Loading...
Pages: [1]   Go Down
Author Topic: which is best Wifi shield for arduino?  (Read 3300 times)
Offline Offline
Newbie
View Profile
 :)Hello! Anyone,
Any suggest which wifi shield best work for Arduino?
Also, any app for iphone to use iphone as the remote control?
Thank you!
Logged
0
Offline Offline
Edison Member
Arduino rocks
View Profile
WWW
Try the "official" arduino wifi shield:
http://store.arduino.cc/ww/index.php?main_page=product_info&cPath=11_5&products_id=237
Sparkfun sells one which is a bit cheaper:
https://www.sparkfun.com/products/9954
If you run a web server on your arduino with the wifi shield, you can access it through your iPhone through the browser.
Logged
Austin, TX
Offline Offline
Faraday Member
CMiYC
View Profile
WWW
What is your definition of "best"?
Logged
www.cmiyc.com - A guide to being an Enginerd
Offline Offline
Newbie
View Profile
Hi
I am looking for the same answer as Tonyzhang.
Which Wi-Fi shield is the best one for arduino (or other arduino "compaible" controller boards)
My defintion of best would be :
the one which have the more possibilities (supported protocols b/g/n..., supported encryption)
the fastest one (throughput speed, limited of course by the Arduino communication speed itself)
and maybe some other parameters i may have forgotten or not familiar with
Thanks smiley
Logged
Austin, TX
Offline Offline
Faraday Member
CMiYC
View Profile
WWW
That would be most of them since all of that has to be handled on the shield itself and not by the ATmega.
That would be all of them.
Since cost isn't a concern, get the Official Arduino Shield.
Logged
Washington, DC
Offline Offline
Newbie
Changes are never trivial.
View Profile
WWW
We just released this:  http://www.dexterindustries.com/Arduino-WIFI_Shield.html
« Last Edit: November 02, 2012, 06:24:28 pm by Johnny D » Logged
Offline Offline
Newbie
View Profile
Hey, Johnny, what's the power consumption like for your module?
Do you have a wiki page similar to http://www.dfrobot.com/wiki/index.php/WiFi_Shield_V2.1_For_Arduino_(SKU:TEL0047) ?
Logged
Washington, DC
Offline Offline
Newbie
View Profile
WWW
Hey,
The module draws about 7uA in standby, and a max of 250 mA at a transmit rate of 11 MB/Sec.
You can see the wiki we have for the module here:   http://www.dexterindustries.com/manual/arduino-shields/arduino-wifi-shield/
Logged
Offline Offline
Newbie
View Profile
Thanks for quick reply!
How do you put it into standby mode? Do you have any examples?
Is it cid_disconnect(int)?
Hey,
Logged
Washington, DC
Offline Offline
Newbie
View Profile
WWW
Request Standby Mode is in section 4.12.2 in the Gainspan Module manual.  It says:
AT+PSSTBY=x[,<DELAY TIME>,<ALARM1 POL>,<ALARM2 POL>]
The parameters are:
 x is the Standby time in milliseconds. If a delay time (see below) is provided, the Standby count
begins after the delay time has expired.
 DELAY TIME is the delay in milliseconds from the time the command is issued to the time when
the SOC goes to Standby.
 ALARM1 POL is the polarity of the transition at pin 31 of the SOC which will trigger an alarm
input and waken the GainSpan SOC from Standby. A value of 0 specifies a high-to-low
transition as active; a value of 1 specifies low-to-high.
 ALARM2 POL is the polarity of the transition at pin 36 that triggers an alarm input, using the
same convention used for Alarm1.
The parameters DELAY TIME, ALARM1 POL, and ALARM2 POL are optional. Specifying an alarm
polarity also enables the corresponding alarm input.
We don't have an example up of how to go into Standby.  However, it is in this documentation here:  http://www.dexterindustries.com/files/DI-WIFI_Sensor.pdf
Logged
Shanhghai
Offline Offline
Newbie
DFRobot Tech Support
View Profile
WWW
Try this  http://www.dfrobot.com/index.php?route=product/product&filter_name=wifi&product_id=548#.UUSf0VvN_kw
It uses a mature WizFi210 chip. It provides the bridging from TTL serial port communication to IEEE802.11b/g/n wireless communication. So any device with TTL serial ports can easily be connected with this WIFI module and controlled and managed remotely through a wireless network. Different kinds of communication protocols and encryption algorithms are integrated with the module. The Arduino architecture enables you to easily integrate this module into any Arduino based project.
Logged
DFRobot-Drive The Future
Official Technical Support for DFRobot Product
www.DFRobot.com
Smithfield, Rhode Island
Offline Offline
God Member
View Profile
The "best" one is the one I am working on, since it does not yet exist. It will:
- Allow operation as an access point
- Have a web server built in
- Have extra memory for storing web content
- Talk to the Arduino host board using I2C or SPI (or both) in addition to offering the UART.
So far, I have yet to find this. There are a few based on the Ganispan 1.2 device, but this has limitations that prevent it from using the latest GS firmware. The official Arduino wifi shield uses SPI, which is great, but the HDG104 has limitations that prevent it from meeting my needs.
Its been frustrating, but I determined that I need to build my own.
Logged
Pages: [1]   Go Up
Print
Jump to:
