Loading...
Pages: [1]   Go Down
Author Topic: Reading a website and selecting imformation among the code return  (Read 193 times)
Offline Offline
Newbie
View Profile
Im making a smart clock project now and i wanna get information from website posting weather information by using the Web client code.However, i can only read "www.google.com" but not "www.weather.com/weather/right-now/Enschede+Netherlands+NLXX0183" the page which i wanna get information from.
Besides. by looking at the example given in "http://bildr.org/page/11/"
code:
Code:
//ARDUINO 1.0+ ONLY
//ARDUINO 1.0+ ONLY
#include <Ethernet.h>
#include <SPI.h>
//CONFIGURE
byte server[] = { 174,123,231,247 }; //ip Address of the server you will connect to
//The location to go to on the server
//make sure to keep HTTP/1.0 at the end, this is telling it what type of file it is
String location = "/~bildr/examples/ethernet/ HTTP/1.0";
// if need to change the MAC address (Very Rare)
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
EthernetClient client;
char inString[32]; // string for incoming serial data
int stringPos = 0; // string index counter
boolean startRead = false; // is reading?
void setup(){
  Ethernet.begin(mac);
void loop(){
  String pageValue = connectAndRead(); //connect to the server and read the output
  Serial.println(pageValue); //print out the findings.
  delay(5000); //wait 5 seconds before connecting again
String connectAndRead(){
  Serial.println("connecting...");
  //port 80 is typical of a www page
  if (client.connect(server, 80)) {
    Serial.println("connected");
    client.print("GET ");
    client.println(location);
    client.println();
    //Connected - Read the page
    return readPage(); //go and read the output
  }else{
    return "connection failed";
String readPage(){
  //read the page, and capture & return everything between '<' and '>'
  stringPos = 0;
  memset( &inString, 0, 32 ); //clear inString memory
  while(true){
    if (client.available()) {
      char c = client.read();
      if (c == '<' ) { //'<' is our begining character
        startRead = true; //Ready to start reading the part
      }else if(startRead){
        if(c != '>'){ //'>' is our ending character
          inString[stringPos] = c;
          stringPos ++;
        }else{
          //got what we need here! We can disconnect now
          startRead = false;
          client.stop();
          client.flush();
          Serial.println("disconnecting.");
          return inString;
, i find it possible to select information by recognizing "<" and ">", so my idea is to recognize something like<span class="wx-temp"> and<span> instead of simply recognizing "<"">". But when i tried to implement this method, it returns nothing in serial monitor, i think it is because client.read reads one character at a time.so how shall i change the code? or can anyone of u bring me any better solutions for this problem?
Logged
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
You have to add a null terminator to your buffer before you convert it to a String.
You also have to make sure you don't over-fill the buffer.
Code:
String readPage() {
  stringPos = 0;
  while(true){
      switch (c) {
      case '<':
        stringPos = 0;
      case '>':
        if (startRead) {
          inString[stringPos++] = '\0'; // Add null terminator
          client.stop();
          client.flush();
          return inString;
      default:
        if (startRead && stringPos < (sizeof instring - 1)) {
          inString[stringPos++] = c;
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
Why can't you read from the second site? When you try, something is returned to the Arduino. What is it?
Using the String class at all is a really lousy idea.
Logged
Offline Offline
Newbie
View Profile
when i read the first one...it returns Html codes...but when i read the second one...there is nothing but "connecting...."
Logged
Offline Offline
Newbie
View Profile
Code:
  DNS and DHCP-based Web client
This sketch connects to a website (http://www.google.com)
using an Arduino Wiznet Ethernet shield.
Circuit:
* Ethernet shield attached to pins 10, 11, 12, 13
created 18 Dec 2009
by David A. Mellis
modified 9 Apr 2012
by Tom Igoe, based on work by Adrian McEwen
#include <SPI.h>
// Enter a MAC address for your controller below.
// Newer Ethernet shields have a MAC address printed on a sticker on the shield
byte mac[] = {  0x00, 0x03, 0x0D, 0xE9, 0xAD, 0x27 }; //请自行替换成自己的mac地址
char serverName[] = "www.weather.com/weather/right-now/Enschede+Netherlands+NLXX0183";
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
   while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  // start the Ethernet connection:
  if (Ethernet.begin(mac) == 0) {
    Serial.println("Failed to configure Ethernet using DHCP");
    // no point in carrying on, so do nothing forevermore:
    while(true);
  // give the Ethernet shield a second to initialize:
  Serial.println("connecting…");
  // if you get a connection, report back via serial:
  if (client.connect(serverName, 80)) {
    // Make a HTTP request:
    client.println("GET /s?wd=arduino HTTP/1.0");
    client.println();
  else {
    // if you didn’t get a connection to the server:
    Serial.println("connection failed");
  // if there are incoming bytes available
  // from the server, read them and print them:
    Serial.print(c);
  // if the server’s disconnected, stop the client:
  if (!client.connected()) {
    client.stop();
    // do nothing forevermore:
    while(true);
here is the code i got and it only returns:
connecting…
connected
disconnecting.
so it actually connected but could read nothing.
do u know why?
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
The server that you want to connect to is NOT "www.weather.com/weather/right-now/Enschede+Netherlands+NLXX0183". It is "www.weather.com". The rest of that is supposed to be part of the GET request.
The connection should result in more than the one character you are reading. At a minimum, you should be reading the reply using a while statement, not an if statement.
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Quote
do u know why?
You need to find another source for your weather data. the page you want to capture has way too much useless churn to deal with (look at the html source code on the weather page). use the code below to display in the serial monitor what is downloaded.
Code:
//zoomkat 9-22-12
//simple client test
//for use with IDE 1.0.1
//with DNS, DHCP, and Host
//open serial monitor and send an e to test
//for use with W5100 based ethernet shields
#include <SPI.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
char serverName[] = "www.weather.com"; // zoomkat's test web page server
void setup(){
    while(true);
  Serial.println("Better client test 9/22/12"); // so I can keep track of what is loaded
  Serial.println("Send an e in serial monitor to test"); // what to do to test
void loop(){
  // check for serial input
  if (Serial.available() > 0) //if something in serial buffer
    byte inChar; // sets inChar as a byte
    inChar = Serial.read(); //gets byte from buffer
    if(inChar == 'e') // checks to see byte is an e
      sendGET(); // call sendGET function below when byte is an e
void sendGET() //client function to send/receive GET request data.
  if (client.connect(serverName, 80)) {  //starts client connection, checks for connection
    client.println("GET /weather/right-now/Enschede+Netherlands+NLXX0183 HTTP/1.0"); //download text
    client.println("Host: www.weather.com");
    client.println(); //end of get request
  else {
    Serial.println("connection failed"); //error message if no client connect
  while(client.connected() && !client.available()) delay(1); //waits for data
  while (client.connected() || client.available()) { //connected or data available
    char c = client.read(); //gets byte from ethernet buffer
    Serial.print(c); //prints byte to serial monitor
  Serial.println("==================");
  client.stop(); //stop client
Logged
Why I like my 2005 rio yellow Honda S2000 with the top down, and more!
GOOGLE ADVANCED FORUM SEARCH BELOW!
Go to:  http://www.google.com/advanced_search?hl=en
put in key search words,
use site or domain:  http://arduino.cc/forum
or in a google search box put key words site:http://arduino.cc/forum
Pages: [1]   Go Up
Print
Jump to:
