Must admit all that with the graphs went over my head
I now have another issue, and would welcome comments.
I've breadboarded the chip neatly, and tested it using the example blink and fade examples - worked fine. I then breadboarded the 1307 RTC chip and uploaded the sample code below (found on this forum)
* Read and set through serial port demo sketch for DS1307 I2C rtc clock
* DS1307 library provided by mattt & D.Sjunnesson, corrected by bricofoy.
* See DS1307.h for more details.
* This exemple code is under GNU GPL
* (c) bricofoy 2012
// This is for compatibility with both arduino 1.0 and previous versions
#if defined(ARDUINO) && ARDUINO >= 100
#include "Arduino.h"
#else
#include "WProgram.h"
#endif
#include <Wire.h>
#include <DS1307.h>
use();
read_RTC();
// use explanation message
void use() {
Serial.println("\nUSE : u U r R h[00-23]m[00-59]s[00-59]j0[1-7]D[01-31]M[01-12]A[00-49]");
Serial.println("\nEXEMPLE : h09m35d03 set time to 09h35 and day of week 3 (thuesday).");
Serial.println("\nCommands : h** : hour, m** : minutes, s** : seconds, d0* : day of week");
Serial.println(" M** : month, Y** : year, D** : day of month.");
Serial.println(" r stops clock, R starts it. ");
Serial.println(" u or U shows this message, all other caracter shows time.");
// DS1307 time read function
void read_RTC() {
Serial.print("\nActual time : ");
Serial.print(RTC.get(DS1307_HR,true)); //read the hour and also update all the values by pushing in true
Serial.print(":");
Serial.print(RTC.get(DS1307_MIN,false));//read minutes without update (false)
Serial.print(":");
Serial.print(RTC.get(DS1307_SEC,false));//read seconds
Serial.print(" "); // some space for a more happy life
Serial.print(RTC.get(DS1307_DOW,false));
Serial.print(" ");
Serial.print(RTC.get(DS1307_DATE,false));//read date
Serial.print("/");
Serial.print(RTC.get(DS1307_MTH,false));//read month
Serial.print("/");
Serial.println(RTC.get(DS1307_YR,false)); //read year
// set clock values
void write_RTC() {
char value=0;
char command=0;
command = Serial.read();
delay(50); //delay to allow good serial port reading
value=byte((Serial.read()-48)*10); //-48 becaus ASCII value for 0 is 48, 1 is 49, etc and *10 because we read tens first
delay(50);
value+=byte((Serial.read()-48)); //and then we read units
switch (command) {
case 'h' :
RTC.set(DS1307_HR,value);
Serial.print("hours set to ");
Serial.println(value,DEC);
break;
case 'm' :
RTC.set(DS1307_MIN,value);
Serial.print("minutes set to ");
break;
case 's' :
RTC.set(DS1307_SEC,value);
Serial.print("seconds set to ");
break;
case 'D' :
RTC.set(DS1307_DATE,value);
Serial.print("day of month set to ");
break;
case 'd' :
RTC.set(DS1307_DOW,value);
Serial.print("day of week set to ");
break;
case 'M' :
RTC.set(DS1307_MTH,value);
Serial.print("month set to ");
break;
case 'Y' :
RTC.set(DS1307_YR,value);
Serial.print("year set to ");
break;
case 'u' :
case 'U' :
use();
break;
case 'r' :
RTC.stop();
Serial.println("Clock stopped");
break;
case 'R' :
RTC.start();
Serial.println("Clock running");
break;
default :
break;
read_RTC();
if (Serial.available()) {
write_RTC();
This is (if I ready the details correctly) will display the date / time via the serial monitor, which is fine as I don't have an LCD hooked up yet. The code compiled and loaded without error, but when I launched the serial monitor I got the message that the port was in use and I needed to close other applications. So I tried uploading the basic blink example and got the same message... it seems that the code running won't free up the com port
Any suggestions ?
Malcolm
