Loading...
Pages: [1]   Go Down
Author Topic: How to Send Hexadecimal value to Serial Devices  (Read 539 times)
Offline Offline
Jr. Member
View Profile
hi. hello. i have a question here. how i'm gonna send hexadecimal value to serial devices. i'm done a little bit study. the hex value can be send by using serial write like example below.
//Serial.write(0x55); <----right (HEX)
but how about AA BB 06 00 00 00 01 01 03 03? this is hex command to control the RFID reader. i just want to get the basic idea how to enable & disable the RFID first. if i manage to enable & disable the reader, i can  do lots more things with this reader. the reader that i buy is Mifare CR038. Here is the datasheet of the reader. with all, regards.
https://docs.google.com/document/d/1HxC-Ky4KqSM6SwILC0fRDFnGGZbuPF5TaRtJrfwwFFA/edit#
Logged
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
Code:
Serial.write(0xAA);
Serial.write(0xBB);
Serial.write(0x06);
Serial.write(0x00);
Serial.write(0x00);
Serial.write(0x00);
Serial.write(0x01);
Serial.write(0x01);
Serial.write(0x03);
Serial.write(0x03);
Logged
Offline Offline
Jr. Member
View Profile
is there any other way that so that i can write it simultaneously?
Logged
UK
Offline Offline
Tesla Member
View Profile
There are three overloaded implementations of Serial.write:
Serial.write(val)
Serial.write(str)
Serial.write(buf, len)
The first one sends a single byte, as johnwasser showed.
The second one sends an array of bytes, stopping when it reaches a null value in the array. (This would usually be used to send null-terminated strings.)
The third one sends an array of bytes with the number of bytes explicitly specified. This one seems to be what you want.
Code:
// uncompiled, untested
byte message[] = {0xAA, 0xBB, 0x06, 0x00, 0x00, 0x00, 0x01, 0x01, 0x03, 0x03 };
Serial.write(message, sizeof(message));
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
That depends on what you mean by "simultaneously". By my definition (at the same time), the answer is no. The Arduino can not do two things at once.
Logged
Offline Offline
Jr. Member
View Profile
Quote
based on the rfid user manual that i read, in order to turn off the led of the reader, i need to send this command code via serial communication.
AA BB 06 00 00 00 07 01 0 05
Packet Format (Hexadecimal): AA BB 06 00 00 00 07 01 LED XOR
AA BB = Header, 2 bytes.
06 00 = Packet length, 2 bytes, lower byte first. This indicate there are 6 bytes of data from Node ID to XOR.
00 00 = Node ID, Serial number of CR038, 2 bytes, lower byte first. 00 00 mean broadcast, it works for any ID.
07 01 = Function/Command Code Set LED status, 2 bytes, lower byte first.
XOR = result of exclusive OR operation from Node ID to LED.
i guess it not simultaneously. but in such, according to sequence in a packet.
Logged
Offline Offline
Jr. Member
View Profile
Serial.write(val)
Serial.write(str)
Code:
i understand. based on the your code, it uses Serial.write(buf, len)
buf: an array to send as a series of bytes
len: the length of the buffer
understand now. thank you very much. i will try compile it.
Logged
Offline Offline
Jr. Member
View Profile
no errors. i juz compile it. perhaps this monday i can try burn it into the uno board. tq PeterH & PaulS. finally, i got some new knowledge with your helps. really appreciate it.
Logged
Offline Offline
Jr. Member
View Profile
by the way, how i i'm gonna read the reply from the reader. i know it is related to the serial.read
in my code. i want to read the reply from the reader when i initialize & turn the led off. suppose to be when i turn off the led, the reader would reply Command
(Hexadecimal): AA BB 06 00 00 00 01 01 03 03
Reply from CR038 (Hexadecimal): AA BB 06 00 BF FF 01 01 00 40
BF FF = Node ID or Serial number of CR038, 2 bytes, lower byte 1st.
01 01 = Function/Command Code from host, 2 bytes, lower byte 1st.
00 = Status, 1 byte. 0 mean success, other than 0 mean fail.
40 = Result of XOR operation from Node ID to Status. Try it and you will get 0x40
Code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(8,9,4,5,6,7);
byte initPort[] = {0xAA, 0xBB, 0x06, 0x00, 0x00, 0x00, 0x01, 0x01, 0x03, 0x03};
byte offLED[] = {0xAA, 0xBB, 0x06, 0x00, 0x00, 0x00, 0x07, 0x01, 0x00, 0x05};
  // initialize serial:
  Serial.begin(19200);
  // set up the LCD's number of columns and rows:
  lcd.begin(8, 2);
  // Print a message to the LCD.
  lcd.print("Reader");
  // set the cursor to column 0, line 1
  lcd.setCursor(0, 1);
  // print the number of seconds since reset:
  lcd.print("Port Init");
  // print the string when a newline arrives:
  Serial.write(initPort, sizeof(initPort));
  lcd.print("LED OFF ");
  Serial.write(offLED, sizeof(offLED));
i started with an easy example. serial.available & serial.read from arduino tutorial. i managed to use the serial.read. but only for one figure number. not in string. i stuck here. how i'm gonna read the serial reply from the reader. the reply is AA BB 06 00 BF FF 01 01 00 40
Code:
char incomingByte = 0;   // for incoming serial data
  Serial.begin(9600);     // opens serial port, sets data rate to 9600 bps
  lcd.begin(8, 2);
  // send data only when you receive data:
  if (Serial.available() > 0) {
      // read the incoming byte:
      incomingByte = Serial.read();
      // say what you got:
      Serial.print("I received: ");
      Serial.println(incomingByte, 0);
      if (incomingByte=='1'){
      else if(incomingByte=='2'){
          lcd.print("LED ON  ");
Logged
Offline Offline
Newbie
View Profile
Did you find out how to read hex over the serial when the machine responds?
Logged
California
Offline Offline
Edison Member
View Profile
Pretty Simple:
Code:
int hexIn = Serial.read();
Logged
Offline Offline
Newbie
View Profile
Okay thanks, just didn't know if I had to do a read(something,HEX) thanks for the help.
Logged
Pages: [1]   Go Up
Print
Jump to:
