Loading...
Pages: [1]   Go Down
Author Topic: DipTrace and Documents Security  (Read 593 times)
Offline Offline
Newbie
View Profile
Quote
Bear in mind that DipTrace modifies the security settings of the Documents folder.  In my opinion, the behaviour borders on that of a virus.
How does it do that? DipTrace installer just creates its folder in My Documents, also for installation process we use QInstall from Pantaray Research and its standard features without any security settings change.
Regards,
Stanislav Ruev
DipTrace Team
p.s. Meet us at DesignCon2013 - both #640
Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
I ran the DipTrace install.  The security settings for My Documents had been altered.
I removed DipTrace then rebooted.  The security settings were not restored.
I restored the security settings and rebooted.   The security settings were what they should be.
I reran the DipTrace install.  The security settings for My Documents had been altered.
Logged
Offline Offline
Newbie
View Profile
Seems you are right: I have tried to install DipTrace on fresh system. I did not get any alert, but the installer changed settings of My Documents (not all user folders though) and added all permissions for all users item (not network sharing though). This is actually installer and not DipTrace software itself as I didn't run it at all - I will check installer settings how to change that.
Added later:
Contacted Pantaray (developer of QInstall) regarding the issue.
Regards,
Stanislav Ruev
DipTrace Team
« Last Edit: January 13, 2013, 07:13:26 am by novarm44 » Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
Sometimes.  Sometimes not.  There are circumstances when anything that can access the network will have full access to My Documents.  Which is why I said, "In my opinion, the behaviour borders on that of a virus."
Logged
Offline Offline
Newbie
View Profile
The issue has been fixed and installation files updated on web-site!
Thank You for your help!
Added later:
We receive complains from users the software doesn't work from any account (admin,user, etc.) in Win x64 (actually option was enabled because of that),
so access for all users were returned, but for DipTrace folders only (not all My Documents)
Regards,
Stanislav Ruev
DipTrace Team
« Last Edit: January 18, 2013, 05:37:30 pm by novarm44 » Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
We receive complains from users the software doesn't work from any account (admin,user, etc.) in Win x64 (actually option was enabled because of that), ...
You have a serious problem with your software so...
Quote
...you work around that problem by crippling security.
Good to know.
Logged
Offline Offline
Newbie
View Profile
The problem is not actually software, but something in Windows 64-bit security settings, installer and specific computer settings. On our PCs all versions work ok with any security settings under any account. The users write though:
Quote
Clean install of Diptrace 2.3.0.2 (64bit).
Standard user, attempting to start the launcher or any other Diptrace program throws an error:
"Windows cannot access the specified device, path, or file. You may not have appropriate permissions to access the item." and then terminates.
Tried installing from the administrator login and also from the standard user login, entering the administrator password to allow the installation. Same results both times.
OS is Windows 7 Home, 64bit, 6GB RAM
or http://www.diptrace.com/forum/viewtopic.php?f=9&p=13178
Actually that was the reason why we enabled that option in the past. Enabled incorrectly and it changed security for "My Documents" folder. Now it only creates new DipTrace folders with "all allowed" security settings. We will be happy to solve this, but don't know how at the moment.
Anyway we will keep current settings yet (I suppose allowing access to all PC users for just new DipTrace folders is not critical) and our programmers together with sys admin now trying different configurations - probably we will find why it doesn't work on some x64 systems and make something intermediate, then publish update after DesignCon. I'll keep you informed.
« Last Edit: January 21, 2013, 04:56:02 am by novarm44 » Logged
Pages: [1]   Go Up
Print
Jump to:
