Topic: How to change Arduino IDE menu font size? (Read 39625 times) previous topic - next topic
probono
Hi all, how can I change the Arduino IDE menu font size? Reason: I have installed a lot of cores and my screen is not large enough to show them all. The respective menu does not scroll down, so I'd like to choose a smaller font for the menus. I did find settings to change just about every other font but not the menu font. I am using Ubuntu.
robtillaart
did you look into   File menu -> preferences  -> preferences.txt
editor.font=Monospaced,plain,12
Be aware you must change this file without any IDE running, as the IDE saves the settings upon close
and backup the file before changing !
add/check also these ...
build.verbose=true
upload.verbose=true
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
probono
Thanks, but editor.font does not affect the menus... the menus are "somehow" coupled to the system font. While this may work on many OSes, the result is a too large font (at least for my taste) in Ubuntu where it fails to match the real system font...
eried
Come to Windows, we have cookies and scrollable menus ]:D
My website: http://ried.cl
naught101
#4
Jan 14, 2013, 09:23 am Last Edit: Jan 14, 2013, 09:51 am by naught101 Reason: 1
I'd like to know this too. For some reason, my Arduino IDE (1.0.3, downloaded from the website just now) starts up with menu and UI (e.g. preferences window fonts) so small that I can't read them -- see attached.
I'm running kubuntu quantal, with OpenJDK Runtime Environment (IcedTea7 2.3.3) (7u9-2.3.3-0ubuntu1~12.10.1).
Edit: I've also tried IcedTea6 and Oracle Java 7. Same thing.
naught101
eried
probono
On Linux, I was able to solve this by creating a file called "fontsettings" with the following content:
Code: [Select]
style "small" {
       font_name = "Sans Condensed 8"
class "GtkWidget" style "small"
Now I have to
Code: [Select]
export GTK2_RC_FILES=$GTK2_RC_FILES:./fontsettings
and then launch Arduino. Of course you can integrate the export statement into the Arduino launch script.
16kRAM
I'm running a Debian-based Linux and had the same problem with impossibly small menu text when using the Arduino IDE version 1.0.5
The solution for me was to edit the arduino script (/usr/bin/arduino on my system) to get rid of the GTKLookAndFeel.
From this:
Code: [Select]
java -Dswing.defaultlaf=com.sun.java.swing.plaf.gtk.GTKLookAndFeel processing.app.Base "$@"
To this:
Code: [Select]
#java -Dswing.defaultlaf=com.sun.java.swing.plaf.gtk.GTKLookAndFeel processing.app.Base "$@"
java processing.app.Base "$@"
AntonioLopez
Thanks,
This worked beautifully,
Quote
I was having a hard time seeing the sketch font, this fixed my problem.
Thanks...........Antonio
b-james
#10
Dec 31, 2014, 02:48 am Last Edit: Dec 31, 2014, 02:55 am by b-james
From this:
Code: [Select]
To this:
Code: [Select]
This one is on the money on Puppy Linux also -Thanks heaps .
My eyes were nearly gone and I avoided using Arduino cause I could not see it .
The "#" comments out the line so the line is replaced with
I started another thread on this Yesterday so I will reference that to here also
Now if I can just work out how to get it a bit bigger again
b-james
Also noticed in Puppy Linux and maybe others  the font choice in preferences is wrong.
Look for the line that says Monospaced,normal,12 and change to Monospace,bold,20  for a bigger bolder show for tired eyes.  Could probably use other fonts here too
This probably applies to Ubuntu also.
koenigp
The arduino ide had weird unusable fonts in knoppix usb distro. It is pretty stripped down and I figured it was subbing a font as best it could but to no avail. I tried
sudo apt-get install msttcorefonts
and it was perfect afterwards.
b-james
I gave the above a try but it did not change anything for me on Puppy linux but maybe I need to do something else on the installation .
Definately
Quote
works .
jwmcnc
I am having difficulty reading my arduino  text code on screen in the arduino ide, it appears not be be a true black. When I copy it to notepad++ and try to print it on paper, it prints very light. I have used the notepad++ setting to make text darker which helps, but it is a long way around. Is there a way to get the arduino ide to just display true black letters?
Thanks
jwmcnc
