Loading...
Pages: [1]   Go Down
Author Topic: Class declaration problem with constructor  (Read 120 times)
Offline Offline
Jr. Member
View Profile
I want to calculate the days that passed in a year since a certain date. I made a class DayNumber.
i made this header file
Code:
#ifndef DayNumber_H_
#define DayNumber_H_
class DayNumber
private:
int _day1YearLoop[];
int _day4YearLoop[];
public:
int Days1YearLoop;
int Days4YearLoop;
DayNumber(int setYear,int setMonth,int setDay);
virtual ~DayNumber();
bool checkLeapYear(int setYear);
#endif
i use eclipse. and i made this .cpp file.
Code:
#include "DayNumber.h"
DayNumber::DayNumber(int setYear,int setMonth,int setDay){
// it does not matter what it does it just give me the number of the day since 1 january of each year for a certain day.
DayNumber::~DayNumber(){
bool DayNumber::checkLeapYear(int setYear){
if (setYear%4==0){
return true;
else{
return false;
the problem is at the main.cpp. When i do:
Code:
  DayNumber num1 = DayNumber(2715,10,23);
  Serial.print("Days for one Year Loop(leap)\t");
  Serial.print(num1.Days1YearLoop);
  delay (5000);
everything is ok. if i try to declare DayNumber num1; befroe everything. i mean before setup like this:
Code:
#include "Arduino.h"
DayNumber num1;
int main(void)
init();
setup();
for (;;)
loop();
return 0;
  delay (5000);
i get this error:
../src/main.cpp:8: error: no matching function for call to 'DayNumber::DayNumber()'
/Volumes/Lion 2/EclipseWorks/DayNumber/lib/DayNumber.h:22: note: candidates are: DayNumber::DayNumber(int, int, int)
/Volumes/Lion 2/EclipseWorks/DayNumber/lib/DayNumber.h:12: note:                 DayNumber::DayNumber(const DayNumber&)
make: *** [src/main.o] Error 1
line 22 at header is DayNumber(int setYear,int setMonth,int setDay);
and line 12 is class DayNumber{
so why is this happening? i did everything by the tutorial of from the site and i mean arduino for making libraries. I just wanted to define an "object" of this class to use it in loop.i have made an RTC (real time clock) and i am also using its library that does the same ( defines the object of RTC class before everything) and it does not give any problem. Can you give me a solution so i can declare the object without initialization  and then call it inside loop and initialize it?
Logged
Offline Offline
Full Member
View Profile
try that
Code:
int main(void)
init();
setup();
for (;;)
loop();
return 0;
Problem: way of  declaration.
if you really like that way declaration DayNumber num1;
then add one more constructor.
Code:
DayNumber();
« Last Edit: January 12, 2013, 09:18:12 am by Cybernetician » Logged
From Idea To Invention
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
The DayNumber class needs a constructor that takes no arguments, and a method that takes the arguments of interest, and returns the value of interest.
Logged
Finland
Offline Offline
Jr. Member
View Profile
It should be possible to give default values to the arguments in the constructor and then it would at least pass compilation, but I doubt this is what you wanted either.
DayNumber(int setYear = 2715,int setMonth = 10,int setDay = 23);
Logged
Pages: [1]   Go Up
Print
Jump to:
