Author Topic: Using Arduino uno to burn bootloader error  (Read 472 times)
Try to burn bootloader on to blank chips atmega328P
I get this error after about a minute
Error while burning bootloader
avrdude: stk500_getsync(): not in sync: resp=0x00
Dallas
Shannon Member
Three possibilities...
• Wiring between the programmer (your Uno) and the target (the ATmega328P)
• Auto-reset not disabled on the programmer
• No external clock on the target
Auto-reset not disabled on the programmer I pulled the chip from the uno and hooked it up on the bread board with 16mhz crystal just as it is on the the uno Im doing it like this
http://www.gammon.com.au/forum/?id=11637
Dallas
Shannon Member
When you wrote this...
...did you actually mean something like this...
I burned the bootloader on to blank atmega328P chips as describe by Nick Gammon on his site (http://www.gammon.com.au/forum/?id=11637).  When I try to use the chips, I get this error...
Brisbane, Australia
Are you using Nick's sketch? That doesn't look like one of his errors, but one from the ArduinoISP sketch?
I burned it with no problem on my old computer.
Brisbane, Australia
Can you take a photo of your present setup and post that, along with confirmation of the actual sketch you're using?
I hooked the board as in the picture I posted in post 2 I used the sketch that comes with the arduino ide ver 1.0.3  windows 7
It's just sat there and then it would pop up a error that I posted changed to my old laptop which has ver1.0.2 of the ide and windows XP  and it happly burned all 3 chips .
// ArduinoISP version 04m3
// Copyright (c) 2008-2011 Randall Bohn
// If you require a license, see
//     http://www.opensource.org/licenses/bsd-license.php
// This sketch turns the Arduino into a AVRISP
// using the following arduino pins:
// pin name:    not-mega:         mega(1280 and 2560)
// slave reset: 10:               53
// MOSI:        11:               51
// MISO:        12:               50
// SCK:         13:               52
« Last Edit: January 12, 2013, 11:25:59 pm by be80be » Logged
