Topic: Project 14 (Tweak the Arduino Logo) (Read 16187 times) previous topic - next topic
swapper
Hello.
I have downloaded the last version of processing (2.0b7), but executing the processing code I receive the "serial does not run in 64-bit mode" (I use Windows 7 x64), any solution?
Thanks.
Sbuijs
I had the same. but are now using the 32 bit version. works well...
I needed to copy paste the code though.
cheers, Sander
tiffi
Hello,
I've another problem with project 14. The color sometimes changes very slowly or somtimes it doesn't change at all. It's the same with the numbers in the black field in processing.  I've look at the poti's values at a arduino programm and it works. They change very fast.  I think the code is right because I've tested it with the from the arduino software, too. There's the same problem.
Can anyone help me?
jeffcd
posted by tiffi:
Hello,
Can anyone help me?
I have the exact same issue!  I've actually installed Processing and Arduino on both my Windows 7 laptop and my Macbook Air running Mountain Lion and I have the same issue on both (exactly as described above by the previous poster).  On the Windows machine I've installed the 32-bit version and on the Mac I've selected the 32-bit option in preferences.
Does anyone have an explanation or a fix?
Thanks,
Jeff
hiduino
This is from the Processing site:
I know this is an issue.
We all very much want a 64-bit serial library.
I don't have time to make and test one across all the necessary platforms.
We hope that someone will soon.
It is marked as an "enhancement" because we have never had a 64-bit library. Calling it a major bug won't change the fact that I don't have time to fix it right now.
For the time being, comment #5 explains a workaround.
"comment #5: On Linux and Windows, download the 32-bit version of Processing. "
hiduino
As for the color changing rate problems you are seeing, it appears to be a serial buffering issue.  The Arduino is sending reading sample updates too fast for Processing to keep up with.  I don't know why they made the Arduino code sample that fast (1 millisecond delay is about 1000 samples per second), it's not really necessary.
But here is a quick fix workaround to this.  Change the sample delay from 1 millisecond to 100 milliseconds.  This should slow down the Arduino sampling slow enough for Processing to keep up with.
Try this:
  // read the value of A0, divide by 4 and
  // send it as a byte over the serial connection
  Serial.write(analogRead(A0)/4);
  delay(100);
nass
Thank you Hiduino.
I'm on lowly project 7 but already have this on all the sketches. There's one,for example (I forget which) that shows 2 lines of values and it's impossible to read them unless you slow it all down. Worked for me. Would recommend it for v2.
sina92
Hello.
I downloaded the 32-bit version but I still can't compile. I get the same error that I got on the 64-bit version,
"serial is only compatibl wit the 32-bit download of Processing."
Someone pls help!
hiduino
Hello.
Someone pls help!
Which Arduino are you trying this with?
sina92
#9
Jun 27, 2013, 12:50 pm Last Edit: Jun 27, 2013, 01:54 pm by sina92 Reason: 1
EDIT**
I restarted my PC n no it work's just as intended.
sina92
I've run into some trouble on this project again.
I can change the background color but it keep's flashing. I think it's because of my port.read() values. They pretty much always bounce between 55 and 10, hardly taking notice of how much I've turned the potentiometer.
I have no experience dealing with serial communication, so I'm a bit lost at the moment.
My code:
import processing.serial.*;
Serial myPort;
PImage logo;
int bgcolor = 0;
  colorMode(HSB, 255);
  logo = loadImage("http://www.userlogos.org/files/logos/jumpordie/teamliquid-iphone.png");
  size(logo.width, logo.height);
  println("Avilable serial ports");
  println(Serial.list());
  myPort = new Serial(this, Serial.list()[1], 9600); // parameters : which application, which port & what speed
void draw() {
  if (myPort.available() > 0) { // if(there is something in the buffer)
    bgcolor = myPort.read();
    print("     ");
    println(myPort.read());
    println(bgcolor);
  background(bgcolor, 255, 255); // hue, brightness, saturation. max value 255
  image(logo, 0, 0); // image() is used to draw. --- what to draw , x-coordiante to start, y-coordiante to start ---
1. Does anyone know what I should do in order to get proper readings?
2. What type of images can I use? Any image, or does it have to be a .jpg, .png etc...?
Thanks in advance!!
pedrofe
Try this:
  delay(100);
There is a way to fix this issue changing only the Processing code to clear the buffer after reading a byte:
if ( myPort.available() > 0) {
// read the value and store it in a variable
myPort.clear();
// print the value to the status window
println(bgcolor);
