Author Topic: new column of data in Serial Monitor  (Read 449 times)
hello,
in arduino serial monitor, I acquire three columns of different data seperated with tab "Serial.print("\t");  "
If I read that data in Matlab, it doesn't recognise those data as three columns, but one.
is there any "Serial.print("???")" that helps to write each data in next column, that Matlab will be able to recognise it as next column?
thanks
Dallas
Shannon Member
You will have to provide more detail.  For example, are you using regexp?
I frequently use tab as separator.  In general it's a good choice for text data.
Netherlands
IIRC matlab uses a ; or a , as default separator. Try one of those
Can you post your matlab code?
And Arduino code ?
Rob Tillaart
Hello,
this is one part of arduino code
Serial.print("\t");
  Serial.print(freq(), DEC);
  Serial.print("\t");
  Serial.print("");
  Serial.print(osvet(), DEC);
  Serial.println("\t");
it gives me this results on Serial Monitor (where the left column is counter), and the other two columns are other data
1 800 86956
2 800 86956
3 790 85869
4 790 85869
5 780 84782
6 780 84782
7 780 84782
8 780 84782
9 780 84782
10 790 85869
Ok, now I want to read this in Matlab
s = serial('COM4', 'BaudRate', 9600);
fopen(s);
for i= 1:2000
data=fscanf(s);
y(i)=str2double(data);
plot(i,y(i));
drawnow;
hold on
end
fclose(s);
but I want to plot third column (y), and first coulmn (x)...
actually I want to do that:
plot(data(:,1),data(:,3);
drawnow;
so, is it possible, and how?
thank you for your help!!!
« Last Edit: January 14, 2013, 06:59:42 pm by oximeter » Logged
Dallas
Shannon Member
Try this...
  data=fscanf( s, '%d %d %d', 3 );
I tried, but it doesn't work...it doesn't read third column...  smiley-sad
as I know, arduino writes results as "string", so I wrote this code in Matlab:
data=fscanf( s, '%s',3 )
plot(i,y(i));
drawnow;
hold on
ok, it gives me something, but it is not correct... :/
and another question: How can I connect dots in "real time" graph in Matlab? I have discrete measurments, and it plot me only seperated points...
Seattle, WA USA
Seattle, WA USA
Why are you using single quotes around strings? In C, at least, single quotes are for characters, and double quotes are for strings.
Netherlands
if i look at this  - http://www.mathworks.nl/help/matlab/ref/fscanf.html -
% Create a file with an exponential table
x = 0:.1:1;
y = [x; exp(x)];
fid = fopen('exp.txt', 'w');
fprintf(fid, '%6.2f %12.8f\n', y);
fclose(fid);
% Read the data, filling A in column order
% First line of the file:
%    0.00    1.00000000
fid = fopen('exp.txt');
A = fscanf(fid, '%g %g', [2 inf]);
fclose(fid);
% Transpose so that A matches
% the orientation of the file
A = A';
looks like you miss the fid ?
Rob Tillaart
