Loading...
Pages: [1]   Go Down
Author Topic: Project 14 (Tweak the Arduino Logo)  (Read 3595 times)
Offline Offline
Newbie
View Profile
Hello.
I have downloaded the last version of processing (2.0b7), but executing the processing code I receive the "serial does not run in 64-bit mode" (I use Windows 7 x64), any solution?
Thanks.
Logged
Offline Offline
Newbie
View Profile
I had the same. but are now using the 32 bit version. works well...
I needed to copy paste the code though.
cheers, Sander
Logged
Offline Offline
Newbie
View Profile
Hello,
I've another problem with project 14. The color sometimes changes very slowly or somtimes it doesn't change at all. It's the same with the numbers in the black field in processing.  I've look at the poti's values at a arduino programm and it works. They change very fast.  I think the code is right because I've tested it with the from the arduino software, too. There's the same problem.
Can anyone help me?
Logged
Offline Offline
Newbie
View Profile
posted by tiffi:
Quote
Hello,
Can anyone help me?
I have the exact same issue!  I've actually installed Processing and Arduino on both my Windows 7 laptop and my Macbook Air running Mountain Lion and I have the same issue on both (exactly as described above by the previous poster).  On the Windows machine I've installed the 32-bit version and on the Mac I've selected the 32-bit option in preferences.
Does anyone have an explanation or a fix?
Thanks,
Jeff
Logged
Wahiawa, Hawaii
Offline Offline
Sr. Member
View Profile
This is from the Processing site:
Quote
I know this is an issue.
We all very much want a 64-bit serial library.
I don't have time to make and test one across all the necessary platforms.
We hope that someone will soon.
It is marked as an “enhancement” because we have never had a 64-bit library. Calling it a major bug won't change the fact that I don't have time to fix it right now.
For the time being, comment #5 explains a workaround.
"comment #5: On Linux and Windows, download the 32-bit version of Processing. "
Logged
Wahiawa, Hawaii
Offline Offline
Sr. Member
View Profile
As for the color changing rate problems you are seeing, it appears to be a serial buffering issue.  The Arduino is sending reading sample updates too fast for Processing to keep up with.  I don't know why they made the Arduino code sample that fast (1 millisecond delay is about 1000 samples per second), it's not really necessary.
But here is a quick fix workaround to this.  Change the sample delay from 1 millisecond to 100 milliseconds.  This should slow down the Arduino sampling slow enough for Processing to keep up with.
Try this:
Code:
  // read the value of A0, divide by 4 and
  // send it as a byte over the serial connection
  Serial.write(analogRead(A0)/4);
  delay(100);
Logged
UK
Offline Offline
Jr. Member
View Profile
WWW
Thank you Hiduino.
I'm on lowly project 7 but already have this on all the sketches. There's one,for example (I forget which) that shows 2 lines of values and it's impossible to read them unless you slow it all down. Worked for me. Would recommend it for v2.
Logged
Photography nut trying to make the flux capacitor of macro photography
Pages: [1]   Go Up
Print
Jump to:
