Topic: NRI G.13 - Drinks machine (Read 2809 times) previous topic - next topic
DieterKoblenz
Jan 11, 2013, 11:04 pm Last Edit: Jan 11, 2013, 11:12 pm by AWOL Reason: 1
Hey Arduinousers,
We have an old can machine which uses a NRI G13.6000 (flat cable ribbon serial) as a coin acceptor. Now I need to trick the machines relays board to think that a payment has been made.
The NRI has several output channels, but the one I need (channel 8) sends out a pulse to the board. I need to emulate that Pulse with the push of a button.
This is the description of the output channel of the NRI:
NPN 100ms 10mA active low w/ 47K pull-up to +5V
Is there anyone who knows how to pull this off?
Moderator edit: Smiley removed
larryd
Do you want to learn to do it or do you want us to do it?
No technical PMs.
The last thing you did is where you should start looking.
DieterKoblenz
Well even though it would be easier if someone did it, for me it would be better to learn it.
I've come up with this code:
  pinMode(10, OUTPUT);   // PWM output right
   analogWrite(10, 56);  // 56=111Hz ??
AWOL
// 56=111Hz
I don't really understand that.
PWM frequency is around 490Hz.
There's no need to set the pinMode for an analogWrite
DieterKoblenz
Yes and PWN is set between 0 and 255 right?
Zo 111Hz would be 56 value?
AWOL
No, PWM frequency is fixed, you vary the duty cycle (mark:space ratio) with the parameter to analogWrite
DieterKoblenz
Yep, but haven't I done that by giving analogWrite 56?
AWOL
#7
Jan 11, 2013, 11:46 pm Last Edit: Jan 11, 2013, 11:56 pm by AWOL Reason: 1
You have varied the duty cycle, but the frequency remains the same, namely 490 Hz.
I don't see the significance of this 111Hz from what you've said so far.
Edit.
In case you don't understand the difference, consider a signal with one millisecond high, and nine milliseconds low. The frequency is 100Hz, and the duty cycle is 10%.
A signal with nine milliseconds high and one millisecond low has the same frequency, but a 90% duty cycle.
DieterKoblenz
I've read the output from the coin acceptor.
It's 100Hz normally and when you insert a coin it drops to 90Hz for a few milliseconds.
So I need to emulate this behaviour, from what I've read, PWM output should be the way to go.
DieterKoblenz
What I've done to get the values:
I've used pulseIn to read the pulse the coin acceptor generates:
  // initialize serial communication at 9600 bits per second:
  pinMode(pin, INPUT);
  duration = pulseIn(pin, HIGH);
   Serial.println(duration);
   delay(50);
It gives a long list of
9960
9899
9927
9932
9966
9892
And when I enter a euro (coin acceptor) it gives:
9928
10098
10124
9831
AWOL
No, PWM is not the answer.
The PWM frequency is fixed unless you want to fiddle with registers.
Using micros () may be much simpler.
Have a look at blink without delay.
DieterKoblenz
So, normally I would have an interval of 9 milliseconds and on the push of a button it should need 10 milliseconds?
AWOL
No, 9 milliseconds would be closer to 111Hz.
11 milliseconds would be roughly to 90Hz.
The relationship is a reciprocal.
DieterKoblenz
My pulseIn program gave the following values:
around 10124 microseconds when euro has been inserted
around 9831 microsecond continuous so constant without euro.
So these are the values I have to use is 9.8 constant and then 10.12 when I insert a coin / push the button?
DieterKoblenz
As a side question, would it be possible to catch this on one pin (using pulsein) and then too just forward it to another pin with pulseout?
