Loading...
Pages: [1]   Go Down
Author Topic: Breadboard-friendly power connectors?  (Read 199 times)
Johannesburg UTC+2
Offline Offline
Edison Member
View Profile
Hey all,
I have a couple of the connector thingies shown in the attached pic- sorry for quality but it shows the problem which is that they don't fit breadboard power rails.
I know I can jam the wires into the holes, but that doesn't work with stranded wire. What do others do for power connections to breadboard? (No electronics required- I've just hacked an ATX PSU so I have various voltages (3v3, 5v and 12v) available.)
Logged
IT Crowd:
Roy... "Have you tried turning it off and on again?"
Moss.. "Have you tried forcing an unexpected reboot?"
Scotland
Offline Offline
God Member
Have you had your Arduino fix today?
View Profile
WWW
I bonded one of these to a breadboard, and soldered jumper wires to the pins, and inserted them into the rails.
Logged
Drew.
(MyPCB MANUFACTURING SERVICE)
Duemilanove - UNO - Leonardo - Mega 1280 - Mega 2560 - Pro
& Way too many custom boards.
Johannesburg UTC+2
Offline Offline
Edison Member
View Profile
Yeah I was thinking something along those lines... blob of Araldite should do it.
Logged
IT Crowd:
Scotland
Offline Offline
God Member
View Profile
WWW
Yip - I got 2 - one on each power rail - can do 5V & 12V on same board ;-)
Logged
Drew.
Offline Offline
Sr. Member
The last thing you did is where you should start looking.
View Profile
1. Mount the protoboard on a piece of plastic then add binding posts. Use a wire from the posts to the protoboard.
posts
2. Use male headers on the protoboard. Solder wires to and use female headers on the male  smiley-sweat
3. Make small PCB with male headers on the bottom. Mount the terminal block you show on the top of the PCB.
Logged
Johannesburg UTC+2
Offline Offline
Edison Member
View Profile
Quote
Make small PCB
As the lady on 9gag says, "Ain't nobody got time for that!"  smiley-cool
Logged
IT Crowd:
Offline Offline
Sr. Member
View Profile
Quote
Or use:
http://en.wikipedia.org/wiki/Stripboard
Logged
Johannesburg UTC+2
Offline Offline
Edison Member
View Profile
Quote
Now that I have....
Logged
IT Crowd:
Phoenix, Arizona USA
Offline Offline
Faraday Member
Where's the beer?
View Profile
WWW
Then use solid core wire - or use a thin-enough gauge of stranded wire that you can tin the ends (and the tinned section will still fit).
I typically do one of the above, and use alligator clip jumpers from the PSU to the board. I generally will run the inputs to the positive and negative rails on opposite sides (so the alligator clips have less of a chance of shorting), then jumper on the opposite end of the board the other rails.
Logged
Pages: [1]   Go Up
Print
Jump to:
