Topic: Help with a random number generating 7 seg display problem! (Read 2413 times) previous topic - next topic
green_dog252
This is probably a very simple fix, and I'll just put the code up:
int potnum;
int duration;
long randNum;
  pinMode(6, OUTPUT);
  pinMode(7, OUTPUT);
  pinMode(8, OUTPUT);
  pinMode(9, OUTPUT);
  pinMode(A0, INPUT);
  randomSeed(analogRead(A1));
  randNum = random(10);
  seg(randNum);
void seg(long num){
  if (num = 0){
  digitalWrite(6, LOW);
  digitalWrite(7, LOW);
  digitalWrite(8, LOW);
  digitalWrite(9, LOW);
  Serial.println(num);
  delay(pot());
  if (num = 1){
  digitalWrite(9, HIGH);
  delay(pot());
  if (num = 2){
  digitalWrite(8, HIGH);
  delay(pot());
  if (num = 3){
  delay(pot());
  if (num = 4){
  digitalWrite(7, HIGH);
  delay(pot());
  if (num = 5){
  delay(pot());
  if (num = 6){
  delay(pot());
  if (num = 7){
  delay(pot());
  if (num = 8){
  digitalWrite(6, HIGH);
  delay(pot());
  if (num = 9){
  delay(pot());
int pot(){
  potnum = map(analogRead(A0), 0, 1024, 0, 500);
  return potnum;
If you go ahead and run this code for yourself, you'll see that it outputs 1, 2, 3...9 and then starts over. I want this to output random numbers on a seven segment display (I'm using an SN7446AN to achieve this).
The whole side of the program that outputs number on a display and the part that determines how quickly these numbers are displayed works fine, but the numbers aren't random! They just go on from 1-9 (it skips 0 for some reason).
So my questions are: Why does the code skip 0 and why aren't the numbers outputted random? I'm fairly new to making subroutines in Arduino, so I'm sure that's where my problem is.
please help! Thank you!
larryd
randomSeed(analogRead(0));
random(min, max);
See:
http://arduino.cc/en/Reference/Random
http://arduino.cc/en/Reference/RandomSeed
No technical PMs.
The last thing you did is where you should start looking.
Coding Badly
Coding Badly
In the worst case is pointless.  In the extremely rare best case produces 1024 unique sequences.
Coding Badly
larryd
This reads a floating Analog i/p.
The i/p voltage will fluctuate randomly.
No technical PMs.
green_dog252
  if (num = 0){
Assignment versus comparison.
*facepalm* Sigh... i'm embarrassed to have had to bring this question up. Thank you.
  pinMode(A0, INPUT);
Why?
That's the input of the potentiometer. Necessary?
Coding Badly
You are welcome.
Necessary?
No.  You should only call pinMode on digital pins (on pins you will be accessing using digital functions like digitalRead and digitalWrite).
Coding Badly
I assume you are referring to this...
Wanna bet?
