Topic: Arduino leonardo + sd (Read 4246 times) previous topic - next topic
gio03gio
Hello, I am a novice user of arduino.
I can not get arduino leonardo communicate with the sd card.
I wanted to know if someone actually succeeded and attach code + scheme
Thank you for your time spent
ciao sono un utente inesperto di arduino.
Non riesco a far comunicare arduino leonardo con la scheda sd.
Volevo sapere se  qualcuno realmente sia riuscito e allegare codice + schema
Grazie per il vostro tempo dedicato
PaulS
Quote
The Leonardo doesn't have an SD card. Perhaps that is the problem.
If you added one, defining which one, and how it is connected, and what code you are using, and what problems you are having, might be useful things to do.
gio03gio
but is possible to comunicate ?
SurferTim
It should be no problem. If you want help, answer the questions PaulS posted.
Bear in mind the SD library uses SPI, and the SPI data lines on a Leonardo are available only on the ICSP connector. They are not available on any digital pins.
fat16lib
The Ethernet shield works fine .
It is also possible to use SdFat on Leonardo with software SPI.  This allows Uno style SD shields to be used.  I posted Leonardo software for the Adafruit data logging shield here AdafruitLogger20121219.zip http://code.google.com/p/beta-lib/downloads/list.
SurferTim
Thanks, fat16lib. Just one condition:
If the ethernet shield is the new type with the ICSP connector, it will work fine. The older versions without the ICSP header on the bottom will not work without serious pin bending.
gio03gio
hi fat16lib
I bought Adafruit data logger
I downloaded the file but can not compile it.
Could you explain how you did it?
thanks
PaulS
Quote
What file? There are at least two files available to download from the internet. Maybe even more.
What version of the IDE are you using?
Why can't you click the Verify button in the IDE?
fat16lib
Quote
thanks
How did you install the libraries and what are the error messages?  Did you copy the libraries I2cMaster,  SdFat, and SoftRTClib, to your libraries folder?
SurferTim,
Quote
I forgot the R1 Ethernet shield.  The R1 Ethernet SD should work with software SPI.
gio03gio
thanks I managed to solve the problem
ilovetoflyfpv
Hi gio03gio
I have recently purchased a Arduino Leonardo with the intention of using it with the Adafruit Data Logger. I was wondering how you managed to get it to work?
Cheers
Jase  :)
