Loading...
Pages: [1]   Go Down
Author Topic: Need help identifying the use for circuit on DC motor  (Read 170 times)
Offline Offline
Newbie
View Profile
What's the purpose of those capacitors? What would happen if I would bypass them?
Thanks in advance!
Logged
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
I think they are there to absorb some of the very nasty electrical noise caused by the DC motor.  You can remove them if you don't mind the electrical interference. smiley
Logged
UK
Offline Offline
Sr. Member
View Profile
Yep, they're to reduce noise, just as John says. Where it says 'soldered to the outside' - that means you solder one leg of the cap to a motor terminal, to other leg to the motor case next to the terminal. The noise absorption is superior to a single cap across the terminals.
Logged
Offline Offline
Newbie
View Profile
Thanks alot guys for the quick and informative answers!  smiley-grin
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
The brushes on brushed DC motors generate sparks which are the source of the electrical noise (in
the radio frequency bands).  The caps reduce these higher frequencies to much lower voltages thus
preventing the motor leads acting as noise-transmitting aerials.  The value is chosen to be large
enough to remove a lot of the noise but not so large as to overload the motor driver circuit when
it uses PWM.
Logged
Pages: [1]   Go Up
Print
Jump to:
