Author Topic: BPM (Beats per Minute) detection program - my version  (Read 783 times)
utah
Okay so, after many months of study and tinkering, writing and re-writing code I finally made a working(at least with version 22) beat detection program it takes 10 seconds to get a rough beat and then starts honing in after 20 more seconds if I remember correctly... it's been a while since I messed with it. I found a much cooler solution to my problem and no longer need this code, but I put the absolute peak of my focus and effort into it for many months so it seems a waste to not share it.
  be nice to me I'm not a programmer and I only had one class of java in college. but I know enough to know that it's sloppy, not very well documented and downright confusing at some parts. for example, I start using some weird variables like "fruit" or "Fruity" my brain was fried and I needed a variable with a unique name... sorry. Despite all this I'll do my best to answer any questions.
keep in mind that beat detection is hard enough to do for a person and their instincts let alone to define it in an algorithm but this is still fun to see it respond to faster or slower beats even though it might be off a little (it's not as good as we all hope it was.) sometimes its dead on though.
when I started this project I knew nothing of Arduinos or micro controllers for that matter, but after lurking 100% (out of fear of angering grumpy Arduino community members) I learned a lot. in fact I feel that everyone needs to try and figure things out without making things a problem for someone else or at least until you are really stuck.
 I still don't feel like I belong posting anything on here cause I don't know very much. but I wanted to contribute this so here it is
oh and this is actually a two Arduino project, one for detecting the BPM and one for controlling animations on an 8X8 RGB LED matrix. if anyone is interested in the animation side of this project I'll post it in the appropriate section and add a link to it in this post.
  I fully intended on cleaning up this code and making it pretty and easy to understand but I am busy with other projects, a three year old, job, new business and life in general so this is what you get, sorry.
some things you'll need besides my code:
SimpleTimer library
you will also need this web site as reference as to how to hook up the MSGEQ7 chip for audio data input:
http://nuewire.com/info-archive/msgeq7-by-j-skoba/
utah
and finally my sketch:
/* Beat Detection Program
this program uses a MSGEQ7 chip to collect sound data,
the chip seperates the audio into 7 bands centered on 63hz, 160hz, 400hz, 1khz,
2.5khz, 6.25khz and 16khz(which from my tests is more like 15khz)
   then it takes the average of however many samples are in 1.25 seconds
and compares it to the current sample. If the current sample is higher
than the average multiplied by C, it counts a beat.
   it takes the average amounts of beats in ten seconds and converts that
to beats per minute.
  It then takes 60 divided by the average beats per minute and multiplies
it by 1000 to convert beats per minute into a delay to use between
animations.
  The animations are done on an eight by eight LED Matrix. I'm using four of the
74hc595 ic shift registers to extend the outputs of the Arduino Uno.
I used common cathode RGB LEDs so if the binary animations seem funny
it may be that you have common anode LEDs.
#include <Wire.h>
#include <SimpleTimer.h>
SimpleTimer timer;
                   // these are for the MSGEQ7
int analogPin = 0; // read from multiplexer using analog input 0
int strobePin = 2; // strobe is attached to digital pin 2
int resetPin = 3; // reset is attached to digital pin 3
int spectrumValue=0; // to hold a2d values
const int numReadings2 = 20;
const int numReadings3 = 20;
float readings2[numReadings2];       // the readings from the analog input
float readings3[numReadings3];
int index2 = 0;                  // the index of the current reading
int index3 = 0;
float total2 = 0.0;                  // the running total
float total3 = 0.0;
int average = 0;                // the average
float cycles2 = 0.0;
float cycles3 = 0.0;
float cyclesS2 = 0.0;
float cyclesS3 = 0.0;
float cyclesV = 0.0;
float cyclesV3 = 0.0;
float sumBPM2 = 0.0;
float sumBPM3 = 0.0;
//  int BperM2 = 0;
 float spectrumSum2 = 0.0;
 float spectrumSum3 = 0.0;
  float average2 = 0.0; //using
  float average3 = 0.0;
//  int average4 = 0;
//  int average5 = 0;  // not using these, I was thinking it would be cool to work in the different frequencies later.
//  int average6 = 0;
//  int average7 = 0;
  int holdValue1 = 0;   // this is for later if I want to do more with different frequencies.    frequency of 63 Hz
  int holdValue2 = 0;   // I'm currently using this one which is assigned the frequency of 160 Hz
  int holdValue3 = 0;   // not using frequency of 400 Hz
  int holdValue4 = 0;   // not using this one either    frequency of 1 KHz
  int holdValue5 = 0;   // or this    frequency of 2.5 KHz
  int holdValue6 = 0;   //or this    frequency of 6.25 KHz
  int holdValue7 = 0;   // or this frequency of 16 Hz (seems more like 15 KHz)
  int averageBPM1 = 0;  // not using
float aveBPM2 = 0.0;  // I'm using this
 float aveBPM3 = 0.0;  // and this
  int holdBeat2 = 0;
  int holdBeat3 = 0;
  int beat2 = 0;
  int beat3 = 0;
 unsigned long lastCycle ;
  int saveBPM2 = 0;
 unsigned long saveAverage = 0;
  int b = 0;
 unsigned long timesAround = 0;
 float aveBPerM = 0.0;
 float aveBPerM3 = 0.0;
 int Fruit = 0;
 int Fruit3 = 0;
 float variance = 0;
 float variance3 = 0;
 float C = 0;
 float C3 = 0;
 float averageVariance = 0;
 float averageVariance3 = 0;
 float greatestAverageVariance;
 float greatestVariance = 0;
 unsigned long varianceSum = 0;
 unsigned long varianceSum3 = 0;
 int holdBPMDelay = 0;
 double BPMDelay = 0.0;
 int trigger2 = 0;
 int trigger3 = 0;
 int greg2 = 0;
 int greg3 = 0;
int byteSending = 1;
//int toTransfer = 32767;
int Shift = BPMDelay;
int mask = 0xFF;
unsigned char toSend = 0;
int twenty2 = 0;
int twenty3 = 0;
  Wire.begin(0x52); // Start I2C Bus as slave
  Wire.onRequest(requestInt);
  Serial.print("new Session");
  pinMode(analogPin, INPUT);
  pinMode(strobePin, OUTPUT);
  pinMode(resetPin, OUTPUT);
  analogReference(DEFAULT);
  digitalWrite(resetPin, LOW);
  digitalWrite(strobePin, HIGH);
  delayMicroseconds(36);
  timer.setInterval(1250, BPM2);
  timer.setInterval(1250, BPM3);
  timer.setInterval(1250, ResetSec);
//  timer.setInterval(11250, AverageBPM2);
//  timer.setInterval(11250, AverageBPM3);
//  timer.setInterval(11250, ResetTenSec);
  timer.setInterval(11250, Fruity); // ran out of ideas for names so I chose Fruity all it does is switch a boolean statement
  for (int thisReading2 = 0; thisReading2 < numReadings2; thisReading2++)
    readings2[thisReading2] = 0;
  for (int thisReading3 = 0; thisReading3 < numReadings3; thisReading3++)
    readings3[thisReading3] = 0;
« Last Edit: January 14, 2013, 12:22:47 am by dreggory » Logged
utah
void requestInt()
  delay(8);
  if (byteSending == 1) //send packet 1
    toSend = Shift & mask;
    Shift = Shift >> 8;
    Wire.send(toSend);
    byteSending = 2;
  else if (byteSending == 2) //send packet 2
    Shift = Shift >> 8;
    Wire.send(toSend);
    byteSending = 3;
  else if (byteSending == 3) //send packet 3
    Shift = Shift >> 8;
    Wire.send(toSend);
    byteSending = 4;
  else if (byteSending == 4) //send packet 4
    Shift = Shift >> 8;
    Wire.send(toSend);
    byteSending = 1;
    //initialization for next turn
    Shift = BPMDelay;
    mask = 0xFF;
    toSend = 0;
int Strobe()
  digitalWrite(resetPin, HIGH);
  delay(33);
            for(int b=0; b < 7; b++)
                delayMicroseconds(18);
                if (b==0)
                    digitalWrite(strobePin, LOW);
                    analogRead(analogPin);
                    spectrumValue = analogRead(analogPin);
//                    Serial.print(" s1=");
//                    Serial.print(spectrumValue);
//                    Spacing();
                    holdValue1 = spectrumValue;
                if (b==1)
//                    Serial.print(" s2=");
//                    Spacing();
                    holdValue2 = spectrumValue;
                if (b==2)
//                    Serial.print(" s3=");
//                    Spacing();
                    holdValue3 = spectrumValue;
                 if (b==3)
//                    Serial.print(" s4=");
//                    Spacing();
                    holdValue4 = spectrumValue;
                 if (b==4)
//                    Serial.print(" s5=");
//                    Spacing();
                    holdValue5 = spectrumValue;
                 if (b==5)
//                    Serial.print(" s6=");
//                    Spacing();
                    holdValue6 = spectrumValue;
                 if (b==6)
//                    Serial.print(" s7=");
//                    Spacing();
                    holdValue7 = spectrumValue;
//              Serial.println();
int Spacing()
  if (spectrumValue < 10)
      Serial.print("    ");
  else if (spectrumValue < 100 )
      Serial.print("   ");
      Serial.print("  ");
int AverageSpectrum2And3()
  cyclesS2++;
  cyclesS3++;
  spectrumSum2 += holdValue2;
  spectrumSum3 += holdValue3;
  average2 = ((spectrumSum2)/(cyclesS2));
  average3 = ((spectrumSum3)/(cyclesS3));
//  Serial.print(" spectrum ave1=");
//  Serial.print(average2);
//  Serial.print(" add it up=");
//  Serial.print(cycles1);
//  Serial.print(" Spectrum Sum =");
//  Serial.print(spectrumSum1);
//  if (cycles1 - lastCycle > 4)    //count to four make a new line
//   Serial.println();                //  make sure to un-comment
//   lastCycle = cycles1;
void DynamicC()
  cyclesV++;
  if (holdValue2 > average2)
    variance = ((holdValue2)-(average2));
  if (average2 > holdValue2)
    variance = ((average2)-(holdValue2));
//  Serial.print(" variance =");
//  Serial.print(variance);
//  if (variance > greatestVariance)
//         greatestVariance = variance;
//         Serial.print(" GreatestVariance=");
//         Serial.print(greatestVariance);
  varianceSum += variance;
//  Serial.print(" varianceSum =");
//  Serial.print(varianceSum);
  averageVariance = ((varianceSum)/(cyclesV));
//  Serial.print(" aveVariance =");
//  Serial.print(averageVariance);
//  if (averageVariance > greatestAverageVariance)
//    greatestAverageVariance = averageVariance;
//    Serial.print(" greatest Average Variance =");
//    Serial.print(greatestAverageVariance);
  C = (((0.00125)*(averageVariance))+(1));
//  Serial.print(" C =");
//  Serial.print(C);
void DynamicC3()
  cyclesV3++;
  if (holdValue3 > average3)
    variance3 = ((holdValue3)-(average3));
  if (average3 > holdValue3)
    variance3 = ((average3)-(holdValue3));
  varianceSum3 += variance3;
  averageVariance3 = ((varianceSum3)/(cyclesV3));
  C3 = (((0.00125)*(averageVariance3))+(1));
//  Serial.print(C);
utah
void Beat2()
  if(trigger2 == 0)
    if((holdValue2) > ((average2)*(C)))
        beat2++;
        trigger2 = 1;
  if((holdValue2) < ((average2)*(C)))
      trigger2 = 0;
void Beat3()
  if(trigger3 == 0)
    if((holdValue3) > ((average3)*(C3)))
        beat3++;
        trigger3 = 1;
  if((holdValue3) < ((average3)*(C3)))
      trigger3 = 0;
void BPM2()
//  // subtract the last reading:
//  total2 -= readings2[index2];
  // read the beats
  readings2[index2] = beat2;
  // add the reading to the total:
  for (int i2 = 0; i2 < 19; ++i2)
      total2 += readings2[i2];
Serial.print(" TOTAL 2=");
Serial.print(total2);
Serial.println();
  // advance to the next position in the array:
  index2++;
  // if at the end of the array...
  if (index2 >= numReadings2)
    // ...wrap around to the beginning:
    index2 = 0;
//  holdBeat2 = beat2;
  Serial.print(" **** BPS 2 ****=");
  Serial.print(beat2);
  Serial.println();
  greg2 = 2;
void BPM3()
//  total3 -= readings3[index3];
  // read the beats
  readings3[index3] = beat3;
  for (int i3 = 0; i3 < 19; ++i3)
//      if(i3 == 0)
//        Serial.print("yaaaaaaaaaaaaahhhoooooooooo");
      total3 += readings3[i3];
    Serial.print(" TOTAL 3=");
    Serial.print(total3);
    Serial.println();
  index3++;
  if (index3 >= numReadings3)
    index3 = 0;
//  holdBeat3 = beat3;
  Serial.print(" **** BPS 3 ****=");
  Serial.print(beat3);
  Serial.println();
       greg3 = 2;
void AverageBPM2()
  if(cycles2 < 20)
cycles2++;
  Serial.print("cycles2=");
  Serial.print(cycles2);
  Serial.println();
   aveBPM2 = ((total2)/(cycles2));
   aveBPerM = (aveBPM2 * 48);
   delay(100);
   if (aveBPerM < 30)
     aveBPerM = 30;
   if (aveBPerM > 500)
     aveBPerM = 500;
    total2 = 0;
     greg2 = 0;
utah
void AverageBPM3()
  if(cycles3 < 20)
cycles3++;
  Serial.print("cycles3=");
  Serial.print(cycles3);
  Serial.println();
   aveBPM3 = ((total3)/(cycles3));
   aveBPerM3 = (aveBPM3 * 48);
   delay(100);
   if (aveBPerM3 < 30)
     aveBPerM3 = 30;
   if (aveBPerM3 > 500)
     aveBPerM3 = 500;
       total3 = 0;
       greg3 = 0;
void ResetSec()  //ran every second
// delay(10);
  lastCycle = 0;
  beat2 = 0;
  beat3 = 0;
  variance = 0;
  variance3 = 0;
  varianceSum = 0;
  varianceSum3 = 0;
  cyclesV = 0;
  cyclesV3 = 0;
void ResetTenSec2()  //was used to run every ten seconds
  delay(15);
  spectrumSum2 = 0;
  cycles2 = 0;
  sumBPM2 = 0;
  cyclesS2 = 0;
void ResetTenSec3()  //was used to run every ten seconds
  delay(15);
  spectrumSum3 = 0;
  cycles3 = 0;
  sumBPM3 = 0;
  cyclesS3 = 0;
void Fruity()
  delay(20);
  Fruit3 = 0;
void FruityOs()
  Fruit = 0;
void software_Reset() // Restarts program from beginning but does not reset the peripherals and registers
asm volatile ("  jmp 0");
Strobe();
if (holdValue2 > 130)
  Fruit = 0;
  delay(10);
  do
      Strobe();
      AverageSpectrum2And3();
      DynamicC();
      Beat2();
      timer.run();
      if (greg2 == 2)
         AverageBPM2();
         if (aveBPerM > 35)
             BPMDelay = (((60)/(aveBPerM))*(1000));
             delay(50);
//             Serial.print("^^^^BPMDelay in 2^^^^=");
//             Serial.print(BPMDelay);
//             Serial.print("****BPMDelay is set in 2****");
         Serial.print("      ******* Average BPM 2 *******= ");
         Serial.print(aveBPerM);
         Serial.print("      BPMDelay =");
         Serial.println();
      if ((holdValue2< 100) || (aveBPerM == 30))
          ResetTenSec2();
          Serial.print("holdValue2 =");
          Serial.print(holdValue2);
          Fruit = 2;
          Fruit3 = 2;
    }while(Fruit == 0);
if ((holdValue3 > 130)&&(Fruit3 == 2))         //detect third spectrum if fail to run spectrum 2
              delay(10);
              do
                  Strobe();
                  DynamicC3();
                  Beat3();
                  timer.run();
                  if(greg3 == 2)
                    AverageBPM3();
                    if (aveBPerM3 > 35)
                       BPMDelay = (((60)/(aveBPerM3))*(1000));
                       delay(50);
                       Serial.print("BPMDelay is set in 3");
                     Serial.print("      ******* Average BPM 3 *******= ");
                     Serial.print(aveBPerM3);
                     Serial.println();
                  if ((holdValue3< 100) || (aveBPerM3 == 30))
                     ResetTenSec3();
                     Fruit3 = 0;
                }while(Fruit3 == 2);
  Serial.print("Waiting...");
  Serial.println();
  BPMDelay = 115;
//if(Fruit == 2)
//  if (aveBPerM < 35)
//      Fruit = 0;
//  delay(100);
//  ResetSec();
////  ResetTenSec();
utah
I wish I could have posted it all in one but I had to cut it up, it's a large sketch.
References:
http://www-scf.usc.edu/~ise575/a/projects/mooser/BeatDetector.htm
hmm you know... as I was checking the bookmarks I had used for reference, I noticed this ^ was the only link that wasn't broken. expired web pages sorry.
Sydney
Big things come in large packages
You can attach files to a posting by clicking on the Additional option... At the bottom of the reply/post screen.
utah
Awesome, thanks!
ok here is my sketch in one file
Montreal
Per aspera ad astra.
Error 503 Service Unavailable
Service Unavailable
Guru Meditation:
XID: 1087605664
Varnish cache server
                                          What does it mean???
utah
I don't know. Seems it didn't upload the sketch right. I'll upload it again.
utah
Nope. Didn't fix it. Guess you'll have to copy paste the code from above. Sorry guys.
utah
Here's a video of the whole project put together
https://www.youtube.com/watch?v=fA-RN_4i4y4&feature=youtube_gdata_player
