Topic: Printing temperature probe data in Processing (Read 2125 times) previous topic - next topic
Phil125
I want to create a GUI using processing to display 3 temperature probes I have connected to my  Arduino.
I am able to get Processing to read the data. I have not seen anything about how to display this data in a window with text.
Any help I can get would be greatly appreciated.  I am a very new to this program.
Example of the serial data processing is getting from the println.  3 printsof it.
70.25
70.25
70.25
70.2570
.2570.25
70.25
70.25
70.25
Thanks
Phil
Processing code:
// Example by Tom Igoe
import processing.serial.*;
PFont f;
Serial myPort;  // The serial port
  // List all the available serial ports:
  size(480, 480);
  println(Serial.list());
  // Open the port you are using at the rate you want:
  myPort = new Serial(this, Serial.list()[1], 9600);
  f = createFont("Arial",16,true);
void draw() {
  background(255);
  textFont(f,16);
  fill(0);
  text("TEMPERATURES:",10,50);
  text("Temp 1:",10,100);
  text("Temp 2:",10,150);
  text("Temp 3:",10,200);
  while (myPort.available() > 0) {
    String inBuffer = myPort.readString();
    if (inBuffer != null) {
      println(inBuffer);
Arduino Code:
#include <OneWire.h>
#include <DallasTemperature.h>
// Data wire is plugged into pin 3 on the Arduino
#define ONE_WIRE_BUS 3
// Setup a oneWire instance to communicate with any OneWire devices
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
// Assign the addresses of your 1-Wire temp sensors.
DeviceAddress T1 = { 0x28, 0x0E, 0xFF, 0xE9, 0x03, 0x00, 0x00, 0xFA };
DeviceAddress T2 = { 0x28, 0x0E, 0xFF, 0xE9, 0x03, 0x00, 0x00, 0xFA  };
DeviceAddress T3 = { 0x28, 0x0E, 0xFF, 0xE9, 0x03, 0x00, 0x00, 0xFA  };
void setup(void)
  // start serial port
  // Start up the library
  sensors.begin();
  // set the resolution to 10 bit (good enough?)
  sensors.setResolution(T1, 10);
  sensors.setResolution(T2, 10);
  sensors.setResolution(T3, 10);
void printTemperature(DeviceAddress deviceAddress)
  float tempC = sensors.getTempC(deviceAddress);
  if (tempC == -127.00) {
    Serial.print(" Error");
    Serial.print(DallasTemperature::toFahrenheit(tempC));
void loop(void)
  delay(2000);
  sensors.requestTemperatures();
  printTemperature(T1);
  printTemperature(T2);
  printTemperature(T3);
1
PaulS
There are several things you need to do. First, there needs to be some way for Processing to tell when one value ends and another begins. Right now, you are sending "70.2570.2570.25" to the serial port.
You need to have the Arduino use Serial.println() in printTemperature().
In Processing, handling serial data is not a task that draw() should perform. You need a serialEvent() callback that reads the serial data.
You need to add a myPort.bufferUntil() call to setup() to tell Processing to buffer data until some specific character, like a carriage return or a line feed, arrives.
These are headers and titles. Nowhere do you actually create text for the data.
Phil125
#2
Jan 14, 2013, 03:00 am Last Edit: Jan 14, 2013, 03:10 am by Phil125 Reason: 1
Understood
I was planning on using commas for delimiting between temperatures.
I understand they are headers and titles.  How to create text for the data was my main question.
Ok I have the first temperature working with serialEvent().  Getting there.
PaulS
The serial data is coming in as text. You are collecting it in some variable in serialEvent(). Use another text() call, with that variable and the location where you want the text to appear.
