Author Topic: Static burst sound effect  (Read 298 times)
in my project i need to have a short static burst follow my speech through a small amplified speaker
any idea how to accomplish this with arduino+mini amp+microphone+mp3 player?
UK
If you can connect an SD Card reader up then you could use the SimpleSDAudio library to play sounds straight from a PWM pin(s).
You can have 8 bit Mono (1 pin), 8 bit stero (2 Pins), 16 bit mono (2 pins and a resistor network) or 16 bit stereo (4 pins and 2 resistor networks).
I use the 8 bit mono for sound effects and that's plenty good enough for my requirements.
For like a Storm trooper type effect?
Im not sure this is really going to help..seems to be more 'pitch' related..  (and I think uses the Waveshiled as a base)
but I have got this working before:
http://learn.adafruit.com/wave-shield-voice-changer/overview
Manchester (England England)
Solder is electric glue
Just use the noise bit out of this program:-
volatile unsigned int sample = 0;
 volatile unsigned int increment = 0x800;
void setup(){
    setSampleTimer();
ISR(TIMER2_COMPB_vect){  // Interrupt service routine to output next sample to PWM
      sample += increment;
     if((sample & 0x8000) != 0)  // implement a triangle wave
     OCR2B = 127 - (sample >> 8) & 0x7f;
      OCR2B = (sample >> 8) & 0x7f;
void setSampleTimer(){  // sets timer 2 going at the output sample rate
  pinMode(3, OUTPUT);
  TCCR2A = _BV(COM2B1) | _BV(WGM21) | _BV(WGM20); // Just enable output on Pin 3 and disable it on Pin 11
  TCCR2B = _BV(WGM22) | _BV(CS22);
  OCR2A = 129; // defines the frequency 120 = 16.13 KHz or 62uS, 124 = 15.63 KHz or 64uS, 248 = 8 KHz or 125uS
  OCR2B = 64;  // deines the duty cycle - Half the OCR2A value for 50%
  TCCR2B = TCCR2B & 0b00111000 | 0x2; // select a prescale value of 8:1 of the system clock
void loop(){
   wobble(10);
   sweepUp(200);
   sweepDown(200);
   noise(1000);
   notes(30);
void wobble(int wobbles){
   TIMSK2 = _BV(OCIE2B); // sound
    for(int j=0; j<wobbles; j++){
  for(int i = 0x500; i< 0x1300; i+=0x4){
    increment = i;
   delayMicroseconds(100);
  TIMSK2 = 0; // hush
void noise(int length){ // length about 1000
  for(int i=0; i<length; i++){ // noise
   increment = random(30, 0x1500);
   TIMSK2 = 0; // hush
void sweepUp(int time){ // time controls how long it takes start with 200
  TIMSK2 = _BV(OCIE2B); // Output Compare Match B Interrupt Enable
  for(int i = 0x500; i< 0x1300; i+=0x1){
    increment = i;
   delayMicroseconds(time);
 TIMSK2 = 0; // Output Compare Match B Interrupt Disabled
void sweepDown(int time){ // time controls how long it takes start with 200
    increment = 0x1300 - i;
void notes(int length){
    increment = random(300,0x1500);
    delay(100);
  TIMSK2 = 0; // hush
