Loading...
Pages: [1]   Go Down
Author Topic: Looking for an LCD  (Read 348 times)
Not behind you
Offline Offline
Newbie
View Profile
First off, I'd like to say this is my first post here, and you would be correct to call me a newbie when it comes to Arduino and some of the nitty-gritty-electronics-stuff. So if I say anything stupid or use any wrong terminology or anything, please point it out for me  smiley-wink.
I'm looking for a TFT-LCD with some certain specs. I've looked around, done a few google searches, but I am unable to find a good place that sells LCDs similar to what I need. I did find this (http://www.ebay.com/itm/3-2-inch-TFT-LCD-Module-Display-320-x-240-Touch-Panel-PCB-adapter-color-screen-/251057269544) on eBay, but I think it is a little more expensive because it has a touchscreen too. Does anyone know a good place to buy LCDs, such as with the following qualities?
- 2.8-3.2 inches
- 320x240 or better resolution (3:2 aspect ratio preferred)
- Under $15-20 (USD)
Thank you!
« Last Edit: January 12, 2013, 10:19:48 am by Nelsyv » Logged
North Queensland, Australia
Offline Offline
Edison Member
View Profile
WWW
I got my first SSD1289 off ebay for a bargain $10 ( auction ), but they are on 'buy it now' for a range of low prices.
I got a sainsmart kit also for $45 ( auction also ) which has a mega and shield on top of the screen.
Some screens where discussed here: http://arduino.cc/forum/index.php/topic,141761.0.html
You can also create your 3:2 ratio by changing the vertical pitch of a square lcd.
Logged
UK
Offline Offline
Sr. Member
View Profile
This is just one that was posted in another thread (on the 1.8" cheap TFT's)
http://item.mobileweb.ebay.co.uk/viewitem?itemId=181008290930
It's touch screen too, but you could just not use that function.
It meets your other criteria; size, aspect ratio, price.
HTH
Logged
Not behind you
Offline Offline
Newbie
View Profile
Everyone who posted, thanks for your replies! I looked at all of the screens you suggested, and they all look great. However, as I read around the forums a bit, I found that most of the screens people like use the SSD1289 LCD controller, while some of the suggested ones use ILI9320. I am kind of a newbie, so can someone explain what kind of difference different LCD controllers make?
Logged
UK
Offline Offline
Sr. Member
View Profile
With LCD screens, especially higher pixel counts, speed is going to count, so look for the connection method.
You also need to see if there is a library and good code examples for you to work from.
For these I'd think hardware SPI is the best connection method, but check any library to see what speed you are interfacing at. You can go up to half the MCU clock speed with SPI so a clock divider of 2.
For example, the 128 x 160 TFT I just bought workers with an Adafruit library. The library specifies a clock divide of 4. This can be changed to 2 and double the data rate onspeed up display.
This is just my own take on finding the right method and code. I'm sure there are some more experienced members that could tell you any hardware pros and cons of the actual controller chips themselves.
I'd guess one will be what data rate thy could handle on SPI, to see if you can change the SPI clock divider as I mentioned above.
Logged
Not behind you
Offline Offline
Newbie
View Profile
Sorry, but when you say SPI, is that just a different connection, or a different controller method or what?
Logged
Anaheim CA.
Offline Offline
Edison Member
Experienced old Whitebeard with a Full head of Hair...
View Profile
Both. Go look at the UTFT library from Henning Karlsen. That library supports the Itead Studios #.2" 320 X 240 line display which can be purchased from Amazon for $19.98. I  like buying there because IF.. you have ANY issues with the display Amazon is real good about returns/refunds . I bought a display that only had 1/2 of the screen working and had a return authorization within 15 minutes of the package arriving at my door.
Bob
Logged
“The solution of every problem is another problem.” -Johann Wolfgang von Goethe
Pages: [1]   Go Up
Print
Jump to:
