Loading...
Pages: [1]   Go Down
Author Topic: new column of data in Serial Monitor  (Read 453 times)
Offline Offline
Newbie
View Profile
hello,
in arduino serial monitor, I acquire three columns of different data seperated with tab "Serial.print("\t");  "
If I read that data in Matlab, it doesn't recognise those data as three columns, but one.
is there any "Serial.print("???")" that helps to write each data in next column, that Matlab will be able to recognise it as next column?
thanks
Logged
Global Moderator
Dallas
Online Online
Shannon Member
View Profile
WWW
You will have to provide more detail.  For example, are you using regexp?
I frequently use tab as separator.  In general it's a good choice for text data.
Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
IIRC matlab uses a ; or a , as default separator. Try one of those
Can you post your matlab code?
And Arduino code ?
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Offline Offline
Newbie
View Profile
Hello,
this is one part of arduino code
Code:
Serial.print("\t");
  Serial.print(freq(), DEC);
  Serial.print("\t");
  Serial.print("");
  Serial.print(osvet(), DEC);
  Serial.println("\t");
it gives me this results on Serial Monitor (where the left column is counter), and the other two columns are other data
Code:
1 800 86956
2 800 86956
3 790 85869
4 790 85869
5 780 84782
6 780 84782
7 780 84782
8 780 84782
9 780 84782
10 790 85869
Ok, now I want to read this in Matlab
Code:
s = serial('COM4', 'BaudRate', 9600);
fopen(s);
for i= 1:2000
data=fscanf(s);
y(i)=str2double(data);
plot(i,y(i));
drawnow;
hold on
end
fclose(s);
but I want to plot third column (y), and first coulmn (x)...
actually I want to do that:
Code:
plot(data(:,1),data(:,3);
drawnow;
so, is it possible, and how?
thank you for your help!!!
« Last Edit: January 14, 2013, 06:59:42 pm by oximeter » Logged
Global Moderator
Dallas
Online Online
Shannon Member
View Profile
WWW
Try this...
Code:
  data=fscanf( s, '%d %d %d', 3 );
Logged
Offline Offline
Newbie
View Profile
I tried, but it doesn't work...it doesn't read third column...  smiley-sad
Logged
Offline Offline
Newbie
View Profile
as I know, arduino writes results as "string", so I wrote this code in Matlab:
Code:
data=fscanf( s, '%s',3 )
plot(i,y(i));
drawnow;
hold on
ok, it gives me something, but it is not correct... :/
and another question: How can I connect dots in "real time" graph in Matlab? I have discrete measurments, and it plot me only seperated points...
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Why are you using single quotes around strings? In C, at least, single quotes are for characters, and double quotes are for strings.
Logged
Netherlands
Offline Offline
Tesla Member
View Profile
if i look at this  - http://www.mathworks.nl/help/matlab/ref/fscanf.html -
Code:
% Create a file with an exponential table
x = 0:.1:1;
y = [x; exp(x)];
fid = fopen('exp.txt', 'w');
fprintf(fid, '%6.2f %12.8f\n', y);
fclose(fid);
% Read the data, filling A in column order
% First line of the file:
%    0.00    1.00000000
fid = fopen('exp.txt');
A = fscanf(fid, '%g %g', [2 inf]);
fclose(fid);
% Transpose so that A matches
% the orientation of the file
A = A';
looks like you miss the fid ?
Logged
Rob Tillaart
Pages: [1]   Go Up
Print
Jump to:
