Loading...
Pages: [1]   Go Down
Author Topic: Map() analogRead() Problem  (Read 128 times)
Offline Offline
Newbie
View Profile
Map value problem;
Although the value read is 1023, result is sometimes 11 en sometimes 12 ????
How can than be?
Basic Code (not actual program!):
ValMap = map(analogRead(A0), 0, 1023, 0 , 12);
Serial.print(analogRead(A0), DEC);Serial.println(ValMap, DEC);
Result on screen
1023 - 11
1023 - 11
1023 - 12
1023 - 12
1023 - 11
Making analogRead() first a Value, then putting it into map(), solved the problem!!!, Thank you...
« Last Edit: January 12, 2013, 08:11:52 am by Cees » Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
Try this...
Code:
int ara0;
ara0 = analogRead(A0);
ValMap = map(ara0, 0, 1023, 0 , 12);
Serial.print(ara0, DEC);Serial.println(ValMap, DEC);
Logged
Sweden
Offline Offline
Full Member
View Profile
Map value problem;
How can than be?
Result on screen
1023 - 11
1023 - 11
1023 - 12
1023 - 12
1023 - 11
Look at the first two lines of the code, let me quote:
Code:
You're making two different measurements on these lines. Try changing it to the following:
Code:
int val1=analogRead(A0);
ValMap = map(val1, 0, 1023, 0 , 12);
Serial.print(val1, DEC)
//Basel
Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
Be aware that the map function has serious rounding troubles around the high end.
Code:
for (int i=0; i<1024; i++)
  int x = map(i, 0,1023, 0,12) ;
  Serial.print(i);
  Serial.print("\t");
  Serial.println(x);
you might want to use map(i, 0,1024, 0,13) ; to get the results you want.
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Offline Offline
Newbie
View Profile
Thanks  smiley
Logged
Pages: [1]   Go Up
Print
Jump to:
