Topic: How do you make the current draw from a device gradual instead of instant? (Read 2047 times) previous topic - next topic
David82
I have a load activated by a button. I need it to gradually draw voltage and current as if it is being activated by a slider or knob. What simple, cheap device will do that for me up to 12v 3.5amps?
Grumpy_Mike
Look for a feature called "soft start", you fin it on a lot of power regulators and switches.
retrolefty
That's a request I haven't seen before. Perhaps if you wired a digital output pin to a fairly large R/C network that then wires to the gate of a N channel power mosfet, it would turn on (sink to ground) rather gradually causing that slow turn on you require.
Lefty
David82
I'm trying but can't find anything that fits the bill
stoopkid
What exactly is your goal? There may be a more clever way of accomplishing it if there was more information.
David82
MarkT
PeterH
What sort of load is it? Perhaps you could use PWM to power it and gradually ramp the duty cycle up from 0% to 100%.
zoomkat
Can the load be PWM'd ?  What is the load?
Suspected issue:
http://arduino.cc/forum/index.php/topic,140951.0.html
bobthebanana
#10
Jan 12, 2013, 03:43 am Last Edit: Jan 12, 2013, 07:28 am by bobthebanana Reason: 1
I've seen it done like this before. First your load receives power through a 1 ohm resistor (fiddle with the value) and the capacitor slowly charges up to the relay turn on voltage. Once the relay latches, it and your load receive full power since the resistor is bypassed. Make sure you use a high wattage resistor.
zoomkat
Possibly a MOSFET could be controlled with increasing PWM to gradually increased the total current being supplied.
Grumpy_Mike
#12
Jan 12, 2013, 09:49 am Last Edit: Jan 12, 2013, 11:15 am by Grumpy_Mike Reason: 1
OP - you need to put some time measurement into that first graph, the solution depends on how long you want the ramp to take.
You also need to say if the current is AC or DC.
David82
jackrae
According to my son-in-law's father "you move the switch slowly"   :smiley-mr-green:
So much for his knowledge of electrickery
