Topic: I don't seem to understand C++ (Read 900 times) previous topic - next topic
RCork
Jan 13, 2013, 10:52 am Last Edit: Jan 13, 2013, 08:34 pm by RCork Reason: 1
c++ stuff
I program in c and I cannot find any help with this problem in the C++ searches I have done.
I am accessing several DHT11 packages.  I am using the dht11 lib which seems to be written in C++
I am trying to use a function to process the serial data received from each of the packages.
my problem is I am trying to use a pointer to each package's data.
proper includes
#include <dht11.h>
I declared the objects
dht11 DHT11one;
dht11 DHT11two;
//then within the loop I will call each one and send it to:
void loop
 int chk1 = DHT11one.read(DHTPIN1);
 int chk2 = DHT11two.read(DHTPIN2);
 doTemp( &DHT11one);
 doTemp( &DHT11two);
void doTemp(dht11 *DHT11chk)
 float aTemp = *DHT11chk.temperature;
 do other stuff ... (store the temperature in a array, calc the average and send it to a display)
I guess I do not understand C++ but this does not work.  it tells me that DHT11chk is not declared within this scope
any and all help is appreciated!
Moderator edit: [code] [/code] tags added.
Author edit: clarify some information and correct a typo.
Coding Badly
proper includes
What does that mean?
marco_c
Even in C the parameter passed as a pointer would be declared as type *varname, not &varname.
Arduino Libraries https://github.com/MajicDesigns?tab=Repositories
Parola for Arduino https://github.com/MajicDesigns/Parola
robtillaart
Try to get a copy of Kerningham and Ritchie C 2nd edition to learn some basics about C pointers
also a good learner = http://www.cplusplus.com/reference/cctype/
Rob Tillaart
Chaul
This is where you create an instance of the class.
dht11 DHT11one;
This could do without the &-symbol, if you have defined the function to take a reference to the instance in.
doTemp( &DHT11one);
But, if it says dht11 has not been declared, you must not have included a header before you created the instance in the first place. And the type name is case-sensitive.
The pointer symbol here looks a little weird, but it does depend on what the temperature is returned as from the library. I assume it's a float anyways, and I think it would work better without the pointer symbol for what you are trying to do with it.
float aTemp = *DHT11.temperature;
