Author Topic: Coneccion wifi con seguridad  (Read 211 times)
hola, estoy utilizando arduino wifi shield wiz610wi para conectarme a una red casera de internet, utilicé el ejemplo que se encuentra en la página, pero tengo una duda: qué se debe poner en "int status = WL_IDLE_STATUS;"??
adjunto el código de ejemplo
#include <WiFi.h>
char ssid[] = "networkName";     //  your network SSID (name)
char pass[] = "yourPassword";    // your network password
int status = WL_IDLE_STATUS;     // the Wifi radio's status
  // initialize serial:
  // attempt to connect to an open network:
  Serial.print("Attempting to connect to WPA network: ");
  Serial.println(ssid);
  status = WiFi.begin(ssid, pass);
  // if you're not connected, stop here:
  if ( status != WL_CONNECTED) {
    Serial.println("Couldn't get a wifi connection");
    while(true);
  // if you are connected :
  else {
      Serial.print("You're connected to the network");
      printCurrentNet();
      printWifiData();
  // check the network connection once every 10 seconds:
  delay(10000);
  printCurrentNet();
void printWifiData() {
  // print your WiFi shield's IP address:
  IPAddress ip = WiFi.localIP();
    Serial.print("IP Address: ");
  Serial.println(ip);
  Serial.println(ip);
  // print your MAC address:
  byte mac[6];
  WiFi.macAddress(mac);
  Serial.print("MAC address: ");
  Serial.print(mac[5],HEX);
  Serial.print(":");
  Serial.print(mac[4],HEX);
  Serial.print(":");
  Serial.print(mac[3],HEX);
  Serial.print(":");
  Serial.print(mac[2],HEX);
  Serial.print(":");
  Serial.print(mac[1],HEX);
  Serial.print(":");
  Serial.println(mac[0],HEX);
void printCurrentNet() {
  // print the SSID of the network you're attached to:
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  // print the MAC address of the router you're attached to:
  byte bssid[6];
  WiFi.BSSID(bssid);
  Serial.print("BSSID: ");
  Serial.print(bssid[5],HEX);
  Serial.print(":");
  Serial.print(bssid[4],HEX);
  Serial.print(":");
  Serial.print(bssid[3],HEX);
  Serial.print(":");
  Serial.print(bssid[2],HEX);
  Serial.print(":");
  Serial.print(bssid[1],HEX);
  Serial.print(":");
  Serial.println(bssid[0],HEX);
  // print the received signal strength:
  long rssi = WiFi.RSSI();
  Serial.print("signal strength (RSSI):");
  Serial.println(rssi);
  // print the encryption type:
  byte encryption = WiFi.encryptionType();
  Serial.print("Encryption Type:");
  Serial.println(encryption,HEX);
  Serial.println();
muchas gracias por la ayuda
