Offline
Newbie
« on: January 12, 2013, 05:04:08 am » |
Hi all, I am new in electronics and encounter a problem with a tip120 transistor. I wire it this way: http://floran.morel.free.fr/Divers/versys_bb.jpgThe problem is, the led is always ON, and when i am testing the transistor with a multimeter in diode mode, i find 0,5v between the collector and emmiter. So i kill it and i don't know why  I need some help to understand where is my mistake.
« Last Edit: January 12, 2013, 07:07:43 am by cheesepower »
Logged
Miramar Beach, Florida
Offline
Faraday Member
« Reply #1 on: January 12, 2013, 07:04:22 am » |
I cannot find a datasheet on that TIP220 transistor. Can you post a link to it? Are you sure it is a TIP220 and not a TIPXXX in a TO-220 case?
Logged
Offline
Newbie
« Reply #2 on: January 12, 2013, 07:08:49 am » |
Logged
Offline
God Member
« Reply #3 on: January 12, 2013, 07:12:16 am » |
It's a Darlington, Collector, Base Emitter.
- not a mosfet as your circuit would describe.
you're not blowing them, they work still no doubt, collect D3 of Arduino to the Base Pin (middle/2 pin), Emitter to GND, Collector to your LED's GND (short lead) and the Anode + side goes straight to your 5v rail.
Logged
Offline
God Member
« Reply #4 on: January 12, 2013, 07:13:34 am » |
But, add a 1 - 10k resistor on base or it could damage the arduino pin.
Logged
Offline
Faraday Member
« Reply #5 on: January 12, 2013, 07:14:13 am » |
Try connecting the wire connected to the Arduino D3 pin to ground instead of the Arduino pin. Does the LED still light?
@cjdelphi: That is not what the datasheet shows. Pin 1 is the base.
Logged
Offline
Newbie
« Reply #6 on: January 12, 2013, 07:24:39 am » |
According to the datasheet, the base pin is the pin 1, right ?
Logged
Offline
Faraday Member
« Reply #7 on: January 12, 2013, 07:26:02 am » |
Pin 1 is the base. Did you try the test?
Logged
Offline
Newbie
« Reply #8 on: January 12, 2013, 07:30:52 am » |
Yes, and the led is still light
« Last Edit: January 12, 2013, 07:33:28 am by cheesepower »
Logged
Offline
God Member
« Reply #9 on: January 12, 2013, 07:35:47 am » |
ah yes sorry my bad, I looked at the Darlington first, then i went back to a similar datasheet i had open and looked, then i went back and realized.
take a look at the attachment....
Logged
Offline
God Member
« Reply #10 on: January 12, 2013, 07:36:22 am » |
ah yes, my amazing circuit design skills
Logged
Offline
God Member
« Reply #11 on: January 12, 2013, 07:38:37 am » |
fair enough, so what resistors you using? to connect the transistor? i'd use a 1k for the base, and then 300 ohms to limit the LED current, also while you're at it, move it from 3v to 5v, it's possible if you're not using a red led, it will be dimly lit, even less so with the voltage drop through the transistor.
« Last Edit: January 12, 2013, 07:41:12 am by cjdelphi »
Logged
Offline
Newbie
« Reply #12 on: January 12, 2013, 07:40:41 am » |
Sorry but i don't understand your schematics
Logged
Offline
God Member
« Reply #13 on: January 12, 2013, 07:42:00 am » |
^^ so just swap to a 5v source and let us know the resistor values.
Logged
Offline
Newbie
« Reply #14 on: January 12, 2013, 07:46:16 am » |
I put a 1K resistor between D3 and the base pin, also put a 200 ohms resistor for the led
Why do i need to change the voltage to 5v ? 3,3v is not correct ?
Logged
