Pages: [1] 2 3   Go Down
Author Topic: if pin 1 is high in 3seconds led will turn on else ignore .(if statement .help.)  (Read 771 times)
isabela, philippines.
if you dont go, you will never know.
this is the situation, press the switch in more than 3 seconds before the led turn on unless it wont.
my idea didnt work.
if ( button, HIGH) {
x + 1;
x + 1;
if (button, HIGH) {
x + 1;
if ( x == 3) {
digitalwrite( "leds turns on")
x = 0;
else {
x=0;
just give me the idea.
jaylisto
Seattle, WA USA
Seattle, WA USA
It is highly unlikely that the comma operator is doing what you think it is doing. You can't just invent a "command" and expect it to work.
There is a function to read the state of a digital pin. You should figure out what that digitalRead() function is, and how to use it.
Seattle, WA USA
Seattle, WA USA
Oh, and adding 1 to x and discarding the result is an exercise in futility.
Malaysia
it should be something along this line
if (Switch==HIGH)
 x++;
 if (x==3)
   digitalWrite(LED,HIGH);
   x=0;
if (Switch==HIGH)
 x++;
 if (x==3)
   x=0;
thank you very much with this sir. ill try this style.
but i think if you press the switch 3 times it will light up. (not holding the switch) . though ill just try it if it works..
jaylisto
UK
Your code:
Should be :
if(digitalRead(button) == HIGH) {
Your code:
x + 1;
Should be:
x = x + 1;
Your code layout makes it very difficult what your control structure is.
Please adopt the habit of putting each { and } on separate lines, with matching pair indented by the same amount, and with the code between them indented one extra level. It makes it much, much easier for us (and you) to understand the structure of the code and also to spot where the structure is not what you intended.
Your code:
Should be :
Your code:
x + 1;
Should be:
x = x + 1;
pls give me the answer coz my program didnt work. i repeat, there is no problem with the correct code. i only did that for representation (i know its wrong)
this is a very simple problem, though no one can answer even me.
the solution for my answer, i think...
check if the switch is high
delay (100)
check if the switch still high
delay (100)
delay (100)
turn on the led
but how can i transfer this to a code or something?.
if no one can help me then
ill keep trying to solve this problem.
jaylisto
Seattle, WA USA
Seattle, WA USA
Then post that code.
if (Switch==HIGH)
 x++;
 if (x==3)
   x=0;
woohooooooo. yes! it works! for all the answer out their. this is the only one made me smile  smiley-mr-green,
 very good sir, thank you very much!. you only use looping but its the same with mine. what exactly is the one second as a delay? is it delay(1000)?
. you really help me sir. thank you very much.
Moderator edit: gibberish removed
« Last Edit: January 14, 2013, 01:36:36 pm by AWOL » Logged
jaylisto
const int buttonPin = 2;
const int ledPin =  11;
int x = 0;
int buttonState = 0;
  pinMode(ledPin, OUTPUT);
  pinMode(buttonPin, INPUT);
void loop(){
  if (buttonState == HIGH) {
  x++;
    delay(1000);// turn LED on:
   if (x==3) {
    digitalWrite(ledPin, HIGH);
    x=0;
  else {
    digitalWrite(ledPin, LOW);
« Last Edit: January 14, 2013, 01:51:00 pm by AWOL » Logged
jaylisto
East Anglia (UK)
May all of your blinks be without delay
Does that code do what you want ?
What happens if the user presses the button for 2.5 seconds then releases it ?
What will the value of x be then ?
What value will x have after the user now presses the button for 1 second ?
Malaysia
Im sorry jaylisto, The program that i gave to you does not do what you need it to do. I thought you need to press the switch 3 time b4 the led will light up. so its does not do acording to what you want.
btw i want to say its not good that you anger all those post a reply for your question. those people have help me learn alot.
Queens, New York
"Of all the things I've ever lost, I miss my mind the most" -Ozzy Osbourne
int buttonState = LOW;
int  lastReading = LOW;
long onTime = 0;
void loop(){
  if (buttonState == HIGH && lastReading == LOW) {
    onTime = millis();
//held
  if (buttonState == HIGH && lastReading == HIGH) {
    if ((millis() - onTime) > 3000 ) { //(current time - first pressed time) must be greater than 3000 (3 seconds)
       lastReading = LOW; //reset state
  else {
  lastReading = buttonState; //write button to lastreading for compare
I can not try this myself right now, but it should work.
« Last Edit: January 14, 2013, 11:30:57 am by HazardsMind » Logged
UNO, MEGA, NANO, 4x4 keypad, micro servos, RF transceivers, bluetooth, ultrasonic sensor, 20x4 I2C LCD, 3.2 TFT touch screen, L298N Dual motor driver, Voice Recognition 15W, Gameduino
Arduino Tutorials, coming soon.
"If your doing nothing, it does not mean your lazy, it just means your open for anything that suits you" - Unknown
California
Of course, there are always people who will write code for others despite any attitude problems.
UK
I've removed a lot of invective and insults from this thread.
OP, if this continues, this thread goes and your account risks going with it.
« Last Edit: January 14, 2013, 01:50:06 pm by AWOL » Logged
Pages: [1] 2 3   Go Up
