Author Topic: turn lights on and off using real time clock ds1307  (Read 344 times)
Poledust.com
I am wondering if converting the time from 24hr to 12hr is going to interfere with the part of code that will turn on the ledpin and off at set times
#include <dht11.h> //this is for the temp and humidity sensor
#include <LiquidCrystal.h>
#include <Wire.h>
#include "RTClib.h"
#include <DateTime.h>
//#include <RTClib.h>
LiquidCrystal lcd(7, 8, 9, 10, 11, 12);
int hiTemp  = 30;//this  will activate relay 1 witch will turn on fan 1
int hiHumidity = 32;//this  will activate relay 2 witch will turn on fan 2
int lowTemp = 34;//this  will activate relay 3 witch will turn on heat lamp
int lowHumidity = 36;//this  will activate relay 4 witch will turn on mister
int ledPin = 13;
//PHOTOCELL VALUES
int sensorMin = 1023; // minimum photo sensor value
int sensorMax = 0; // maximum photo sensor value
const int sensorPin = A0;// select the input pin for the photocell
int sensorValue = 0;// variable to store the value coming from the photocell sensor
int tempPin = 2;//Temp and humidty pin
int ack;
int chk;
int count = 0;
char cmd = 0;
byte temppin = 0;
[[color=red]color=red][font=Verdana]byte startHour = 13;    // Set our start and end times
byte startMinute = 33;  // Don't add leading zero to hour or minute - 7, not 07
byte endHour = 13;      // Use 24h format for the hour, without leading zero
byte endMinute = 34;
byte validStart = 0;    // Declare and set to 0 our start flag
byte poweredOn = 0;     // Declare and set to 0 our current power flag
byte validEnd = 0;      // Declare and set to 0 our end flag
[/color]
dht11 DHT11;  //this is for the temp and humidity sensor
RTC_DS1307 RTC;
    Wire.begin();
    RTC.begin();
    lcd.begin(20, 4);
    DHT11.attach(2);
    if (! RTC.isrunning())
      lcd.setCursor(0,0);
   lcd.println("RTC is NOT running!");
    // following line sets the RTC to the date & time this sketch was compiled
     RTC.adjust(DateTime(__DATE__, __TIME__));
    delay(4000);
   lcd.clear();
     //PIN MODES
   pinMode(hiTemp, OUTPUT);  //this  will activate relay 1 witch will turn on fan 1
   pinMode(hiHumidity, OUTPUT);//this  will activate relay 2 witch will turn on fan 2
   pinMode(lowTemp, OUTPUT);//this  will activate relay 3 witch will turn on heat lamp
   pinMode(lowHumidity, OUTPUT); //this  will activate relay 4 witch will turn on mister
 [color=red]  pinMode(ledPin, OUTPUT);// Set our LED as an output pin
    digitalWrite(ledPin, LOW); // Set the LED to LOW (off)[/color]
   //WELCOME SCREEN
   lcd.setCursor(0,0);
   lcd.print("Starting up");
   lcd.setCursor(0,1);
   lcd.print("*** WELCOME! ***");
   lcd.setCursor(0,3);
   lcd.print("Initializing");
     delay(4000);
   lcd.clear();
//LIGHTS ON/OFF LOGIC
sensorValue = analogRead(sensorPin);    // read the analog input pin
  if (sensorValue < 300)
   // Serial.println("LIGHTS OFF  ");
  //  Serial.println(sensorValue);    // print to screen
    lcd.setCursor(0,3);
    lcd.print ("Lights     OFF ");
    lcd.print (sensorValue);
      delay(50);
      // Serial.println ("Lights  ON");
   lcd.setCursor(0,3);
   lcd.print ("Lights     ON  ");
}//END SETUP
//START DISPLAY OF TEMPERATURE READINGS
//void checkTEMP();
  int chk = DHT11.read();  //this is for the temp and humidity sensor
 //  switch (chk)
   lcd.setCursor(0,2);
   lcd.print("Humidity    %  ");
   lcd.print((float)DHT11.humidity);
   lcd.setCursor(0,1);
   lcd.print("Temperature F  ");
   lcd.print(DHT11.fahrenheit());
    DateTime now = RTC.now();
if (now.month()<10)
  lcd.setCursor(0,0);
  lcd.print(" ");
  lcd.setCursor(1,0);
  lcd.print(now.month(), DEC);
  lcd.setCursor(2,0);
  lcd.print("/  ");
lcd.setCursor(0,0);
lcd.setCursor(2,0);
lcd.print("/  ");
if (now.day()<10)
    lcd.setCursor(3,0);
  lcd.print(" ");
  lcd.setCursor(4,0);
    lcd.print(now.day(), DEC);
    lcd.setCursor(5,0);
    lcd.print("/    ");
        lcd.setCursor(6,0);
    lcd.print(now.year(), DEC);
  lcd.setCursor(3,0);
    lcd.setCursor(5,0);
    lcd.print("/    ");
        lcd.setCursor(6,0);
[color=red]    int hr_24, hr_12;// liudr
hr_24=now.hour();
if (hr_24==0) hr_12=12;
else hr_12=hr_24%12;
 if (hr_12<10)[/color]
lcd.setCursor(12,0);
lcd.print("  ");
 lcd.setCursor(13,0);
lcd.print(hr_12, DEC);
lcd.setCursor(18,0);
if (hr_24<12) lcd.print("AM");
else lcd.print("PM");
    lcd.print("  ");
//... everything in between now last line:
 //     lcd.setCursor(11,0);
 //   lcd.print("   ");
// lcd.setCursor(12,0);
//lcd.print(now.hour(), DEC);
    lcd.setCursor(14,0);
    lcd.print(":  ");
    if (now.minute()<10)
 lcd.setCursor(15,0);
lcd.print(" ");
 lcd.setCursor(16,0);
lcd.print(now.minute(), DEC);
 // lcd.setCursor(15,0);
    //lcd.print(now.minute(), DEC);
   delay(3000);
[color=red]  if (now.second() == 0){ // Only process if we have ticked over to new minute
    if (poweredOn == 0){  // Check if lights currently powered on
      checkStartTime();    // If they are not, check if it's time to turn them on
      checkEndTime();      // Otherwise, check if it's time to turn them off
    if (validStart == 1)
    { // If our timer is flagged to start, turn the lights on
      turnLightsOn();
    if (validEnd == 1)
    {   // If our time is flagged to end, turn the lights off
      turnLightsOff();
byte checkStartTime()
  DateTime now = RTC.now();  // Read in what our current datestamp is from RTC
  if (now.hour() == startHour && now.minute() == startMinute)
    validStart = 1;  // If our start hour and minute match the current time, set 'on' flags
    poweredOn = 1;
    validStart = 0;  // Otherwise we don't need to power up the lights yet
  return validStart; // Return the status for powering up
byte checkEndTime()
  if (now.hour() == endHour && now.minute() == endMinute)
    validEnd = 1;    // If our end hour and minute match the current time, set the 'off' flags
    poweredOn = 0;
    validEnd = 0;    // Otherwise we don't need to power off the lights yet
  return validEnd;   // Return the status for powering off
void turnLightsOn()
  digitalWrite(ledPin, HIGH);  // Turn on the LED
void turnLightsOff()
  digitalWrite(ledPin, LOW);   // Turn off the LED
}[/color]
« Last Edit: January 13, 2013, 07:52:11 pm by poledust » Logged
When you cant get to the Club to see them Dance! Mingle with Exotic Dancers at Poledust.com!
East Anglia (UK)
May all of your blinks be without delay
Please edit your post and put code tags around your code.
Norfolk UK
As your startHour is 13 then switching the RTC to 12 hour mode will effect the on/off time in that the hour will never get to 13 and the lights wont turn on. If you have a lower value for startHour (say 7) then the lights will come on at 7 in the morning and 7 in the evening, maybe not what you wanted. Best to keep the RTC in 24 hour mode and if you want a 12 hour display with AM/PM indicator then convert the hours value on the fly to 12 hour format.
