Loading...
Pages: [1]   Go Down
Author Topic: Hacking Ac motor with Arduino and Solid State Relays  (Read 420 times)
Offline Offline
Newbie
View Profile
Mighty Forum:
Im wondering if anyone had experience hacking a 120V AC motor with arduino and solide state relays to control the direction?    We dont need to control the speed.
We were able to control the SSRs with arduino and the code below,  but we were not able to change the direction of the motor.
 You can see from the video
https://vimeo.com/57183524
We are using this motor:
http://www.harborfreight.com/880-lb-electric-hoist-44006.html
which has a 25% duty cycle.
I think it also has a built-in motor controller, and the motor comes with a pendent switch to control the direction.
Amico 250V 25A SSR-25DA Temperature Control Solid State Relay
to hack the motor pendent switch
Here's the code that we're using
// this code only run both direction once when it starts, then the ac motor stops working completely with arduino after that.. we can still operate the motor with its pendent switch
const int motorPin1 =  5;    // One motor wire connected to digital pin 5
const int motorPin2 =  6;    // One motor wire connected to digital pin 6
void setup()   {
  pinMode(motorPin1, OUTPUT);
  pinMode(motorPin2, OUTPUT);
  rotateLeft(255, 10000);
  rotateRight(255, 10000);
void rotateLeft(int speedOfRotate, int length){
  analogWrite(motorPin1, speedOfRotate); //rotates motor
  digitalWrite(motorPin2, LOW);    // set the Pin motorPin2 LOW
  delay(length); //waits
  digitalWrite(motorPin1, LOW);    // set the Pin motorPin1 LOW
void rotateRight(int speedOfRotate, int length){
  analogWrite(motorPin2, speedOfRotate); //rotates motor
« Last Edit: January 11, 2013, 06:54:29 pm by molmol » Logged
Offline Offline
Newbie
View Profile
We solve the problem by putting 200K resistor to discharge the capacitor. And we 're able to control the direction of the AC motor now via an Arduino.
The arduino code can be downloaded at my github:
https://github.com/openMolmol/hack-acmotor-with-relay-and-arduino
Will post more instruction soon
« Last Edit: January 17, 2013, 02:48:22 pm by molmol » Logged
Beijing
Offline Offline
Full Member
Skype name habib.derbyshire
View Profile
WWW
Nice! I took apart a washing machine and got a huge ac motor with a nice ac capacitor as well. I'll post photos latter.
Logged
What is man's best friend? The breadboard!
Pages: [1]   Go Up
Print
Jump to:
