = 0;
string_select = 0;
//Set the input and output pins
pinMode(button_pin, INPUT);
pinMode(servoPin, OUTPUT);
pinMode(led_high, OUTPUT);
pinMode(led_ok, OUTPUT);
pinMode(led_low, OUTPUT);
pinMode(led_e4, OUTPUT);
pinMode(led_b3, OUTPUT);
pinMode(led_g3, OUTPUT);
pinMode(led_d3, OUTPUT);
pinMode(led_a2, OUTPUT);
pinMode(led_e2, OUTPUT);
Serial.begin(9600); // Opens serial port, sets data rate to 9600 bps
// Nothing is done in the Arduino loop, since timing is off.
// Timer function running every microsecond
ISR(TIMER1_COMPA_vect)
timer++;
idle_timer++;
// Read button press to determine which string is to be detected
if (timer % 100 == 0)
select_pin_val = digitalRead(button_pin);
if (select_pin_val == HIGH)
string_select = ((string_select + 1) % 6);
Serial.print("string: ");
Serial.println(string_select);
// Depending on which string is selected, the proper variables are set
switch (string_select)
case 0:
digitalWrite(led_e4, LOW); // sets the proper LED on, all else off
digitalWrite(led_b3, LOW);
digitalWrite(led_g3, LOW);
digitalWrite(led_d3, LOW);
digitalWrite(led_a2, LOW);
digitalWrite(led_e2, HIGH);
a = 0.045;
b = 0.9099;
threshold = 150;
upper_bound = 77;
lower_bound = 33;
avg_upper = 57;
in_tune = 55; // This is the "in tune" average of cross counts for the string.
avg_lower = 53;
timer_divide= 2000;
divide_by = 3;
break;
case 1:
digitalWrite(led_a2, HIGH);
digitalWrite(led_e2, LOW);
a = 0.0592;
b = 0.8816;
threshold = 150;
upper_bound = 88;
lower_bound = 44;
avg_upper = 67;
in_tune = 65; // This is the "in tune" average of cross counts for the string.
avg_lower = 63;
timer_divide = 2000;
divide_by = 3;
break;
case 2:
digitalWrite(led_d3, HIGH);
a = 0.0797;
b = 0.8406;
threshold = 150;
upper_bound = 117;
lower_bound = 63;
avg_upper = 97;
in_tune = 95; // This is the "in tune" average of cross counts for the string.
avg_lower = 93;
divide_by = 3;
break;
 I have to divede the code two parts because I cant put here all- the next is ather part of the code-
see the circuit image
Ducaqabe
the code continued here
case 3:
digitalWrite(led_g3, HIGH);
a = 0.0730;
b = 0.8541;
threshold = 130;
upper_bound = 50;
lower_bound = 15;
avg_upper = 29;
in_tune = 27; // This is the "in tune" average of cross counts for the string.
avg_lower = 26;
timer_divide = 500;
divide_by = 4;
break;
case 4:
digitalWrite(led_b3, HIGH);
a = 0.1270;
b = 0.7459;
threshold = 140;
upper_bound = 50;
lower_bound = 15;
avg_upper = 35;
in_tune = 34; // This is the "in tune" average of cross counts for the string.
avg_lower = 33;
timer_divide = 500;
divide_by = 4;
break;
case 5:
digitalWrite(led_e4, HIGH); // sets the proper LED on, all else off
a = 0.1648;
b = 0.6705;
threshold = 150;
upper_bound = 60;
lower_bound = 20;
avg_upper = 47;
in_tune = 45; // This is the "in tune" average of cross counts for the string.
avg_lower = 43;
timer_divide = 500;
divide_by = 4;
break;
check_crossings();
// After the string input has been idle for a while, we take the average of a number of cross counts that were in bound.
if (idle_timer == 10000)
Serial.println("AVG AVG LOOK HERE AVG AVG");
average_val = avg_cross / divide_by;
Serial.println(average_val);
// If else statements for tuner lights
if ((average_val < avg_lower) && (average_val > 0))
// Turn off all string display lights to conserve power
// Sets the proper tuning LED on, all else off
digitalWrite(led_high, LOW);
digitalWrite(led_ok, LOW);
digitalWrite(led_low, HIGH);
pitch_diff = in_tune - average_val;
Serial.print("Pitch Difference Low: ");
Serial.println(pitch_diff);
// If the tuning is off by a questionably high amount, count it as an error in reading and do not turn the peg.
// Otherwise tune the peg for a period of time. This time depends on how far off the read average is.
if (pitch_diff < 20)
for(long i = 0; i < pitch_diff * 36000; i++)
digitalWrite(servoPin, HIGH); // start the pulse
delayMicroseconds(15); // pulse width
digitalWrite(servoPin, LOW); // stop the pulse
// Don't turn the peg if the guitar is in tune.
else if ((average_val >= avg_lower && average_val <= avg_upper) || (average_val == 0))
digitalWrite(led_ok, HIGH);
digitalWrite(led_low, LOW);
else if (average_val > avg_upper)
digitalWrite(led_high, HIGH);
pitch_diff = average_val - in_tune;
Serial.print("Pitch Difference High: ");
for(long i = 0; i < pitch_diff * 270000; i++)
delayMicroseconds(2); // pulse width
// Reset all variables used for pitch detection
cross_count = 0;
avg_cross = 0;
avg_counter = 0;
// We take the average of cross counts after the first value in bound. We dismiss the first value since it is usually inaccurate
// for finding a good average.
if (timer % timer_divide == 0){
if (cross_count > lower_bound && cross_count < upper_bound) {
if (avg_counter >= 1 && avg_counter < (divide_by + 1)) {
avg_cross = avg_cross + cross_count;
Serial.print("Runnin Avg cross sum: ");
Serial.println(avg_cross);
avg_counter++;
Serial.print("cross_count: ");
Serial.println(cross_count);
cross_count = 0;
void check_crossings()
lastx = x;
lasty = y;
x = analogRead(analogPin); // Read the input pin
y = a * x + a * lastx + b * lasty; // Apply Butterworth filter to eliminate high frequencies
// If the string crosses it's set threshold, add it to the count. If there are no crossings, the idle timer will begin to run.
if (lasty > threshold and y < threshold)
cross_count++;
idle_timer = 0;
PaulS
OCR1A = .071;
Are you sure that you can do this? From what I've read, it looks like OCR1A needs to be a non-zero, integer value.
In an ISR? No.
That code does something. You want it to do something. What either of those somethings is is not clear.
My car has mag wheels. Why won't it start?
el_supremo
That code claims to start Timer1 interrupting every microsecond and then has an ISR routine that:
- can't possibly execute in less than a microsecond
- calls Serial.print (as PaulS has pointed out)
- calls delayMicroseconds(15) inside a loop that is executed a minimum of 36000 times and (if that's not enough silliness) it also calls delayMicroseconds(2) in a loop that executes a minimum of 270000 times.
It therefore can't possibly be sampling the audio at a consistent rate which would permit it to detect an audio tone (even if the code's detection method could actually work in the first place).
Pete
Don't send me technical questions via Private Message.
