Loading...
Pages: 1 [2]   Go Down
Author Topic: Cheap small capacity SD Cards?  (Read 529 times)
Washington
Offline Offline
God Member
Firefox & Arduino rocks
View Profile
Maybe it doesn't comply with the recommended interrogation sequence?  There's a flowchart in the SD specs showing you how to properly differentiate.  It's backward compatible.  If you (as a designer) just initialize and go, instead of probing and verifying behavior, you may end up using the wrong command set.  Just a guess.
So it is not really backwards compatible... If the device is not aware of SDHC than it will fail.
Logged
Avoid throwing electronics out as you or someone else might need them for parts or use.
Solid state rectifiers are the only REAL rectifiers.
Resistors for LEDS!
Anchorage, AK
Offline Offline
Sr. Member
View Profile
Uh... yeah, OK.  Point taken.  I guess I was looking at it the other way around.  An SDHC-compatible reader must... as in, per the spec, absolutely must... know how to tell the difference between SDHC, SD, and MMC cards.  But you're right, there's no guarantee that a new card would work in an old reader that's not aware of fixed block addressing and whatnot.
Logged
Washington
Offline Offline
God Member
View Profile
Thats the problem I have. Lots of old devices.
Logged
Resistors for LEDS!
Pages: 1 [2]   Go Up
Print
Jump to:
