Topic: Help with a pulse detection func (Read 4920 times) previous topic - next topic
PaulS
You can't use delay() in an ISR. That ISR is populating an array. In loop(), read the data in that array, and do something. Do NOT add code to a function you do not understand.
GoForSmoke
Quote
There goes 80% of all problem-with-the-code threads....
Nick Gammon on multitasking Arduinos:
1) http://gammon.com.au/blink
2) http://gammon.com.au/serial
3) http://gammon.com.au/interrupts
PaulS
Quote
You say that like it's a bad thing.  8)
GoForSmoke
Sven, you don't need interrupts.
Just run fast through loop() without delays and you will be plenty fast enough -- a few microseconds, maybe as fast as 1 microsecond per pass.
Before you code, make your plan. Something like this perhaps?
Start loop()
Read the pin
Did the pin change state from LOW to HIGH? (or HIGH to LOW, however you count the pulse)
  Yes -- add 1 to pulse count
  Is pulse count > what you want?
    Yes -- do whatever you do when pulse count has reached the limit
    Zero pulse count
  Save the pin state so you know when it changes again.
  Did the pin change state from HIGH to LOW?
    Yes -- save the pin state so you know when it changes again.
End loop() -- takes you back to the Start
What is missing is "whatever you do when pulse count has reached the limit".
Do that with the least steps possible. You should be able to get away with serial print given the long pulse times you first posted (longer than a second? with tight code, 10 millis is long!) and the 100-120 pulses you're counting. The great majority (over 99%) of passes through loop() would see no change in pin state at all. Count those (use an unsigned or unsigned long) and see, you will likely be surprised and maybe learn how really fast loop code is.
ali_jamil
did u solved your problem ?
because i have same project
i want to count heart beat then display it on LCD
hope u got the solution
GoForSmoke
You know those finger-tip-clamp pulse monitors at hospitals? I wonder if they work by light reflected or light passed through the very finger tip? There is a bright red light without heat involved.
I imagine a piezo could do the job of electronic stethoscope. Biggest part of that is separating heart beat from other body noises. Piezo is sensitive enough given that they can be used to detect ants walking on them.
https://www.youtube.com/watch?v=8ZVFKvgJQtA
