Topic: How to change Arduino IDE menu font size? (Read 39626 times) previous topic - next topic
Ueff
#15
Feb 23, 2018, 05:28 pm Last Edit: Feb 23, 2018, 05:33 pm by Ueff
I'm running a Debian-based Linux and had the same problem with impossibly small menu text when using the Arduino IDE version 1.0.5
The solution for me was to edit the arduino script (/usr/bin/arduino on my system) to get rid of the GTKLookAndFeel.
From this:
Code: [Select]
java -Dswing.defaultlaf=com.sun.java.swing.plaf.gtk.GTKLookAndFeel processing.app.Base "$@"
To this:
Code: [Select]
#java -Dswing.defaultlaf=com.sun.java.swing.plaf.gtk.GTKLookAndFeel processing.app.Base "$@"
java processing.app.Base "$@"
thank you, it's work!
problems in bad GTK+ LookAndFeel theme, we can chenge LAF theme for example to Numbus:
Code: [Select]
JAVA_OPTIONS=("-DAPP_DIR=$APPDIR" "-Dswing.defaultlaf=com.sun.java.swing.plaf.nimbus.NimbusLookAndFeel")
or Motif. Mmm... Cutie...
Code: [Select]
JAVA_OPTIONS=("-DAPP_DIR=$APPDIR" "-Dswing.defaultlaf=com.sun.java.swing.plaf.motif.MotifLookAndFeel")
or remove LAF parameter:
Code: [Select]
JAVA_OPTIONS=("-DAPP_DIR=$APPDIR")
fast-Lion
This change worked for me. (Linux Manjaro 17.1 with KDE Plasma5)
